Old Jun 08, 2015, 10:15 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Goldwing 26cc Extra 260 Build
After wrecking my GW Yak I purchased this Is Extra 260 from General Hobby.
I bought it on sale for 199 dollars. I fell in love with it the moment I saw her
They shipped it right away and she arrived on good shape.
I am putting a DLE 20 on her.
kerwin50 is offline Find More Posts by kerwin50
Old Jun 08, 2015, 10:17 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
This is a very light weight airframe. Perfect for the DLE 20
Old Jun 08, 2015, 10:25 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I really like the motor box
Old Jun 08, 2015, 10:27 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
It should be more than strong enough to support the DLE
Old Jun 08, 2015, 10:39 AM
Kerwin49 is offline
Find More Posts by Kerwin49
Unregistered User
Kerwin49's Avatar
United States, MO, Cameron
Joined Jan 2011
Looks good K50!
Kerwin49 is offline Find More Posts by Kerwin49
Old Jun 08, 2015, 11:17 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Tonight I fuel proofed the fuse. While examining the tank area. I notice the landing gear tri stock was not tight up next to the fuse. So I removed it and replied it.
I realize this is a 199 dollar 120 size plane. So a little extra work here and glue there is worth it.
I've used Dubro hardware from way back when I was building kits.
Old Jun 08, 2015, 11:25 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
This airframe is built light. I think the DLE 20 is going to be a perfect fit
Old Jun 09, 2015, 08:54 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I cut a hole in the firewall to accommodate the DLE 20's carb. I also pinned the firewall as well.
Old Jun 09, 2015, 08:56 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I couldn't resist putting her together again
Old Jun 10, 2015, 09:12 PM
plowboy1966 is offline
Find More Posts by plowboy1966
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
Looks good Kerwin!
plowboy1966 is offline Find More Posts by plowboy1966
Old Jun 11, 2015, 01:54 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I installed the stabs I used ca because I want to keep the weight down.
I removed the covering in the center and installed the horizontal stab. I applied ca down the slot for the rudder. I then installed the vertical stab
Old Jun 11, 2015, 02:03 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I installed the DuBro hinges on the elevator. But overnight the right elevator hinges became missed aligned. I had to cut it off. And cut the hinges out. With the slots now being in larged I put a piece of 1/16th ply in the hinge slots
Old Jun 12, 2015, 11:36 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I love it when a plan comes together. I got the elevators installed and working perfect.
I put a Robart barbed hinge on the top of the rudder and a Dubro pinned hinge on the bottom of the rudder. These hinges will help carry the load. I am also going to put in the ca hinges as well.
Old Jun 12, 2015, 01:00 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I started the landing gear mod. I made a template from the rear landing gear former. Then I cut a piece of 1/16 ply using it.
I sandwiched light fiberglass cloth between the two.
Old Jun 12, 2015, 03:08 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I installed the landing gear and wheels in preparing for balance.
I used a servo arm for my choke lever. I had already had my choke set up from the previous Yak.
I weighed the wheels as they felt really light. Forty five grams
They are over an ounce lighter than the Goldwing 30cc MX's wheels
Wanted Cowl for 26cc Sukhoi/Yak (goldwing or skylinerc) bobzilla Aircraft - Fuel - Airplanes (FS/W) 5 Jun 04, 2015 09:58 PM
For Sale Extra 260 26CC 70in richyan Aircraft - Fuel - Airplanes (FS/W) 0 Aug 26, 2014 07:30 AM
Wanted goldwing extra 260 parts rcrick10 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 24, 2014 05:33 PM
Sold Goldwing Extra 260 50cc AZcrashpro Aircraft - Fuel - Airplanes (FS/W) 3 Feb 20, 2013 05:38 AM
