Old May 20, 2016, 09:03 AM
Capt. Kelso is offline
Find More Posts by Capt. Kelso
Capt. Kelso
Capt. Kelso's Avatar
United States, FL, Fernandina Beach
Joined Dec 2011
Portable Starting/Work Bench
I've always been frustrated trying to work on a plane while running the engine away from the Field. Specifically working at home without a Starting Bench. You know, you finish a build or re-build and want to run the engine and tune everything before going to the Field.
In my case, its a 40+ mile round trip to the Field, a long way to go in order to test something. Recently, I built a couple of Starting Benches for our Club using plans I found on RC Universe,
http://images.rcuniverse.com/forum/u...58/Sq46166.pdf
After studying the plans further I decided to build a Portable Starting Bench to use in my garage by modifying the plans.
Total cost was approximately $50 of which half was for hardware and screws. Its been a great addition.
Capt. Kelso is offline Find More Posts by Capt. Kelso
Old May 20, 2016, 06:50 PM
piperjoe is offline
Find More Posts by piperjoe
piperjoe's Avatar
United States, MI, Interlochen
Joined Dec 2009
Very nice idea. One addition you may want to consider: add a screw eye to each side of the aft portion of your stand in the vicinity of the tail; doing so will allow you place an appropriate length of bunge cord over the fuselage and in front of stabilizer to hold the airplane tail down.
Soft landings,
Joe
piperjoe is offline Find More Posts by piperjoe
Old May 20, 2016, 07:17 PM
ETpilot is offline
Find More Posts by ETpilot
Joined Jun 2014
That is a good looking starting bench. I agree with piperjoe on a tail tiedown. I'm sorts of in the same situation. My club field is 55 miles one way. So I don't get to visit too often. Good news is I have a grass runway at home. So I made a starting/working stand for the workshop. Then I put it on my untility trailer to get it to the runway. Works good BUT, it has things about it I don't like. One is I've built larger planes and this one is a bit small.
So I have been thinking of building something similar to the one you built, with retractable wheels and large enough for any plane I may build. I can then tow it back n forth to the runway then set it on the ground.
Thanks for the pictures.
ETpilot is offline Find More Posts by ETpilot
Old May 21, 2016, 10:52 AM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
I like the cooler in the trailer. SPADs are great too. I have a tie down at the back of my stand too. I like to set up the idle and stuff at home without the wing on. My old test stand almost tipped over, so I thought I had better make something a bit heavier. I only used a .28 when it pulled it over too. I got the pattern for the new one off the internet too, and only changed the height and width because I am kind of tall, and most planes I have are little guys.
aspeed is online now Find More Posts by aspeed
Sold Cleaning up work bench. A few items (lot) highonthai Aircraft - General - Miscellaneous (FS/W) 0 Mar 09, 2016 12:45 PM
Sold Bunch of stuff to clean off work bench the sign shop Aircraft - Electric - Multirotor (FS/W) 0 Oct 31, 2015 02:50 PM
Sold Great Planes Bench Topper Work Bench Organizer jacktrotter Aircraft - General - Miscellaneous (FS/W) 2 Apr 27, 2014 08:34 AM
Help! Lipo powered portable prototype bench tpot Batteries and Chargers 0 Mar 09, 2010 04:05 AM
Help! Lipo powered portable prototype bench tpot RC Hovercraft 1 Mar 08, 2010 02:23 PM
