Old Jul 11, 2015, 10:02 AM
ruff1 is offline
Find More Posts by ruff1
A Day @ a Time - Matt. 6:25-34
ruff1's Avatar
North AL, USA
Joined Nov 2009
Starting the fuselage station panels, it is getting easier...
ruff1 is offline Find More Posts by ruff1
Old Jul 23, 2015, 08:49 PM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Rear panels glued in, tail cone under horizontal stabilizer shaping in progress. Just glued on the panel over the wing box.
She's coming along nicely.
I wish I could get my hands on some more of the yellow 1 inch foam board; it shapes and sands very well. I used that on the tail cone and engine nacelles.
Old Jul 24, 2015, 05:21 AM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Looking Great Kev! Your 404's tail section is really shaping up nice!
demondriver is online now Find More Posts by demondriver
Old Jul 24, 2015, 05:59 AM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Couldn't wait to check the panel glued in over the wing box; it came out really nice and the edge of the panel lines right up with the wing box. There won't be a lot of work to get this area smoothed up.
I decided to put her on the scale this morning. All up weight is 4.076 pounds! That includes two 2200 mah 3S batteries to simulate the new battery I'll have (hope it is a bit less).
I believe it is realistic to estimate weight at 4.5 pounds all finished. That puts me in the 65 watts/pound range (motors/props came in at 150 watts each @ 16 amps). That should make for some great scale performance. The wing cubic loading comes in at 13.4 (442.25 sq. in. wing area / 72 oz. weight). That is on the high side of scale, so hopefully wing thickness will give me some additional lift (it is 1.3 inches thick at the side of the fuselage).
On to the front end of the fuselage... need to be thinking about battery venting, I have some ideas. I think the power draw will be modest, so hopefully not a lot of heat buildup.
Old Jul 27, 2015, 08:48 PM
MD_Mogge is online now
Find More Posts by MD_Mogge
MD_Mogge's Avatar
Joined Jul 2015
Hi! Good looking build.
MD_Mogge is online now Find More Posts by MD_Mogge
Old Jul 28, 2015, 05:54 AM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
Thank you sir... All fuselage panels are now attached, need to work on the cockpit and tail cone areas. I'll try to get a picture uploaded later.
Old Jul 29, 2015, 12:52 AM
Up-Out-&-Gone
Joined Mar 2007
Sounds great Kev! You keep this steady pace and you should have a maiden by September.
Old Jul 29, 2015, 05:25 AM
ruff1 is offline
ruff1's Avatar
North AL, USA
Joined Nov 2009
That's the idea; to be done:
- Finish sanding cockpit area and glue it on
- Attach hstab
- Sort out nose gear; strut is too long, I may need to fabricate my own
- Finish shaping nacelles and attach
- Install arming plug
- Create tail cone under hstab
- Final sanding and attaching control surfaces, connect push rods
- Figure battery placement (cog 25% back from leading edge just to be safe) and create battery box, hopefully right over wing box
Old Jul 29, 2015, 10:34 AM
Up-Out-&-Gone
Joined Mar 2007
- Attach hstab
It might seem like a long list Sit but one item a week and your finished in 6-7 weeks.
Not bad at all!
Idea I'm Considering a Martin 4-0-4... ruff1 RC Airliners (Commercial, Cargo, Troop Carrier) 62 Dec 20, 2012 09:56 PM
Sold Sig 1/4 scale Spacewalker,Pica 1/6 scale Spitfire joedoan Aircraft - Fuel - Airplanes (FS/W) 2 Jun 02, 2012 11:45 PM
Sold 1/4 scale 4 1/4" inflatable cub tires lla Aircraft - General - Miscellaneous (FS/W) 0 May 28, 2012 10:55 AM
Build Log L-19 1/4 Scale Vailly Aviation Build Greggo Scale Fuel Planes 5 Dec 02, 2011 08:55 AM
Sold 1/4-Scale Fairchild PT-19 DanSavage Aircraft - Fuel - Airplanes (FS/W) 1 Aug 13, 2007 01:40 PM
