Old Mar 20, 2010, 10:41 AM
Vladimir88's Avatar
Joined Mar 2010
New Product
Control brushless motors "YGE 4S" for receiver AR6400
Be interesting control brushless motors "YGE 4S" for receiver AR6400.
His weight without wires - 0.6 grams.
http://www.yge.de/artikel.php?search=yge4s
I wonder what the output resistance he has?
Can he be the alternative to the widely ubiquitous XP-3A and XP-7A with too much loss of output impedance?
Its price is approximately equal to the price leader, quality- TMM 0703-3 EXPERT
http://mgm-compro.com/index.php?tid=...-0703-3-expert.
But it is easier for it twice and resolved the problem with micro-connector.
Regulator "YGE 4S" really can buy here -
http://www.slowflyworld.de/index.php...ucts_id=114248
Vladimir88 is offline Find More Posts by Vladimir88
Old Mar 20, 2010, 07:26 PM
It's a spiderweb of knit lines
Souderton Pa. USA
Joined Mar 2002
Thanks Vladimir88, that's exactly what I've been looking for since the YGE-4BL doesn't seem to be available anymore.
mcross is offline Find More Posts by mcross
Old Mar 20, 2010, 10:47 PM
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I think BSD has some of these coming. I'm planning to get a couple when he gets them. I always thought the YGE was the best micro BL controller.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 21, 2010, 08:06 AM
Souderton Pa. USA
Joined Mar 2002
Yep, YGE are the best in my opinion. After all the wasted time and missed flight time due to failures/problems with the HK esc's I will never buy them again. Last straw was KIEF, only had one good flight all weekend with my F-84 due to a HK esc. All 5 YGEs I've bought over the years still work flawlessly.
Old Mar 30, 2010, 10:07 PM
Souderton Pa. USA
Joined Mar 2002
Just recieved my controllers from Germany. Excellent workmanship and exactly .6g without wires or connector. Now I need to translate the instructions, lol.
Old Mar 31, 2010, 04:25 AM
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Its beautiful!!
Google translate works well enough on the manual.
MegaTesla is offline Find More Posts by MegaTesla
Old Apr 04, 2010, 12:18 PM
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Is this 2s capable?
boredom.is.me is offline Find More Posts by boredom.is.me
Latest blog entry: RFD900 Case
Old Apr 04, 2010, 12:37 PM
Vladimir88's Avatar
Joined Mar 2010
Yes, powered by 2S perhaps, judging from data on the controller:
Max # 4A continuous current, in with good cooling airflow.
# 1 to 2s LiPo with automatic detection of cell number reduction at low voltage.
# Undervoltage disabled.
# Speed control (Governor Mode)
# Soft start individually adjustable.
# Emf brake in 3 steps.
# Frequency of 8 to 16 kHz
# Rpm limit: 240,000 rpm (2 Poles)
# Dimensions: 11.5 x 17 x 3.5 mm
# Weight 0.6 g without cable
# Programming with the ProgCARD II
Old Apr 04, 2010, 01:09 PM
Souderton Pa. USA
Joined Mar 2002
It is 2 cell capable but does not have a bec. Voltage to the rx and servos is the battery voltage. So, for the AR6400, it's a one cell esc.
Old Apr 14, 2010, 01:10 PM
Vladimir88's Avatar
Joined Mar 2010
Comparative tests of the regulator YGY-4S for losses on the output resistance, I spent a measurement of static thrust of different regulators.
The controller connected to the AR6400 receiver and brushless motor MM-13/3/12T (http://www.bsdmicrorc.com/index.php?productID=840).
Handle "gas" the transmitter to the maximum position.
On the motor shaft set screw (160 x 70) from the micro-aircraft SU-26m.
Supply voltage 3.7-Volt.
The static thrust with a regulator YGE-4S (weight- 0,6 gr.) amounted to - 67 grams.
For comparison quote the results with other regulators.
The static thrust with a regulator TMM-0703-3 (weight- 1,1 gr.) (http://mgm-compro.com/index.php?tid=...-0703-3-expert) amounted to- 68 gr.
Since the regulator MBC-3 MicroInvent (weight- 0,22 gr.!) (http://www.microinvent.com/mambo/ind...d=23&Itemid=42) amounted to - 61 gr.
Since the regulator XP-5A Micron Radio Control (weight- 0,8 gr.) amounted to - 58 gr.
Since the regulator XP-7A (weight- 1,58 gr.) amounted to - 52 gr.
With the regulator XP-3A (weight- 0,4 gr.) amounted to - 52 gr.
Conclusions.
