Old Apr 08, 2014, 03:30 PM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
i have found in a box 2 caps 220 35v caps...too little ?
magrinsi is online now Find More Posts by magrinsi
Old Apr 08, 2014, 03:40 PM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
better get 470uF...
sebbe is online now Find More Posts by sebbe
Old Apr 08, 2014, 08:24 PM
Joined Nov 2013
Put another 5 flights on the Reverb today. Field was around 75F. with light winds.
Only news is the new A-Spec G2 2200 slips in easier than the old A-Spec does. Its slightly smaller in height and width (33x33 v 35x34). Also slightly lighter in weight. Run times the same.
As far as performance, really didn't notice any difference. Have a new logger coming which will include rpm along with watts and amps.
Best.
PHDBouncingBob is offline Find More Posts by PHDBouncingBob
Old Apr 14, 2014, 01:15 PM
Italy
Joined May 2009
Description: Name: uploadfromtaptalk1397498996148.jpg
Description: Name: uploadfromtaptalk1397499008209.jpg
Description: Name: uploadfromtaptalk1397499022555.jpg
Description:
Finally I started to build my plane, added carbon firewall and carbon roving in the fuse, this is the first time I make those things I hope it will works, I put carbon hinge and I want to test throws before glueing the servos, can you tell me the throws and CG please?
I too have a 100A yep, I think to change cables with thinner ones, do I have to add caps to it too?
Thank you
anestetico is offline Find More Posts by anestetico
Old Apr 17, 2014, 07:28 AM
Speed is Good!
rumbey's Avatar
Chippenham, Wilts
Joined Oct 2005
Can anyone recommend an outrunner motor that I can use with my swift( reverb) with 3s 2200 35c battery and 10 x 6 folding prop?
rumbey is offline Find More Posts by rumbey
Old Apr 17, 2014, 10:13 AM
Joined Oct 2009
First attempt at getting some video of the Reverb, rain was on the way so I hurriedly setup the camera.
If you look closely you can even see it a few times
HK Reverb on 4S Pylon Racer Setup (2 min 20 sec)
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Apr 18, 2014, 12:23 AM
Joined Nov 2013
We don't have any grass around our RC field to land in. Just red dirt. Alot of it. Found the better way to protect the belly as its nice to land on the runway. I now have added a small strip of JB weld to the belly and tail of the Reverb. It holds up quiet well.
Get around 10 landings in before I have to mix a small amount and reapply. The Reverb now has close to 100 flights. Been getting around 10 per day. HK doppler(RCSpeedo?) has it around 165-170 mph most times. The motor, esc and batteries are all doing fine.... just slightly warm to the touch after flight.
Best.
Old Yesterday, 02:17 PM
Italy
Joined May 2009
I have mixed infos on this thread and got this values:
Reverb Hobbyking
CG 50 - 55 mm (I don't like nose heavy so will try at the field)
Landing: ELE +6 - 5mm AIL +8 -5mm
Speed: ELE +- 2mm AIL +5 -3 mm
Spoilerons: AIL +24mm (I think I don't need on my field)
I am waiting for the linkage as I don't like the HK one and I have to decide if glue the elevator or only use 2 screws, I think to maiden it next week-end
Question Will Wasp V4/Belt 250 parts fit on Wasp V3? cfanto Skyartec 8 Mar 24, 2010 04:02 PM
Wanted Spirit E by mibo FASTBEN Aircraft - Sailplanes (FS/W) 3 Dec 07, 2009 01:36 AM
anybody know Mibo Modeli "spirit e"??? trashmanf High Performance 3 Jul 23, 2005 08:33 PM
Mibo Modeli Spirit e 207 Electric Sailplanes 15 Jul 23, 2005 07:26 AM
Any info about Mibo Spirit E? AndrésMtnez High Performance 27 Jun 20, 2005 09:21 AM
