Old Feb 17, 2015, 07:22 AM
Joined Jan 2015
Can I setup my Taranis Plus to control a gimbal with the joysticks?
I'd like to be able to completely switch the control of the joysticks for a 3 axis gimbal on the same receiver with a flip of the switch. Is this possible?
MichaelFR85 is online now Find More Posts by MichaelFR85
Old Feb 17, 2015, 08:19 AM
Aaalie's Avatar
Netherlands
Joined May 2006
Yes, a Taranis can do this.
Aaalie is offline Find More Posts by Aaalie
Old Feb 17, 2015, 02:14 PM
Joined Jan 2015
Could I switch the stick assignments to takeover gimbal control while in the air and then switch back to regular control? How would it work specifically? How is it setup? Is there a video? Thank you!
Old Feb 17, 2015, 02:44 PM
Jubz's Avatar
United States, CA, Orange County
Joined May 2014
Hmm, been thinking about this and would be a little nervous with this type of setup. But I would think you can set up custom mixes to override a stick's pitch and roll via a switch, and control a gimbal's tilt and pan, all while the multirotor is in a stable GPS hold hover.
Another approach is to simply program the Taranis' side slide switches for tilt and pan on a gimbal.
I think a really tricked out mod would be to mount a small joystick controller (gamepad/PS2 size) onto the Taranis and tap into the circuitry of the rotary S1 and S2 switches. Now you have a dedicated gimbal controller.
Jubz is offline Find More Posts by Jubz
Old Feb 17, 2015, 02:59 PM
Joined Jan 2015
How would I setup a slide switch to pan smoothly and continuously on a 360 degree gimbal? Is that possible? Slide more for faster panning, less for slower panning? Slide past 50% to go in reverse?
Old Feb 17, 2015, 03:25 PM
Jubz's Avatar
Joined May 2014
You can, but the slide switch is overall quite limiting due to it's narrow travel and low resolution. You've got me motivated to explore this myself, and seeing if I can replace a slide switch with a small joystick to control a gimbal.
Info below on the joystick controller in my previous post; seems very doable.
"Standard interface and electronic building blocks 2.54mm pin interface leads; Cross rocker as a two-way 10K resistor, with the rocker in a different direction, tap the resistance with the change; 5V power supply"
Old Feb 17, 2015, 03:36 PM
Jubz's Avatar
Joined May 2014
OK, now going to make this happen. Just picked up a couple of these:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Now to figure out which circuits to tap into and how to mount the joystick onto a Taranis Plus.
Discussion "buddy box" joystick for gimbal control? Steve_in_NJ Aerial Photography 0 Jan 28, 2015 01:40 PM
Help! Can't get the phantom 2 gimbal tilt to work with Taranis Plus Austin42 Multirotor Electronics 1 Jan 09, 2015 02:24 PM
Help! helicopter setup with taranis plus on phoenix flight simulator Zartan Radios 0 Nov 10, 2014 09:49 PM
Discussion Can I control a WLtoys v959 with a frsky taranis and no module? groncho Mini Multirotors 2 Nov 21, 2013 04:29 PM
Discussion Tarot 2d Gimbal with joystick can it work? tir33x Multirotor Electronics 1 Nov 02, 2013 09:58 AM