1. Controller YGE-4S "won" controlers XP-7A and XP-3A at 15 grams thrust (approximately 30 %)!!!
2. Controller YGE-4S practically not inferior traction best controller TMM-0703-3 and in this case has is two times less weight and the presence of connectors for connecting to the receiver AR6400!
Old Apr 14, 2010, 01:36 PM
Way to many airplanes!
Canada, QC
Joined Oct 2009
Wow, nice job Vladimir... Didn't knew that the ESC could make such a big difference! Particularly in lower power ESC. Thanks!
RealGambler is offline Find More Posts by RealGambler
Old Apr 14, 2010, 04:14 PM
Vladimir88's Avatar
Joined Mar 2010
Originally Posted by RealGambler View Post
... Didn't knew that the ESC could make such a big difference! Particularly in lower power ESC. ....
The problem is that the at low voltage on the energy loss supply strongly affected the voltage drop on the transistor switches.
Example.
The currents through the transistor switches
regulators will cause the loss 0,5 Volt -
at a voltage 7,4 V loss would amount- 6,75%;
at a voltage 3,7 V loss would amount -13,5%.
Than lower supply voltage, the greater will be the loss of energy, with the same elemental base ESC regulators.
Conclusion.
With a low supply voltage (3.7 V) absolutely impossible to save on quality ESC regulator!
Old Apr 14, 2010, 11:31 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Whoa here!!!
The old YGE-4 was capable of 1, 2 or 3 LiPo cells, and It had BEC.
I'm currently using one with a Spektrum ar6400, adding a silicon rectifier diode (1N4000) between the ESC and the Rx.
So the new YGE-4S cannot accept a 3S battery pack, and does not have BEC??? I don't know of a single receiver that can accept an 11.1 vdc supply voltage!!
356Jim is offline Find More Posts by 356Jim
Old Apr 15, 2010, 12:24 AM
Vladimir88's Avatar
Joined Mar 2010
Yes, the controller YGE-4S no has BEC and can not solve the problem of power AR6400 receiver on the voltage over 1S.
But for micro - aircraft weight category up to 50 grams, the use of LiPo 2S and 3S is a necessary measure to achieve the required thrust, more than 50 grams.
But this option the weight of the aircraft did not get the minimum possible.
The second (better) way is the use of low-Voltage power supply (1S) the use of efficient brushless motors and ESC controls.
Therefore, YGE-4S is the uncompromising choice in achieving maximum traction motor at minimum weight of the aircraft!
P.s.
Examples of effective brushless motors powered by LiPo 1S (by 3,5 V) using YGE-4S.
1. Thrust 67 gr. - motor MM 13/3/12 (weight 5 gr) http://www.bsdmicrorc.com/index.php?productID=840
2. Thrust 85 gr. - motor MM 13/4/8T (weight 6 gr) http://www.bsdmicrorc.com/index.php?...2&show_all=yes
3. Thrust 92 gr. - motor G15 12W 3.6V Bronco Gasparin (weight 7 gr) http://www.gasparin.cz/?show=frames&...hatsnew&lng=en
4. Thrust about 80 gr. - motor (C05M-11000) with gearbox (1 : 4) (weight 6 gr) http://www.rcgroups.com/forums/showthread.php?t=1207768
motor (C05M-11000) with gearbox (1 : 3) (weight 5,4 gr) http://www.rcgroups.com/forums/showthread.php?t=1207845
5. Thrust about 80 gr. - motor (HP03S) with gearbox (1 : 4 ) (weight 4,5 gr) http://www.rcgroups.com/forums/showt...1207845&page=3
Old Apr 15, 2010, 05:55 AM
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Thanks Vladimir for these informations.
I've ordered one for a single cell micro edf jet project.
I've seen that there is a programming card, but i hope it can be configured by mean of the transmitter....
indoor_fr is online now Find More Posts by indoor_fr
Sold Quad - Walkera UFO#4 board & ESCs for sale for Brushless motors frank48 Aircraft - Electric - Helis (FS/W) 2 Mar 22, 2010 02:14 PM
Discussion Gauging Interest: 4 Channel ESC for Brushless Motors (RS232/PWM/I2C + Atmel AVR's!) Mrbmw99 Power Systems 0 Mar 10, 2010 03:36 PM
Discussion Tiny Dancer micro F3P for AR6400 & MM Brushless Gordon Johnson Scratchbuilt Indoor and Micro Models 79 Feb 14, 2010 03:11 PM
Sold Sensorless Control for 010 Brushless motors NEW $30.00 shipped Mikemynameis Aircraft - Electric - Power Systems (FS/W) 0 Sep 27, 2009 04:38 PM
Discussion Curious Problem With AR6400 and YGE-4 BL ESC 356Jim Scratchbuilt Indoor and Micro Models 7 Sep 02, 2009 12:50 AM
