Old Nov 06, 2009, 05:51 PM
InfaRed is offline
Find More Posts by InfaRed
Somerset, UK
Joined Oct 2008
Cellpro 10S 15A fuse
I read the FAQ about the 'No Plug Blocker', and have diagnosed that the fuse is blown. Where can I get a replacement? The UK stockist does not do repairs and apart from offering a replacement at 75.00, wasn't all that helpful.
Ian
InfaRed is offline Find More Posts by InfaRed
Old Nov 06, 2009, 09:03 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Ian
Hi Ian:
If you're handy with a soldering iron, you can carefully remove the top plate, remove the current 15A fast blow fuse, and replace with an automobile "blade" type 15A fuse. If you have questions, let us know.
Hope this helps!
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Nov 07, 2009, 03:09 AM
InfaRed is offline
Somerset, UK
Joined Oct 2008
Thanks Tim,
I'll give that a try and report back when I have done it
By the way the UK supplier is warning me of other possible damge and that it may need calibrating. It works fine charging a single pack. Is this a likely scenario?
Ian
Old Nov 07, 2009, 10:46 AM
Tim Marks's Avatar
Joined Mar 2008
Thanks Tim,
Ian
Ian:
There's a very good possibility that the fuse is the only issue. Although we put a skull and cross-bones symbol between the inner two banana jacks, customers still plug a battery across these banana jacks by mistake from time-to-time. That's what takes out this fuse. So hopefully that's all that's happened in your case as well.
Good luck.
Tim Marks
Old Nov 08, 2009, 06:03 PM
InfaRed is offline
Somerset, UK
Joined Oct 2008
Replaced the fuse with an automotive blade type and all appears to be working. Just topped off a couple of Flightmax lipos and got the readings for each separately.
As a separate issue I have an Overlander Tornado 3s 2100 which is a PQ type connector. When I use the Cellpro 4s adapter it charges OK, however the 6s adaptor(s) gives me a reverse polarity error. Any ideas?
Ian
Old Nov 08, 2009, 07:04 PM
Tim Marks's Avatar
Joined Mar 2008
Ian
Glad to hear you were able to swap out the fuse and get the charger working again! With regard to the adapter issue, that's odd. The 4s and 6s adapters should be virtually identical in operation with regard to a single 3s battery. When using the 6s adapter, make sure you are plugging the first pigtail (the one that does not have the wrap-around label which reads "Connect for 6s") plugged into channel 1 of the charger. The pigtail with the label goes into channel 2 and is only used when you are charging a 6s battery.
Old Nov 09, 2009, 01:47 AM
InfaRed is offline
Somerset, UK
Joined Oct 2008
The adaptors over here are not marked connect for 6s only.
One side is for PQ connectors and the other for TP. Or so it appears.
It looks exactly like http://www.fmadirect.com/detail.htm?...280&section=72.
If you have two of these then you can charge two packs.
If the label is missing which wire connection should I be using, Left or Right?
Ian
Old Nov 09, 2009, 09:11 AM
Tim Marks's Avatar
Joined Mar 2008
Ian
Ian:
Ah, O.K. That's the problem. Both pigtails can be used for either brand. For 2s-5s, you need to plug the pigtail opposite the TP style into Channel 1. If 6s, then you would also use the other pigtail and plug it in to channel 2.
Sorry for the confusion. I'll need to touch base with the mfr and make sure they fix this problem.
Tim Marks
Old Nov 09, 2009, 02:55 PM
InfaRed is offline
Somerset, UK
Joined Oct 2008
Thanks Tim. I was beginning to suspect that as I had used the TP side to charge a Flightpower Lipo OK. Good of you to confirm it.
I'll get some labels and mark up all my adaptors.
Ian
Old May 01, 2015, 08:39 PM
John K. White is offline
Find More Posts by John K. White
Joined Apr 2014
Cellpro 10S Charger Error Message
My Cellpro 10S Charger will charge one 1350 mAh LiPo, but when trying to charge two 1350 mAh LiPo's it gives an error message "Ch2 Bad S. Count". I can charge two 350 mAh LiPo's with no problem. What is wrong with the charger? Is the fuse blown? If replacing the fuse will fix the charger, how do I go about doing this?
John K. White is offline Find More Posts by John K. White
Old May 01, 2015, 09:09 PM
Gregor99 is offline
Find More Posts by Gregor99
Seattle
Joined Sep 2007
How are the packs connected to the charger? Can you post a picture? Are the 350 pack and the 1350 pack the same cell count?
Similar thread http://www.rcgroups.com/forums/showthread.php?t=2395594
Gregor99 is offline Find More Posts by Gregor99
Old May 02, 2015, 04:33 AM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
John,
Anytime you refer to a battery please specify both the cell count and the mAh.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Sold FMA CellPro 10S Charger X2 BoysToys Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 31, 2009 03:32 PM
Question Cellpro 10s question Al P Batteries and Chargers 4 Oct 26, 2009 08:22 AM
Wanted Cellpro 10s charger Gunky Aircraft - Electric - Batteries & Chargers (FS/W) 2 Oct 12, 2009 10:49 AM
Wanted FMA Cellpro 10S MrE Aircraft - Electric - Batteries & Chargers (FS/W) 5 Oct 05, 2009 02:30 PM
Wanted WANTED a FMA CELLPRO 10S USB Interface Module for 2 way data communication mechengineer03 Aircraft - Electric - Batteries & Chargers (FS/W) 6 Sep 06, 2009 11:52 PM
