Old Jun 15, 2013, 01:10 PM
SteenPedersen is offline
Find More Posts by SteenPedersen
Joined Nov 2012
Dr. Mad Thrust 50mm problems
Hi
I am new to this forum but hope I have posted this the correct place.
I just got Dr. Mad Thrust 50mm 4S version today
http://www.hobbyking.com/hobbyking/s...DF_3300kv.html
Unfortunately I didn't get the results I expected.
I use a Dynam Dectrum 30A ESC http://www.hobbypartz.com/60p-dye-1003-30a-esc.html
For the test I used my nanotech 850mAh 4S battery http://www.hobbyking.com/hobbyking/s...lipo_pack.html
I only draw 22A / 315 Watt and about 350 grams of thrust.
Any idea why?
BR
Steen
SteenPedersen is offline Find More Posts by SteenPedersen
Old Jun 15, 2013, 01:38 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
I have these fans in my Banshee. I think your battery is too small.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jun 15, 2013, 02:53 PM
Joined Nov 2012
Thanks.
I thought it would be enough. 0.85 x 45 = 38 amps?
I'll try order another (nano-tech 1300mah).
BR
Steen
Old Jun 15, 2013, 06:27 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
might try adjusting the timing on the dynam esc but watch the heat and watts
D_FAST is offline Find More Posts by D_FAST
Old Jun 15, 2013, 07:44 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
An 850 mah Battery!? A wee bit tiny.
As for C ratings.. Brochure Babble..
Divide claimed ratings by half and then these would be only optimistic, rather than laughable.
Bare is offline Find More Posts by Bare
Old Jun 16, 2013, 11:02 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Better battery and high timing should see numbers close to spec.
anlucas is online now Find More Posts by anlucas
Old Jun 16, 2013, 02:36 PM
Si Goodchild is offline
Find More Posts by Si Goodchild
Si Goodchild's Avatar
Lincolnshire, UK
Joined Oct 2009
Agree with the above, such a small battery will sag under the load of that motor and the thrust will drop off dramatically. Suggest you test with the biggest pack you can muster (parallel them if you have to) and then draw comparisons.
Si Goodchild is offline Find More Posts by Si Goodchild
Old Jun 16, 2013, 04:17 PM
Joined Nov 2012
Thanks for your help. I only have 3S batteries. The little 4S is for my funfighter :-) I will take the plane with me to the club tomorrow and put a bigger 4S on. I'll be back with the results.
Old Jun 17, 2013, 08:55 AM
Joined Nov 2012
Tried today with a bigger battery with the same result.
I guess I should read the "max" 650g thrust. In the real world it delivers 350 grams.
New motor on its way.
BR
Steen
Old Jun 17, 2013, 09:02 AM
Tim Wan is offline
Find More Posts by Tim Wan
Joined Apr 2008
BR
Steen
Hi Steen,
Have you set the ESC time mode in higher position and calibrate the throttle range with ESC.. Since some brand ESC is needed to do the calibration for getting the full throttle position either add 20% travel of throttle channel to test again... The related EDF 4S version to be able gained up to this thrust if the setting is correct.
Hope the above to be assisted you.
Tim
Tim Wan is offline Find More Posts by Tim Wan
Old Jun 17, 2013, 09:38 AM
anlucas's Avatar
Joined May 2011
BR
Steen
True, 650gr is maximum for a few seconds when the battery is full but I have seen consistent 600gr after the initial peak. This is outside the airframe though on a test stand.
As above, make sure timing is set to high.
Are you measuring in the airframe?
Old Jun 17, 2013, 12:45 PM
Joined Nov 2012
Hi again.
Yes I am measuring in the frame. I put the aircraft on the nose, reset the weight and gives full throttle.
I just changed the ESC time mode to fast/high (the 3.rd choise).
I fully charged the battery and made the test. Only 350 grams of thrust.
The aircraft weight is 475 grams with the battery and I was hopening for a vertical acceleration.
I have now ordered a 2815 4800kv for this fan. I read on the thread below the product on HK website that this should do the trick?
In the meantime I have put back my old hyperion y22s 6000kv with my wemotec fan - it's giving me 450 grams with a 3S battery :-)
BR
Steen
Old Jun 17, 2013, 03:32 PM
anlucas's Avatar
Joined May 2011
This is the reason. The 650gr thrust is with fan out in the open air.
