Old Feb 11, 2015, 05:43 AM
contact303 is offline
Find More Posts by contact303
Joined Mar 2005
Mini-Review
BocamTR-1 All in One VTX, DVRRecorder and Cam
http://www.foxtechfpv.com/boscam-tr1...er-p-1489.html
I have been looking to get myself a DVR recorder to record low-fi fpv videos from the ground without having to carry a mobius on board ever time i want to record something .
Well, whilst looking i got distracted and ended up with the All-in-one TR-1 from boscam .
It is a DVR but unlike others it comes complete with VTX 200mw and Camera
A all in one solution with 8 Ch on the 5.8=Ghz band .
The Boscam Camera&Transmitter is for aerial FPV, like as DJI phantom etc. small multicopter.
Features:
200mW transmitting power
About 600 meter image range at open field
All-aluminium case
Small size(36*18*43mm),light weight
Delivery 10 days from Asia to NLD TY Foxtechfpv ! Great !
First impression: A solid alloy Box construction . Looks indeed very sturdy and definitely can take a bash or 2 .
Second look , Why is the case the wrong way around ?
Looking at the shape and dimensions I don't really understand why the antenna connector is on the side .
It would indeed be much better on the other, long side of the case .
Also the height is slightly too tall . F#$%@ This will not fit in my mini frame?!
but of course this is my fault So remember, kids Read Description careful before you buy !
So after some more fitting rages, I have decided to mount the TR1 on the outside up front on my HEX frame.
This way I can connect an extension to the Antenna socket and move the antenna further back on the frame.
The form factor just isn't perfect for a Mini.
The TR1 will be much better suited for a larger project, like an fpv plane or wing . On bigger model's mounting the unit would be much easier , I am sure the TR1 would also it nicely on a gimbal .
Once installed we can see the weight saving are not massive but on the other hand wire mess has been removed quite considerably
The connector has only VCC and GND . but a DIY solution Is easy made and the other pins can be used . Connect your OSD in line and it will record
Finally, the installation done .
Now lets have a look at the Camera functions .
First thing I did notice when unpacking .The TR1 has no buttons.
It has instead one single slider . On or Off Recording
On the back we have the typical dip switch arrangement .
The Boscam TR1 supports 8 ch. 5645 - 5945Mhz.
As said no buttons but one slider , so when you want the recording to start just slide the button to the side and the recording starts immediately .
Another important thing to remember O not disconnect the power when you are recording
Always first stop recording by moving the slider to the OFF position, then disconnect the power(Lipo)
The TR1 does need a second to write to memory so a sudden power loss equals video loss. Be careful.
There are no indications, no blinking LED or otherwise to let you know it actually is working . Not a bit deal because we have a sliding button that is pointing to On or off
To stop the recording simply slide the button to the OFF position.
Recording format : MJPEG , Yes the ugly and somewhat disliked format
Nevertheless , the resolution is 1440x 1080.
The recording has no OSD overlay because i didn't hook it up .
Rest assures it works, I had it on the bench
Just add VID to the plug and insert
It record the osd overlay just fine .
But I was more interested in the actual quality of the recording
The uploaded clip is unchanged ...I uploaded 'as is' and I have to say the youtube rendering is pretty close .
Its not as clear/sharp as a Mobius or GoPro recording
but its definitely not a bad picture .It handled fast changes in scenery very well. I was impressed , it doesn't appear to go too dark at all.
The Sun really is low and I was almost expecting more sun blurr but it held up well .
00050008 RAW REC - BOSCAM TR-1 Test (3 min 3 sec)
So then the one and only real Issue I have is the missing user interface/osd ?
Why cant i adjust the picture ?
There are no settings you can change . No contrast, saturation, brightness ...nothing?
It makes no sense. I cannot even rotate the picture which would really help in placing the unit ...
BOSCAM what are u doing ?
Why oh Why does it have no OSD ? An OSD with software functions to adjust the picture really is a must.
Unfortunately, No OSD .No adjustments to output . No choice in how to place the unit .
The live view is a little disappointing. I compare it to a good 480TVL, Adequate but not amazing.
The DVR record the live view but in 1440x 1080
The live CAM picture itself appears a bit dull and blurry . The White correction is slow ,therefore fast changing environments like dark to light present the camera with some notable performance issues.
Unlike the DVR , which i said before does the fast changes rather good ?
Maybe we see here one of the compromises necessary to have a ALL IN 1 Unit?
All in all a decent enough package . I will use it on my BixlerII mounted on a gimbal. Which is a much more suited use of the Boscam TR1.
So stay tuned , once the weather gets a bit better and we have some ore sunhours I ll make another video .
contact303 is offline Find More Posts by contact303
Old May 04, 2015, 06:40 PM
pato13uy is offline
Find More Posts by pato13uy
Joined Apr 2015
Problem with recording function
Hi friend, you did make a good review. I have a problem with the recording function. I make a recording of a pair of minutes, and its only save a few seconds (15 aprox), and then the video crashes(Windows media player throw an error "a problem with playing the file")
I follow all the instructions you described to record video, buy i dont have luck.
I repeated the test several time...
Do you have any idea what could be the reason?
Thanks!!
pato13uy is offline Find More Posts by pato13uy
For Sale (2)2.4 Ghz vRx,(2) 2.4 Ghz vTx. and 2.4Ghz. Cam with built in Vtx. for FPV Magoo76 FPV Equipment (FS/W) 0 Dec 20, 2014 10:07 AM
Sold VA1100 All-in-One Ultra Micro FPV cam system ZIIguy FPV Equipment (FS/W) 3 Dec 04, 2014 02:47 PM
Sold TBS Core, DL Rx, 1.3 and 1.2 VTx, 1.3 CP antennas, broken Pixim cam MayMayDay FPV Equipment (FS/W) 0 Aug 23, 2013 01:16 AM
Sold Alternative FC2.0 board all in one board + 1 all in one mkbl board noppita Aircraft - Electric - Multirotor (FS/W) 1 Jan 29, 2012 10:48 PM
