Old Jun 07, 2016, 01:48 PM
omahaomaha is offline
Find More Posts by omahaomaha
United States, NE, Omaha
Joined Sep 2015
Build Log
Soljet 70mm EDF Flying Wing
The Soljet is a flying wing with a single 70mm EDF unit. I'm going to build with R1.0 foam from lowes and carbon tubing.
My plan is to make this a 5-6 minute night flyer with the advanced edf lighting kit and neon tubes. I have a 70mm unit left over from a motor replacement on my FMS scorpion and I want to try my hand at a scratch build.
Wish me luck!
omahaomaha is offline Find More Posts by omahaomaha
Old Jun 08, 2016, 05:30 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
EDF on top
CK my blog
space 1 is offline Find More Posts by space 1
Old Jun 08, 2016, 04:07 PM
Joined Sep 2015
Originally Posted by space 1 View Post
CK my blog
Those look good!
Old Jun 08, 2016, 04:14 PM
Joined Sep 2015
Here's a parts list for my build:
2 aileron servos
1 elevator servo for thrust vector
1 rudder servo for thrust vector
kk2 board for flight stabilization
thrust vector 70mm
fms 70mm 12 blade unit
fms 70a esc
frsky x8r
frsky high precision variometer
frsky 100a current sensor
advanced edf lighting system
4 blue fiber optic tube lights
5v 3a bec
1 female to 5 male jst splitter for lights
500mah 3s battery for lights
2 5300 2s 40c batteries for motor/rx/surface control
square carbon fiber tubing
lowes r1.0 styrofoam
'slightly better than balsa' wood from menards for motor mount
Old Jun 08, 2016, 04:33 PM
Joined Sep 2015
I essentially want it to look like a Ho 229 (belly lander) with one motor and nowhere for the pilot:
https://s-media-cache-ak0.pinimg.com...1de3112911.jpg
Old Jun 09, 2016, 08:37 AM
Joined Sep 2015
Very much like this XPD-8 - but much larger. My plan is to build the wings out of foam and feed in 15cm square carbon fiber tubing that's detachable from the fuselage. This model had CG issues because all the components were stored in a somewhat large cockpit area on top of the edf. The soljet will have two 2s batteries on either side of the edf. Only the ESC, Gyro, Receiver, light control, and light battery will sit on top of the EDF if I can't get them to balance on either side of the edf. Something else weird about the XPD-8 is that the aileron servos are on the bottom and there doesn't seem to be any kind of skid pad. I'm planning to put my servos on top of the wing (just like a CTH wing) and build skid pads out of 3 liter coke bottle plastic.
ElectriFly RC XPD-8 EP HyperFlow Ducted Fan ARF (1 min 30 sec)
Old Jun 09, 2016, 09:06 AM
Joined Sep 2015
Another video that looks similar to my design is the FF-Wasp. The difference is that I won't have a rudder because I'll be using thrust vectoring for yaw. The balance of this jet is achieved with two 4s batteries ahead of the edf unit which is all the way in the back. The intake for the edf comes from the top and bottom of the wing which has been disrupted by the wing itself. I don't like disrupting the airflow into the edf - mine will be completely open. I do like the vertical stripes - I might want that in blue and white. The thrust tube on the back can't help with the CG either...
90MM Homemade EDF JET Maiden 8S FF- WASP Part 3 (9 min 1 sec)
Old Jun 09, 2016, 11:18 AM
Joined Sep 2015
Updated CoG image
Old Jun 09, 2016, 12:48 PM
Joined Sep 2015
Thrust vectoring hopefully goes as good as this:
home made trhust vectoring for EDF (5 min 51 sec)
Old Jun 10, 2016, 06:09 AM
space 1 is offline
USA
Joined Apr 2007
xpd
xpd good flyer I was going to put nose cone & use where fan goes for all elect & battery & mount EDF on top
Old Jun 13, 2016, 09:34 AM
Joined Sep 2015
Pictures from this weekend
I attempted to create the framing for the thrust tube this weekend but didn't get far. I need to wait for the thrust tube to come in to see how I could mount it before making the fuselage, but these pictures show my first attempt. I will need 2 or 3 of these frames to connect to the pieces they will slide into for the sides of the fuse. I'm planning to put the batteries here and mount the wings to them.
My next attempt will be different because I'm going to make all 3 of the frames on my band saw at once so they'll be identical. I'm also going to have a better idea about the real wingspan of this plane. I want to use a 23 degree sweep off of a 20cm center section. Depending on how much the thrust vector weighs I'm going to have to make the wings a little shorter than in my original diagrams.
Thank you skydve for getting the fan unit and ESC back to me!
This week, my orders for batteries, servos, carbon rods etc. is coming in. I'll post more pictures then!
Old Jun 19, 2016, 10:09 AM
space 1 is offline
USA
Joined Apr 2007
full fuse
I know you build lots better than I do but thought you may like this
Old Jun 20, 2016, 12:17 PM
Joined Sep 2015
This is my first build. Yours looks good!
Old Jun 20, 2016, 01:33 PM
Joined Sep 2015
This thing is too heavy for VTOL.
The motor I have can only do 1600g of thrust. If I assume that the wood, foam, and carbon tubes are about 500g then this won't work.
Should still fly though. I kind of wanted it to be slower for more aerobatic moves with the lights on at night.
Old Jun 21, 2016, 08:05 AM
Joined Sep 2015
Busy night
Last night I cut more fuselage parts and added the sides. I realize that the batteries I bought are about 3x too big for this plane so I'll have to use them for something else or get rid of them in the classifieds. The entire plane should be less than 1500g and those batteries are more than 500g!
All I need to do now is figure out how long the wings should be. I'm set on a 23 degree angle from the front of the fuselage. I need the thrust vector on the end of the thrust tube to be shorter than the wings so that when they fold out for VTOL mode, they'll hit the ground instead of the vector.
Discussion EDF powered flying wing. oneday Flying Wings 11 Jul 04, 2016 08:35 PM
Found 64mm EDF Flying Wing ricebowl1988 Aircraft - Electric - Airplanes (FS/W) 0 May 18, 2016 09:35 PM
For Sale 70mm Sapac MB-1 EDF Unit and Motor plus a 70mm 6s EDF Unit jgalexander Aircraft - Electric - Jets (FS/W) 8 May 05, 2016 08:55 PM
For Sale 70mm Sapac MB-1 EDF Unit and Motor + a 70mm 6s EDF Unit jgalexander Aircraft - Electric - Jets (FS/W) 0 Apr 16, 2016 12:54 PM
Build Log The Bat Wing 70mm edf jet. crispy1074 Foamies (Scratchbuilt) 1 Jan 30, 2016 09:31 PM