When the fan is installed, the intake restriction and backpressure from the exhaust result in much lower thrust levels for these 10blade fans.
When you fly though, the air ducts work quite well and the thrust decrease is not so noticeable.
I suggest that you sand the exhaust a bit to open it up 2mm at a time and/or cut cheater holes to help the fan pull more air in. This will definetely improve thrust.
Old Jun 17, 2013, 08:48 PM
Bare is offline
Canada
Joined Nov 2000
I'm thinking this CS rotor is barking up the wrong tree.
Inserted a Haoye 50mm 7 blade rotor which incidentally Fits! the CS Alloy shroud Very well.. better than the 10 blader does OR the Haoye in it's own Haoye shroud.
Using a hk 2815 of 4000kv on 4s it measures ~38 a @530 watts and generates 750 gms thrust... In a Nacelle :-).
No shroud contact at 50K .. yet.
10 blade rotor is decidedly poor in comparison during my experimentation, although I'm liking the alloy shroud's concentricity and rigidity ...a lot .
Old Jul 24, 2013, 01:49 PM
Cody f86saber is offline
Find More Posts by Cody f86saber
Pro Jet Pilot
Cody f86saber's Avatar
Canada, NB
Joined Apr 2006
I also have the 7 blade and 10 blade, and I concur that the 7B fits better in the aluminum housing than its own. I have been using the 2815 4800kv motor in the 10 blade fan for some time and with good flight results, and on a warm 1300 3S pack this setup provided 47A, 11.31V, 532 Watts, and the RPM gets pretty high but the impeller has held together thus far. This motor runs only warm as it is free to cool in the fan's airstream. Its enough power to move the 50mm F-16 at moderately high speeds, such that it goes from being barely within sight to almost out of sight again in under four seconds, and could move a 64mm class airframe, although not necessarily fast in that scenario. I am not sure what your plans are SteenPedersen, but this setup flies nice at half throttle, and normal mixed throttle flights with several WOT passes will last about 3 minutes, as nobody flied with the throttle at full for the entire duration. This setup does put the 50mm airframes near the limit in terms of ease of hand launch. I have had over 100 flights on this airframe, the same one since 2010 without any incident. As you get into larger packs, larger ESCs and in this case, a pretty hefty motor that would normally be seen on a 64mm fan, it begins to push the tip stall point during hand launches and you can feel it in high-bank turns as it overshoots (which looks really cool). It is important that you balance the impeller and ensure that the adapter is straight on the motor shaft. If you're only able to get low thrust on 4S even on the stock motor, there is something wrong. I do not place any great credence in C ratings, but they can guide you to lower IR packs, but nothing more and it has to be verified by yourself first. An internal resistance meter like those built into the FMA and iChargers is a great help here, and since you have measured your systems power, you should also take note of the voltage drop at your relatively low 22A current draw. If the voltage appears strong, then you can eliminate the battery as the problem for the time being and move to the next component in the chain. If you have a servo analyzer, you can verify if your throttle channel is receiving full throttle or not. I have spent a lot of time lending advice to others in the Power Systems forum and on occasion this type of low power issue is caused by the transmitter throttle endpoints. It could also be a wrongly wound motor but they typically vibrate when a coil has the incorrect number of turns compared to the others. A bad ESC with high impedance semiconductors or a high IR cell can induce your weak power symptoms, too. Those parts have to be verified firsthand. Below is a photo that I took depicting both fans just for comparative purposes:
Cody f86saber is offline Find More Posts by Cody f86saber
Sold FOR SALE: Brand New Dr. Mad Thrust EDF Inrunner superjon Aircraft - Electric - Jets (FS/W) 2 Jun 07, 2013 12:43 PM
Sold FOR SALE: Brand New Dr. Mad Thrust Inrunner EDF Motor 2200kv superjon Aircraft - Electric - Power Systems (FS/W) 1 Jun 07, 2013 12:42 PM
Discussion Dr Mad Thrust 3000kv 1300w stanordave Power Systems 0 May 28, 2013 03:10 PM
Discussion Dr Mad Thrust 3300kv stanordave Power Systems 0 Mar 27, 2013 01:29 PM
Discussion Dr Mad THrust 2200kv stanordave Power Systems 0 Mar 24, 2013 05:14 PM
