Old Nov 05, 2015, 10:19 AM
Richardjb is offline
Find More Posts by Richardjb
Richard Brown
Richardjb's Avatar
United Kingdom, Morley
Joined Aug 2014
Maidened at last.
the weather was rubbish, drizzly, misty and very damp.
But the Kappa 35 was not a disappointment, even in these conditions it floated around with a very low sink rate. it seems to have a good speed range and the flaps very effective with a good climb rate under power, getting to 150 meters in less than 20 seconds.
need to sort out some minor trim settings in the different flight modes but could not be happier.
Richardjb is offline Find More Posts by Richardjb
Old Nov 10, 2015, 09:36 PM
ReidRoberts is offline
Find More Posts by ReidRoberts
ReidRoberts's Avatar
United States, CO, Perry Park
Joined Apr 2006
Congratulations on the maiden flight! Sunny Morley has another great flying machine!
ReidRoberts is offline Find More Posts by ReidRoberts
Old Nov 20, 2015, 06:23 AM
dutchsoarer is offline
Find More Posts by dutchsoarer
Joined Oct 2006
my build
Hello,
I didn't use the ply for servomount in de fuse. In the pictures my build with the abillity to add 260 gr ballast.
Pretty standard. Motor is a Mega 16/25/4CE, hyper spinner with Ae 10*7 and a thin esc. Battery is SLS 1000 with 19 mm. So it is possible to place the battery and esc behind the motor where the fuse is 38mm thick. Ad canopy it is smaller!
The servoplate is demountable with 4 screws in case you have to service motor or esc (antenna's in silicone fixed with hotglue)
Flying weight 1330 gr, carbon D-box.
Not much flown yet. But already placed the cg further back now on 98 mm.
Structure is strong enough to carry more weight. Surprised by its abillity to make distance.
Not happy with the weight of the (small) stab with 51 gr and the small rudder.
Hope it gives you some ideas.
Johnny
dutchsoarer is offline Find More Posts by dutchsoarer
Old Feb 18, 2016, 11:03 AM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
The aileron and flap linkage pins have come loose on some customers models, see:
Please see http://www.rcgroups.com/forums/showthread.php?t=2606123
I recommend everyone checks the linkages on their models.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Feb 28, 2016, 08:19 AM
Richard Brown
Richardjb's Avatar
Joined Aug 2014
I checked mine during the build, and used a very small dab of cyno on one end of the pins, only needed to do the ailerons as the flap pins were pretty tight.
Not had chance to fly the Kappa for a few weeks but finally got a few flights in, moved the C of G back, ( haven't messured it yet) and comparing it to the Multiplex Herron , well there's no contest the Kappa is a great soaring machine. The control authority is not as sharp as the Heron so it more of a handful in terbulance but it works the weak Febuary thermals like a star.
Old Mar 12, 2016, 12:56 PM
Richard Brown
Richardjb's Avatar
Joined Aug 2014
A few details about my Kappa 35.
Weights with everything installed ready to fly
Fuselage 541g
Wing joiners 15g
Centre section 404g
Left wing tip 167g
Right wing tip 172g
Battery 111g
Airframe weight 1299g
Flying weight 1410g
Servos MKS 6100 all round with 2amp sbec on each.
Motor 1025 Powerline
18x6 prop
Castle Creation 75 amp ESC
Battery Overlander 1350mha 45C
Receiver Jeti R9 EX
Aerob Tec Altis4+
Climb to 150 metres 15 seconds
Thermal performance, outstanding.
Crow for landing and descent from height very affective.
Old Mar 12, 2016, 02:32 PM
HyperFlight Support
Joined Feb 2001
I am glad you are happy with the model Richard.
Do you mean a 16x8 prop?
Neil.
Old Mar 13, 2016, 06:02 AM
Richard Brown
Richardjb's Avatar
Joined Aug 2014
Thanks Neil, you are right it should read 16x8.
Thanks too for the excellent help and service, I will be back for more.
Richard
Old Apr 12, 2016, 03:30 AM
rdakin is offline
Find More Posts by rdakin
Joined Apr 2016
Very pleased with my new Kappa35 full cabon F5J glider.
Setup are:
6 x MKS-HV6100
Leomotion L3013-6000
38 mm Hyperspinner
GM 14x7 folding prop
Castle Phoenix Edge Lite 100
3S 1300 mh LIPO
Only problem is to get CG right, the Lipo have to stay in front, behind the motor. Thats means that I canīt get the Lipo out, the ESC are to big.
Other option is to place the ESC behind the motor, then itīs easy to get the Lipo in and out, but then the CG are to aft.
rdakin is offline Find More Posts by rdakin
Old Apr 12, 2016, 07:17 AM
VHO is online now
VHO
Find More Posts by VHO
VHO
glider misguider
Armidale NSW Australia
Joined Feb 2007
Setup are:
6 x MKS-HV6100
38 mm Hyperspinner
3S 1300 mh LIPO
Try a smaller prop, battery and ESC. I routinely use 850mAh 3s and 70A Jeti SB ESC on a Mega 16/15/2 and 5.2:1 Kontronics Gearbox motor. Gives 2 -3 launches without problems. I use a 13x8" prop on that. I see the Hyperflight page for that motor says 13x8 will provide 69A ~690W. That's more than enough (hint - understatement) power for a light F5J plane.
VHO is online now Find More Posts by VHO
Old Apr 12, 2016, 07:37 AM
rdakin is offline
Joined Apr 2016
I know what you saying, only climbing on 50% power, 100% to wild, climb as a rocket then
Old Apr 12, 2016, 08:46 AM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
That's further proof that you have an over sized power system on a model that ishould intended to be a very light weight floater.
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Apr 12, 2016, 12:32 PM
Bmwjoon is offline
Find More Posts by Bmwjoon
United States, NJ, Nutley
Joined Mar 2015
Setup are:
6 x MKS-HV6100
38 mm Hyperspinner
3S 1300 mh LIPO
This is a pretty hardcore setup This probably hauls. I would put something much lighter in there myself, would be a better match to the airframe.
Bmwjoon is offline Find More Posts by Bmwjoon
Old Apr 13, 2016, 06:41 AM
Richard Brown
Richardjb's Avatar
Joined Aug 2014
my Kappa 35 weighs in at a little under 1400g
using the Powerline 1025 motor with a 16x8 prop and 1300mha battery it can climb to 200 metres in 18 to 20 seconds without any problem.
Old Apr 13, 2016, 08:42 AM
Lenny970 is offline
Lenny970's Avatar
Joined Feb 2000
And mine was under 1200g (42oz) using a NEU 707 motor and lightweight components.
Climb rate was about the same -- 10 meters/sec.
Lenny
Sold Estes Proto X Nano RTF $ 35 Shipped! palomo Aircraft - Electric - Multirotor (FS/W) 0 Nov 12, 2013 12:32 AM
Sold H9 35% Extra 260 RTF, just add batteries- Sarasota, Fl area invertmast Aircraft - Fuel - Airplanes (FS/W) 0 Sep 26, 2013 11:41 PM
For Sale Power package for 30oz to 45oz 3D plane sgomes Aircraft - Electric - Power Systems (FS/W) 2 Mar 17, 2012 05:02 PM
Discussion A123 setup for 38-45oz 3d airplanes. akschu Batteries and Chargers 13 Jun 03, 2009 10:06 PM
Motor/battery suggestions for EPP Turbo Porter 60" wingspan / 45oz. AUW surfimp Power Systems 14 Jan 27, 2004 11:14 PM
