Old Yesterday, 05:47 PM
Montrose CO
not2fast's Avatar
United States, CO, Montrose
Joined Apr 2012
Originally Posted by gabe221 View Post
Not sure what your looking for, but several have them on their blogs. Motors from .10-.46 size.
I'm about to put the two halves together and would like to see some pictures of equipment placement. This thread is so long it's almost impossible to find anything. And search is pretty unhelpful. I think it was called "Performance mods for Fun Cub or something like that.
not2fast is offline Find More Posts by not2fast
Old Yesterday, 06:24 PM
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
There is really no need to install any electronics before joining the halves... the manual has you install the elevator and rudder servo, but that's really just to simplify fishing the wires. Since you have to be able to get to everything after the plane is done, everything can be installed afterward.....
dacaur is online now Find More Posts by dacaur
Old Today, 06:59 AM
oceanway99's Avatar
United States, FL, Jacksonville
Joined Feb 2012
did you leave it stock or have you added a sub floor or MM stiffener? Depends on how it's configured...
oceanway99 is offline Find More Posts by oceanway99
Latest blog entry: Mancave
Old Today, 09:10 AM
Montrose CO
not2fast's Avatar
Joined Apr 2012
This is how I arranged the parts. The BEC is in a section of the tail that is unused . If it is necessary to remove the BEC the wall the wires go through can easily be cut out but the BEC is one of those devises that just mostly get in the way. There are ventilation holes in the webs to keep it cool.
Old Today, 10:33 AM
Recce's Avatar
Estonia, Harju, Tallinn
Joined Aug 2012
One more picture about my tailwheel installation in addition to those posted on page 1488.
At first I fixed the wire to the plastic part with a drop of cyano. Then I covered the wire with baking soda and flooded with cyano. it should make for a stronger joint.
Recce is offline Find More Posts by Recce
Old Today, 10:45 AM
Tree hopper
gabe221's Avatar
United States, TN, Dresden
Joined Sep 2013
You still have room under the tray, why not put it under there?
@ Recce
Looks like you might have fixed your problem, but if it don't hold, you can replace the tailwheel assembly completely .
gabe221 is offline Find More Posts by gabe221
Latest blog entry: Titan from CTH
Old Today, 02:15 PM
Rather be flying
tsudduth's Avatar
United States, TX, Midland
Joined Feb 2009
Originally Posted by rpmrpm View Post
Quick, easy and cheap GoPro/camera mount, using the wing bolts and placing the pad so camera mass is on CG.
Just wondering how your FC flew with that mount. I mounted my Gopro in a similar fashion and it did not flew very well. It immediatly began to yaw as if the vert. stab had been blanked out by the camera. Was not at all happy with the flight. Now my FC is an older model with a smaller vert. stabilizer. Also had it mounted further back towards the trailing edge and moved the battery forward to compensate.
tsudduth is online now Find More Posts by tsudduth
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
