Old Jun 28, 2015, 08:50 PM
Sluice is offline
Find More Posts by Sluice
CrumpyLogs
Joined Jun 2013
Camber / Airfoil Help
Hi all! Let me start by saying that I've been flying my homemade foamies for quite a while but I never really experimented with airfoil sizes. All my wings are the same design, 7" long and a camber of 3 cm high in the highest part. The glide ratio is decent on my planes.
Then I just bought a bixler and that thing refuses to stop flying! The glide ratio is crazy. So I looked at the airfoil and it's barely half the size of my airfoils (in terms of height).
I know I'm giving very vague information but how should I choose the thickness of my airfoil? I know plane size, weight and all that definitely factor in but why does the very thin wing of the bixler fly longer then my airfoils that are twice as big? If you could give me a general idea I'd be happy! Thanks!
Sluice is offline Find More Posts by Sluice
Old Jun 28, 2015, 09:34 PM
whitecrest is online now
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Thicker airfoils are not as "slippery" as the thinner ones, even though they can generate more lift given enough power. The higher drag will reduce the glide ratio, as you have observed.
You can use a program like Profili to examine a wide variety of airfoils to get a better idea of what to design yourself. A fairly typical camber-to-chord ratio of many practical airfoils used in modeling is around 12-15 percent. The amount of camber you described seems to be unusually high.
whitecrest is online now Find More Posts by whitecrest
Old Jun 28, 2015, 09:47 PM
Sluice is offline
CrumpyLogs
Joined Jun 2013
Alrighty whitecrest thank you very much for that! Seems to make sense. I'll adjust my wing and see how it works from there.
So for my 7 inch long wing I should have a camber of about 0.84 inches? Cool.
Old Jun 28, 2015, 10:22 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Yes. If you're not doing this already, you can cut your own foam wing cores using just a couple of templates and a hot-wire foam cutter. This can produce a wing section with an accurate airfoil ready for balsa sheeting or glassing. However, for most sport flying, it is not necessary to get too hung up about any particular airfoil or extreme accuracy.
I scratch build with balsa and have had good luck using the Clark Y airfoil, which is well known. It has worked well for me in models with a wingspan of about 36 inches, 210 sq.in. of wing area and about 7-8 oz/sq.ft. wing loading. These planes are easy to trim for level flight and glide very well. Other similar airfoils would most likely deliver the same good performance.
Good luck with your experimentation.
Old Jun 28, 2015, 11:00 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Firstly: "camber' is NOT the the thickness of the airfoil.
Lotsa Reading /Research into the nature of Airfoils is suggested.. before you can begin to have an articulate conversation about them
Bare is offline Find More Posts by Bare
Old Jun 28, 2015, 11:34 PM
PGregory is online now
Find More Posts by PGregory
Now I have to land that thing?
PGregory's Avatar
United States, NY, Poughkeepsie
Joined Apr 2014
So Bixler has less lift but more wing area with a resultant less drag. Those planes are really engineered these days. Look at the Radian, UMX Radian, etc. They are heavily engineered, with complex manufacturing, too. Expensive molds to form those wings to spec. Even compound curves and winglets. Don't underestimate what went into that design. Thing is, there are only about 1 Million people around the world that would love to have that task - engineering model airplanes.
Bare, are there any entry level books on airfoils for model aircraft?
Probably the first thing to get into is what a Reynolds number is.
Cheers - Poughkeepsie Pete
PS I noticed these suggested threads at the bottom of the page of your post:
PGregory is online now Find More Posts by PGregory
Old Jun 29, 2015, 06:50 AM
Sluice is offline
CrumpyLogs
Joined Jun 2013
There is a reason why I said camber/airfoil size. And while I may now know all the nittygritty breakdown of a wing I certainly know how to build them. I don't know what size to build them but I make a great airfoil from foamboard
Old Jun 29, 2015, 06:52 AM
Sluice is offline
CrumpyLogs
Joined Jun 2013
Originally Posted by PGregory View Post
So Bixler has less lift but more wing area with a resultant less drag. Those planes are really engineered these days. Look at the Radian, UMX Radian, etc. They are heavily engineered, with complex manufacturing, too. post:
I gotcha! Well thank you!
Discussion Higher Angle Of Attack Symmetric airfoil vs. High Camber airfoil wing z-matrix Modeling Science 30 Sep 05, 2011 07:03 AM
Does the SD7037 Airfoil Like Camber? Erik_J Thermal 17 Aug 17, 2005 04:56 PM
Ailerons and Cambered Airfoils foamflyer Modeling Science 12 Jul 17, 2004 01:14 PM
Yippee! new airfoils, camber control Mike Waters Hand Launch 24 Jul 12, 2003 05:50 PM
AG16 & AG17 airfoils - camber, thickness percentages for 7 and 5 inch chord? fprintf Hand Launch 2 May 21, 2003 05:07 PM
