Old Nov 03, 2014, 10:20 AM
nniibb is offline
Find More Posts by nniibb
Joined Nov 2010
Ripmax dagger
Hi all,
Recently I discovered this racer in my shop of choice the following model:
Ripmax Dagger
https://www.rc-passion.ch/de/racers-...rtf-combo.html
it looks really hot and fast, has anyone already built and/or flown it?
I am considering to buy the combo version (which is the Ripmax suggested bundle). Any experience?
nib
nniibb is offline Find More Posts by nniibb
Old Nov 16, 2014, 02:52 PM
Juergen.J is offline
Find More Posts by Juergen.J
Austria
Joined Jan 2014
Hi nib,
last week I ordered one from Germany (guess it's a brand new wing here in Europe because there isn't any shop in Austria which has got this plane in stock).
The Dagger arrived on Friday - I had to finish another project first - but now I'll start to build this delta wing.
I'd like to fly this wing rather fast - the manufacterer recommends a 1250kV motor (35mm diameter, 151g) with a 7x7 prop on 4s (with a 60A SBEC).
Could anybody be so kind to recommend some motor/ESC combos!?
Juergen
Juergen.J is offline Find More Posts by Juergen.J
Old Nov 16, 2014, 05:48 PM
Artful Owl is online now
Find More Posts by Artful Owl
Artful Owl's Avatar
New Zealand, Canterbury, Christchurch
Joined Dec 2011
Juergen.J remember to take the c/g into concretion dose the manufacture recommend what size 4 cell to use.
Artful Owl is online now Find More Posts by Artful Owl
Old Nov 21, 2014, 02:46 PM
Austria
Joined Jan 2014
Wasn't a big deal to "build" this wing - I'm almost done; I'll try the Himax C3516-1350 motor (with a 3S lipo).
Juergen
Old Mar 15, 2015, 12:28 AM
The_RattleSnake is offline
Find More Posts by The_RattleSnake
The_RattleSnake's Avatar
Joined Jul 2007
Where did you end up setting the CG?
The_RattleSnake is offline Find More Posts by The_RattleSnake
Old Mar 20, 2015, 06:39 AM
Aussie64 is offline
Find More Posts by Aussie64
Germany
Joined Nov 2006
I have mine as per the manual, but not yet flown it. Weather is still too cold and wet.
Aussie64 is offline Find More Posts by Aussie64
Old Apr 11, 2015, 09:07 AM
Aussie64 is offline
Germany
Joined Nov 2006
Maiden flight yesterday. The CG was too far forward and the throws of the elevons must be set to a very low rate. I almost ran it into the ground as it headed straight downwards. I had to trim the elevator a good amount upwards and didn't go faster than half throttle as even 50% of throw with 60% expo was way too much. As there were too many people on the field yesterday, I had only this one flight. Hopefully there is more room and time to test tomorrow.
Old Oct 13, 2015, 06:58 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
I just picked up one of these secondhand without electrics.
Any chance anyone could advise the recommended cog and any photos of their setup?
I'm thinking a 35mm 1250kv on 4s.
Thanks for any advice
Goody63 is offline Find More Posts by Goody63
Old Oct 14, 2015, 03:46 AM
Aussie64 is offline
Germany
Joined Nov 2006
Goody,
somewhere I have read that 4s will make too many vibrations, but I don't remember where. I have a 1500kv motor on 3s, with a full battery it will draw nearly 50A and, honestly, it could be a little faster. Also, I have switched to a folding prop as I killed a standard one every second flight. I also found that it is best to set the elevator a little to the up side as I nearly smashed it in the ground on the first flight and had to trim quite a lot up. I then set the elevator to approximately 2mm and now it flies straight and level.
Old Oct 14, 2015, 05:42 PM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
Originally Posted by Aussie64 View Post
Goody,
Thanks for that info
What size motor and lipo are you using?
Cheers
Dave
Old Oct 14, 2015, 05:56 PM
Aussie64 is offline
Germany
Joined Nov 2006
I use an Emax GT2812 with 1550kv on a 3s2200. I still have a Turnigy D3536 with 1450kv which I will test some time. The Emax is quite loud, but so far I could not find to source to the sound. Might be some bad bearings or vibrations from the front of the fuselage.
Old Oct 15, 2015, 03:17 PM
Mike_eee is online now
Find More Posts by Mike_eee
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
where can I get this plane in US or shipped to US??
Mike_eee is online now Find More Posts by Mike_eee
Old Oct 16, 2015, 12:47 AM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
Thanks mate!
Old Feb 11, 2016, 02:22 AM
Jedimaster1965 is offline
Find More Posts by Jedimaster1965
Funjets, Dagger, Me163 & Spit
Jedimaster1965's Avatar
United Kingdom, England, Nantwich
Joined Mar 2006
Hi guys, sorry to revive this thread but was reading your experiences with interest.
I built my Ripmax Dagger last year but it has yet to fly:
Here is optional Ripmax prop driver (essential to avoid vibrations!)
I had issues with my club flying field and we are moving to a new site very soon.
Mine hass the stock Quantum motor set up but installation was a bitch, I tell you, - there is so little room!
I will take the advice about adding some up on the elevons. Cheers.
Jedimaster1965 is offline Find More Posts by Jedimaster1965
Old Feb 11, 2016, 02:51 AM
Joined Mar 2006
Goody,
Guys: THESE two publications are a must-have read for those building a Ripmax Dagger and mention the vibration issues plus full build and flight-testing reviews:
(RCMW January 2015)
Grab a back issue now!
For Sale Ripmax 16A ESC ehelibuff Aircraft - Electric - Power Systems (FS/W) 0 Sep 30, 2014 01:28 PM
Help! Ripmax pro-peak 13.8v 20 amp dual output power supply won't turn on Cardinal RC DIY Electronics 1 Sep 28, 2014 11:57 AM
Discussion Plan & instructions needed for a Delta Dagger kit. ironmonger Fuel Plane Talk 0 Jun 01, 2014 07:24 PM
Discussion TAMIYA WILD DAGGER help garysnooker Electric Power Cars 1 May 30, 2014 06:06 AM
