Old Nov 04, 2011, 05:36 AM
lipoflyer's Avatar
Australia
Joined Nov 2010
HobbyKing Mercury Alloy 64mm 4700KV EDF Unit
These have just appeared on the HK website and they look interesting. I wonder if they are going to quieter. From the looks of it they push although i cant be sure. With any luck we might see a 90mm fan.
In conventional ducted fan design, the motor is secured to the stator hub while the fan secured to the motor shaft. During operation, any imperfection in either the motor or fan will cause both the fan and motor to vibrate at a certain resonance frequency. The oscillation can cause the blade tip to rub against the shroud of the duct. Moto-turbine’s 3-bearing system reduces resonance vibration by 90%.
Motor: 2430-4700kv High Performance EDF Brushless
EDF Unit: 64mm
Battery: 7.4v ~ 14.8v (2s ~ 4s Max)
AMP Draw: 76 amp (Max)
Watts: 1140 watts (Max)
Thrust: 1600g
ESC: 40A~80A
Unit Weight: 162g
Test Data:
11.6v (3s) 2600mah / 54amp / 626watt / 1040g Thrust
12.0v (3s) 5200mah / 57amp / 684watt / 1100g Thrust
14.6v (4s) 2600mah / 73amp / 1066watt / 1550g Thrust
15.0v (4s) 5200mah / 76amp / 1140watt / 1600g Thrust
http://www.hobbyking.com/hobbyking/s...it_2s_4s_.html
This one does 5s
http://www.hobbyking.com/hobbyking/s...it_3s_5s_.html
The do look nice though.
lipoflyer is offline Find More Posts by lipoflyer
Old Nov 04, 2011, 09:28 AM
Toof-fairy
osmium_192's Avatar
Perth, Australia
Joined Sep 2005
Is it suggesting that it has bearings on both ends? - edit - yes it does, theres a bearing in the tail cone section too.
Even has 4 blades within the motor tube to help pull air through the motor nice..
osmium_192 is offline Find More Posts by osmium_192
Old Nov 04, 2011, 09:48 AM
Joined Nov 2005
Another interesting design feature of this this is the stators in the front and back of the fan.
It gets 4lbs of thrust on 5s, not bad....
erh7771 is offline Find More Posts by erh7771
Old Nov 04, 2011, 10:29 AM
Si Goodchild's Avatar
Lincolnshire, UK
Joined Oct 2009
oooo - nice. Could be a real competitor for the lander units if they produce 70mm units and up. Imagine that sort of technology in an 80mm unit running 12s at a modest current - HABU 32 anyone?
Si Goodchild is offline Find More Posts by Si Goodchild
Old Nov 04, 2011, 10:34 AM
Joined Sep 2008
Are they not similar?
http://www.hobbyking.com/hobbyking/s...dproduct=15171
I was eyeing this back ordered item when I noticed the new mercury allow 64mm edf. Other than the colour, the described features are similar? But check the difference in price? 36% premium for that gun metal look?
Ok the mercury will go 5s, and it has a higher thrust? Err 36% premium?
A second point is the front stator doesn't seem to guide airflow onto the foils. Looks more like spar support than functional stators to me.
remauled is offline Find More Posts by remauled
Old Nov 04, 2011, 01:55 PM
Joined Oct 2010
It seems to be from epf hobbies:
http://epf.com.tw/goods.php?id=125
They dont have a 70 and 90mm (yet).
So i gues hk wont get it (soon).
mathijs727 is offline Find More Posts by mathijs727
Old Nov 04, 2011, 04:54 PM
You win again gravity!
SMorrisRC's Avatar
UK
Joined Jan 2010
90mm is to be released this month.
The mercury is more powerful than its predecessor, and has a metal tailcone, the old one was plastic. Also, looks like way more machining in the blades as they're much more complex shape. That's the $30 premium right there.
SMorrisRC is offline Find More Posts by SMorrisRC
Old Nov 04, 2011, 04:58 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
this is the EPF Hobby fan that's over on the foamie thread. good to see HK finally got a hold of it. the reason it costs more is because it's metal, not plastic. the whole thing is metal, including the rotor, from what I remember on that thread. there's video of it flying on that thread, if you wanna hear what it sounds like.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 04, 2011, 05:57 PM
SMorrisRC's Avatar
UK
Joined Jan 2010
The previous one also had a metal rotor.
Old Nov 05, 2011, 01:01 PM
USA, AZ, Buckeye
Joined Feb 2010
Check out the HK main page...there is a product video on this EDF.
HobbyKing Daily - Mercury Alloy EDF Unit (1 min 30 sec)
mray is offline Find More Posts by mray
Old Nov 10, 2011, 03:40 AM
hommel's Avatar
Netherlands, Zwolle
Joined Jul 2005
Exciting times to be in small (64-70mm) EDF these days... With the 10 blade CS fan and this one as well.
I'm somewhat surprised though that this fan doesn't get as much attention as I would expect. This seem to be a well-made and balanced unit that puts out impressive numbers.
A 64mm unit that puts out 1,5 kg at reasonable efficiency (i.e. more than 1,2 g/W) should open the door for scale sized inlets/outlet on lets say a 1,2m Panther as long as you keep weight down to 1,5-2kg. Or am I missing something.
Anyone has some real-life experience with this one?
What about the sound of this 8-blade rotor?
hommel is offline Find More Posts by hommel
Old Nov 10, 2011, 05:23 AM
SMorrisRC's Avatar
UK
Joined Jan 2010
I think they're great. I had a couple of the previous mototurbines and these are even better. Truly beautifully machined blades, and perfect balance. And at HK prices, a hell of a lot of fan for the money!
Old Nov 10, 2011, 09:35 AM
USA, AZ, Buckeye
Joined Feb 2010
I have two of them on their way to me now. Will post info/vid's as soon as I get them.
Old Nov 10, 2011, 09:46 AM
hommel's Avatar
Netherlands, Zwolle
Joined Jul 2005
Would love to hear this thing run at half and full throttle... EPF's own Youtube contributions aren't that clear. At least I didn't hear the typical high pitched edf wyning, but not sure if it is as whooshy as the CS10-70mm.
Old Nov 10, 2011, 04:07 PM
Joined Jan 2009
according to EPF, the 90mm version should be out in a month and the 70mm will be out in January.
Sold Hobby Lobby 64mm EDF Unit & Motor chip.greely Aircraft - Electric - Jets (FS/W) 2 Sep 12, 2011 07:20 PM
Video Hobbyking T-45 64mm EDF Jet PiP Movie Anda Inc. Electric Plane Talk 0 Sep 05, 2011 02:09 PM
Help! 64mm to 68mm EDF Unit with no motor? soundguy63 Electric Ducted Fan Jet Talk 3 Jul 19, 2011 02:04 PM
Sold 64mm edf unit plus motor Doushiyou12 Aircraft - Electric - Power Systems (FS/W) 1 Mar 24, 2011 11:31 PM
Sold Global Fly/ Sapac 64mm EDF unit w/ black tornado 4800kv 4s SkylineFlyer Aircraft - Electric - Power Systems (FS/W) 8 Mar 12, 2011 07:52 PM
