Old Feb 10, 2016, 07:38 PM
bafbob is offline
Find More Posts by bafbob
bafbob's Avatar
United States, VT, Brattleboro
Joined Aug 2012
Powerline gear resistance
I have been flying a PL 1025 for a season with about 100 flights on it and I have noticed a freewheeling spin to the prop when I give it a twirl with my fingers (power off!). I don't detect much - if any - resistance fro the motor/gearbox. Does anyone have this experience?
bafbob is offline Find More Posts by bafbob
Old Feb 10, 2016, 09:29 PM
Westranm is offline
Find More Posts by Westranm
Westranm's Avatar
United States, AZ, Chandler
Joined Jan 2011
I have the same experience. Runs smoothly and brakes with no issues, too.
Westranm is offline Find More Posts by Westranm
Old Feb 10, 2016, 09:30 PM
Rudix is online now
Find More Posts by Rudix
Rudix's Avatar
South Africa, GP, Pretoria
Joined May 2013
My motors spin quite freely, without the ESC brake engaged the prop will continue to freewheel after shutting the motor down.
I assume your motor is still running as it should?
My 1025 with the most flights on it, around 150 launches (most of them below 100m and many only up to about 30m for landing practice), is the one in my Supra, I cannot say I have detected and changes in the motor or gearbox when I turn it by hand.
Rudi
Rudix is online now Find More Posts by Rudix
Old Feb 11, 2016, 12:25 AM
arno888 is online now
Find More Posts by arno888
arno888's Avatar
Germany, NRW, Selfkant
Joined Oct 2005
my 1025 has 1000 + flights and is still spinning like the new version
It was sent to Schambeck for maintenance and came back without remarks .....
arno888 is online now Find More Posts by arno888
Old Feb 11, 2016, 07:35 AM
Jebera is online now
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
Several aspects influence on the "free and smooth" spining, gear ratio, ammount of grease, lubricant viscosity, temperature and motor magnets strength to mention a few.
Keep the gearbox clean and freshly lubricated and it will go for several years.
André
Jebera is online now Find More Posts by Jebera
Old Feb 11, 2016, 10:25 AM
arno888's Avatar
Joined Oct 2005
André
As said; i had 1000+ flights with this engine and used the parts as delivered.
Old Feb 11, 2016, 06:05 PM
zephirus is offline
Find More Posts by zephirus
Scott J.
zephirus's Avatar
United States, NC, Wake Forest
Joined Jan 2013
Hi Arno had you taken the gearbox apart and lubricated it or was the trip to the manufacturer the only maintenance done?
Scott
zephirus is offline Find More Posts by zephirus
Old Feb 12, 2016, 01:26 AM
arno888's Avatar
Joined Oct 2005
Scott
It was sent back to Schambeck for maintenance as required/asked for in the set's manual . I have not taken apart anything ! (never)
First service on the set is free of charge, you only have to pay for the postal costs.
Old Feb 12, 2016, 08:15 AM
zephirus is offline
Scott J.
zephirus's Avatar
Joined Jan 2013
Thanks Arno !
Old Feb 13, 2016, 06:42 AM
arno888's Avatar
Joined Oct 2005
Despite all the tribute being payed to this sweet little toy I do have to make some remarks. The 1025 is developed to be used in F5J and not for endless long runs on full power.
The maximum power output, I measured on my 1025 is 55 A max. on a 1000mah 3s lipo and I can assure you that after 10 seconds, the engine is pretty hot, and for sure the temperature will be close to 80 centigrades after 30 secs. For this reason Schambeck says in the manual, as not to use lipo’s exceeding 1300 Mah capacity. The voltage drop, on the bigger lipo’s, is less thus allowing the motor to run longer on higher Amps. And exceeding this 80 degree border is a bad thing, as from this temp onwards, the magnetic properties of your engine start to decrease rapidly. Thus reducing the effectiveness of the unit.
