Old Jan 02, 2016, 03:37 AM
notime_3001 is offline
Find More Posts by notime_3001
United States, IL, Lansing
Joined Jun 2012
Question
Strong Clear Coating for Foam
I thought that using the Minwax Polycoat would give my EPS / Styrofoam plane the needed strength to resist dents. Sadly it is not true. My foam plane is even more susceptible to dents. I was doing some work on my plane at the kitchen table and one of the servo wires got under the fuselage. Just the weight of the plane resting on the servo wire made a very clear impression in the foam. Needless to say I'm very disappointed. Is there any strong clear coating material either spray or film that I could apply that would give the planes surface more strength to resist dents?
notime_3001 is offline Find More Posts by notime_3001
Old Jan 02, 2016, 05:57 AM
PropSpinner is offline
Find More Posts by PropSpinner
PropSpinner's Avatar
Joined Oct 2005
You have to use something like paper or fiberglass with the Minwax.
PropSpinner is offline Find More Posts by PropSpinner
Old Jan 02, 2016, 06:19 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Sadly , nothing makes foam crash-proof , ding-proof ... Careful flying actually works better than anything ...
Clear packing tape is a good protector for minor things ..
gpw is offline Find More Posts by gpw
Old Jan 02, 2016, 09:16 AM
XDmToter is offline
Find More Posts by XDmToter
XDmToter's Avatar
Joined Apr 2012
I always just use clear packing tape, but it is not as dent resistant as what I believe you are looking for.
I would like to give this stuff a try some time:
Foam Finish from Beacon Adhesives Review (5 min 12 sec)
Maybe you can try this and report back here what you think?
XDmToter is offline Find More Posts by XDmToter
Old Jan 02, 2016, 09:19 AM
XDmToter is offline
XDmToter's Avatar
Joined Apr 2012
Old Jan 02, 2016, 12:07 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Alternates :-)
http://www.horizonhobby.com/foam-armour-dlmbd50
And;
http://www.industrialpolymers.com/pr...rospray-series
Bare is offline Find More Posts by Bare
Old Jan 02, 2016, 12:25 PM
nerdnic is offline
Find More Posts by nerdnic
nerdnic's Avatar
United States, CA, Sunnyvale
Joined May 2014
What about something like this?
Hot Wire Foam Factory Exterior Foam Coat
Link: http://amzn.com/B00EOSNEAM
nerdnic is offline Find More Posts by nerdnic
Old Jan 02, 2016, 07:08 PM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
The Foamie Trailer folks discussed that and it was thought to be "too good to be true" ,and very Expensive , and likely too heavy for our plane use ... Much skepticism about the promises made ...
Old Jan 02, 2016, 07:14 PM
Whiskers is offline
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Never have been able to see little dings in my planes when they are flying.
Even more so with FPV...
Whiskers is offline Find More Posts by Whiskers
Old Jan 02, 2016, 07:18 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Foamys are susceptible to weight variations.
My neighbor built two Judi's and can really tell the difference between them
as one was built tough and Pretty and the other much Lighter and less "decorated" .
My point is simple minded .
Foamys are supposed to be cheap light and expendable.
All this newspaper and glass covering and overcoating with paint etc is just going to implact performance and delay getting into the air
WHERE, as Whiskers said , just above here ...
Ya kan't see the blems any time after takeoff.
birdofplay is online now Find More Posts by birdofplay
Old Jan 02, 2016, 07:42 PM
nerdnic is offline
nerdnic's Avatar
Joined May 2014
I disagree. I think they can be whatever you want to dream up. No reason to put them into a box.
The foam planes I build are on the heavy side, extremely fast, and last a long time. But you've got one thing right, they sure are cheap :-)
Old Jan 02, 2016, 07:43 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
I've " experimented " with coatings , coverings , etc. , mostly on the plane I make most often - the EzFly - so I can compare differences . One EzFy I covered entirely in doculam - it flew like ! The best flying planes are the ones kept LIGHTWEIGHT , and they look BEAUTIFUL when flying !
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jan 03, 2016, 03:17 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
note.... a lot of dents can be removed , either by using the steam/heat from a kettle or by using a modelling iron , they just pop back out,
multi layers of foam are stronger than a thick single layer
tape over is good , it adds a bit of weight.. decoration/colour and being tear resistant it adds strength.. however it still lets the foams get a bit dented
Ironed on laminating film is the toughest material, far stronger and tear resistant, and even heavier.
There is nothing wrong with heavier, it just means your model will have to be flown that bit faster..
any strengthening protection is going to add weight...
so its a trade off..
a light model might fly somewhat better, but that's no use if it doesn't last 5 minutes...
I mostly use a combination of layers with tape coverage... KF wings for multi layers, with 2" packing tape for protection..
the models last ok , they are often only disposed of when I need the room for a new build..
davereap is offline Find More Posts by davereap
Old Jan 03, 2016, 06:23 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Not to worry .... There have always been two schools of thought here ... Light and simple , and heavy and “crash resistant” ... No use trying to convince the other side , they seem very resistant to Logic and experience ..
Old Jan 03, 2016, 07:52 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
GPW, the peacemaker and diplomat as always :-)
My intent was not to be antagonistic but to proffer another viewpoint or philosophy.
I think it was ~ 10 yrs ago when I asked GPW about "the Foamy Philosophy"
as I was trying to get a grip on Foamy designing and uses versus my yrs
of building with balsa and ply.
Question Which clear coat for foam planes? mondo1948 Painting and Finishing Tips 14 Mar 14, 2016 08:03 AM
Discussion Clear Coating DollarTree Foam AssassinXCV Foamies (Scratchbuilt) 3 Oct 31, 2015 10:26 PM
Discussion A durable/protective yet light clear coat safe for foam? thrashaero Micro Ready-to-Fly 3 Aug 08, 2015 01:12 AM
Question Clear coat for foam? Tony_Fletcher Painting and Finishing Tips 7 Oct 26, 2009 03:51 PM
Question Clear Coat for Foam? LBJ Foamy EDFs 5 Dec 29, 2008 09:04 PM
