Old Feb 25, 2015, 12:15 PM
gibby mcfender's Avatar
United States, TN, Nashville
Joined Sep 2013
Voltage readings/warnings using FSBV-01? Battery jumping low
I've been through all the tutorials and setup vids, and I'm positive this system is set up correct... but maybe I'm missing something. (I've got the sensor getting its reading straight from the positive and negative leads from battery)
I set my Taranis to give me audible warnings (battery low, battery critical) at 11.8v and 11.6v for my tricopter. My range is set to 19.7 due to 6:1 multiplier to get an accurate readout on my transmitter of my battery's total voltage, due to scaling, warnings at 11.43 and 11.12.
Started flight with full battery, and I suppose I'm getting my warnings VERY early because I didn't account for battery being under load during flight. How do y'all adjust your settings to accommodate?
gibby mcfender is offline Find More Posts by gibby mcfender
Old Feb 25, 2015, 01:46 PM
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
It really does depend on Exactly which battery you use and what motors/props are on your copter and how you fly.
This is the same problem when setting up one of those simple LiPo alarms. At what Voltage per cell is best? 3.5, 3.4 or 3.3V per Cell.
You will need to experiment so that after landing the battery is at 3.7Volt per cell with No Load. This should be 80% discharged. However, you then need to verify the capacity returned to the battery by the charger.
Adjust Voltage warning levels and repeat.
This is different for different Brand and C ratings so you need to do this for each battery.
waltr is offline Find More Posts by waltr
Old Feb 25, 2015, 08:35 PM
Joined Sep 2013
Cool Thanks for the info!
Sold Quanum Low Voltage warning buzzer.telemetry low voltage vibration buzzer 318wagner Aircraft - Electric - Multirotor (FS/W) 0 Feb 12, 2015 10:48 AM
Sold two battery voltage tester low voltage buzzer alarm jenna Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 23, 2014 08:13 PM
Discussion To low voltage battery warning or not to low voltage warning...!! nesal Multirotor Talk 3 Sep 18, 2013 12:46 PM
Walkera TX batteries.... Low voltage warning at ?? volts? dacaur Micro Helis 0 Jun 15, 2005 08:30 PM
Question Help! Need a Low Voltage Warning for my 3 Cell Lipoly Batteries LittleJoey Batteries and Chargers 16 Dec 19, 2003 06:17 AM
