Old Dec 14, 2015, 05:58 AM
franc is offline
Find More Posts by franc
Joined Mar 2004
Eurofighter airfoil
Although I have own-designed and built numerous "conventional" scale models, I now want to try my hand at an EDF jet, specifically the Eurofighter Typhoon, for a 70 to 90 mm fan, around 800 to 1000 mm span.
Does anyone have any ideas on the ideal airfoil to use on such a model; thickness, camber, washout?
(On my other models I have traditionally used the original airfoil with good results, but don't think it will work in this case?)
franc is offline Find More Posts by franc
Old Dec 14, 2015, 09:54 AM
bandetlol is online now
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
You could always get the freewing 90mm eurofighter and use it as a mold..
bandetlol is online now Find More Posts by bandetlol
Old Dec 14, 2015, 10:14 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
For some inspiration, you could read acesimmer's thread - 76" Scale twin 90mm Composite Typhoon Scratch Build
http://www.rcgroups.com/forums/showthread.php?t=1831924
Both of these are scratch built-- and all composite. He would know about the airfoil.
http://static.rcgroups.net/forums/at...3-IMG_2626.jpg
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 14, 2015, 08:06 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
use of a reflexed airfoil is very helpful in reducing trim drag ...most delta need some up trim ..having the canard helps reduce this some .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Dec 15, 2015, 10:40 AM
franc is offline
Joined Mar 2004
Thanks for all the responses.
I had a look at the Freewing model, but with the poor exchange rate my currency has with the $ that's way out of reach.
I'll check out the other threads, need the inspiration!
Discussion Simulate EuroFighter crash? Wid Simulators 0 Jun 20, 2015 09:23 AM
Sold Freewing Eurofighter V1 mains retracts/struts vigilante1 Aircraft - Electric - Jets (FS/W) 0 Jun 15, 2015 01:46 PM
Wanted Freewing Eurofighter nose section Ceeray Aircraft - Electric - Jets (FS/W) 0 May 24, 2015 01:19 PM
Sold Eurofighter V1 with servos, motor, fan pmisuinas Aircraft - Electric - Jets (FS/W) 4 May 16, 2015 09:36 AM
Discussion drawing eurofighter 90 Graupner Eddy croes Balsa Builders 0 May 03, 2015 03:38 AM