So I think you have to be quite careful, running this engine on full bore, but then on the other hand when flying F5J you don’t have to worry that much. My 1550 grams Xplorer climbs on full power with 11-12 m/sec. And you don’t want to start your F5J flight at 300 meters +
I now from some heavier planes (22-2300 grams) that on full power they easily reach 230-250 meters within 30 seconds so the power available is sufficient. Just be careful as to not overheat this little baby. For that reason also consecutive runs should be avoided or minimized and in case you do have your doubts; current RC equipment does allow quite often for temp measurements.
As said before, I do fly F5J and had 1000+ flights in the last 12 months or so. I do fly on 800 and 1000 Mah, 3s lipo’s. My estimated power consumption was such that approx. 60% of the time the engine was running on 35% of the max power (17 Amps giving 5m/sec climb), 30% of the time it was running on 10% power (searching for thermals giving an actual 0m/sec climb) and 10% was on full power.
My unit was like new after flying for hours and hours and hours
Old Feb 13, 2016, 09:31 AM
Jebera's Avatar
Joined Oct 2006
Goo d statement!
Thank You!
Old Feb 13, 2016, 10:50 PM
fwroberts is offline
Find More Posts by fwroberts
Rick Roberts
fwroberts's Avatar
United States, MA, Montague
Joined Aug 2012
Thank you Arno. I'm just now fitting the 1025 into a Supra-e and will use a 1200ma lipo.
Do you have air vents for cooling the motor? The Supra-e pod has notches in the nose...you just have to drill the holes to let air into the pod near the motor. Just wondering if it's necessary?
Rick
fwroberts is offline Find More Posts by fwroberts
Old Feb 14, 2016, 01:44 AM
arno888's Avatar
Joined Oct 2005
Rick
I use no extra holes in the fuse to cool the motor. Fresh air comes in via the turbo spinner and some openings in the firewall.
Please check out this one :http://www.rcgroups.com/forums/showt...3#post33624138
Old Feb 28, 2016, 10:31 PM
bafbob is offline
bafbob's Avatar
Joined Aug 2012
Voltage Drop
I notice on static runs with my 1025, .850 mah C70 lipo, my voltage drops from 12.5V to about 9 volts in the start of the motor run (first 10 seconds of 30 seconds) and if all is not perfect, this triggers a cut off. I had to lower the cut-off voltage to around 9 volts to keep it running. Voltage jumps back after run.
Full disclosure: I am running a Spin 44 ESC which has no "extra headroom" but looks adequate on paper and fits nicely. Is there a safe limit to how much I can lower the cut-off number? I also have a BUG backup.
Here's how ECalc looks.
Old Feb 28, 2016, 10:47 PM
Westranm is offline
Westranm's Avatar
Joined Jan 2011
I wouldn't lower the cut off voltage but determine why the voltage is drooping below 10 volts. I haven't static tested mine in a while, but I don't fly batteries that droop below 10 volts in a 30 second run in flight...that is generally an indicator that my battery is going bad.
BTW, if you are testing your batteries at low temperatures, that could be a source of the voltage drop. I would also recommend more than a 40 Amp ESC ...that is just cutting it too close in my book.
-Randy
Discussion ALES, F5J and F5J Lite dharban Electric Competition Soaring-F5J/ALES/e-Soaring 165 Jan 08, 2016 12:28 PM
Sold Kontronik Geared - F5J LMR/ALES motor Kholder116 Aircraft - Electric - Power Systems (FS/W) 3 Mar 03, 2014 08:11 PM
Build Log Supra f5j paxjohn Electric Sailplanes 1 Jan 15, 2013 08:05 AM
Discussion F5J Inter Tour 2012 - Ricardo Lima F5J pguim Electric Sailplanes 1 Mar 28, 2012 10:23 AM
Discussion etti out runner 380 or tenshock 1025-13 taffy047 Racing Boats - Electric 6 May 22, 2010 08:04 AM
