Old Jan 11, 2016, 02:02 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Build Log
Aerobeez 91" Slick "BANSHEE"
Picked this bad boy up from the 2016 AMA Expo just this past weekend. Looks like a big box of shenanigans to me!!!!
Planning on running the following:
-5x HSB-9485SH servos
-1x HSB-9465SH throttle
-2x Maxima 6 receivers for redundancy
-2x 2S 1300 LiPo batteries for Rx
-1x 2600 Fromeco LiIon for ignition
- DA70
- Stock everything else
Lets do this...
Xpress.. is offline Find More Posts by Xpress..
Old Jan 11, 2016, 06:19 PM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
I was there Sunday. It looks pretty cool, I even snapped a photo of it and bought one of their little camera quads for my daughter:
jk6672 is online now Find More Posts by jk6672
Old Jan 12, 2016, 03:33 PM
mnavarro is offline
Find More Posts by mnavarro
United States, CA, SF
Joined Oct 2010
Nice! You got a lot of projects!
- DA70
Lets do this...
mnavarro is offline Find More Posts by mnavarro
Old Jan 12, 2016, 04:32 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Too many unfortunately
Old Jan 12, 2016, 05:40 PM
mnavarro is offline
Joined Oct 2010
Do you recommend the dual receiver setup?
Old Jan 12, 2016, 09:55 PM
GravyRobber is offline
Find More Posts by GravyRobber
I fly. I'm pilot.
GravyRobber's Avatar
United States, TN, Memphis
Joined Oct 2012
Good looking plane! Perfect for a DA-70
GravyRobber is offline Find More Posts by GravyRobber
Old Jan 13, 2016, 10:01 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Yes, with a large gasoline airplane I always prefer to use dual redundancy setups.
I agree!
Old Jan 13, 2016, 10:10 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Here is the unboxed pictures, with captions.
Old Jan 13, 2016, 10:34 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Initial impressions with the kit:
-HUGE leaps and bounds improvement from their previous kits, tons of high quality hardware included, very extensive
-Vibrant color scheme, should have no issues seeing this in the air (not that I fly high enough anyways..)
-Extremely well packed in the box
-Initial inspection of parts fit is superb, will need to get into it more to find out everything else
-Improved landing gear assembly and fuel tank is a very welcome surprise
Some other notes that some may want to take:
-Always go over the covering BEFORE you begin to assemble the airplane. No airplane is impervious to the huge climate changes that the containers go through when being shipped here so always iron everything down to be certain. I'm never worried about wrinkles on an airplane fresh out of the box, that's totally normal no matter who you buy from.
-Always double check parts fit and finish before assembling so you can tweak and correct any minor problems you come across. Sofar, my kit seems to be immaculate, aside from maybe some adhesive I need to wipe off from misc. parts taped in place
-Always check your hardware package, you can compare it to mine if you would like. My kit is very complete.
-I always go over all of the plywood to plywood glue joints with thin CA to ensure the wood is sufficiently bonded. It's not really necessary, but it gives you an added measure of security and peace of mind before you start assembling your airplane and put components over areas that can't be reached. I may also brush some thinned epoxy on over the entire motor box assembly to completely fuel proof it.
As far as components like the carbon fiber servo arms, you can opt to use them if you would like but I will be opting to use 1.5" aluminum arms throughout.
That's all for now...
Old Jan 13, 2016, 12:39 PM
taildragger21 is offline
Find More Posts by taildragger21
taildragger21's Avatar
park city
Joined Jul 2004
Nice details express! I am following this and hoping we can encourage each other I'm kinda working on my banshee slick while building 2 warbirds. Too much random....
taildragger21 is offline Find More Posts by taildragger21
Site Sponsor
Old Jan 13, 2016, 12:44 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
My biggest hurdle is acquiring equipment. Should have servos by the end of the month, engine sometime in February I am hoping..
This is going to be a parts log for myself so I know what I need to gather or buy, but please feel free to use this on your own aircraft!
-Desert Aircraft DA70, x1
-Falcon 24x9 propeller, x1
-4" spinner, red to match, x1
-Fromeco Sahara 6.0v regulator, x1
-Fromeco Wolverine switch, x1
-Fromeco Badger switch, x1
-Thunder Power 2s 1900 RX pack, x3
-Hitec HSB-9485SH servo, x5
-Hitec HSB-9465SH servo, x1
-Hitec Maxima 6 receiver, x2
-48" HD Twisted extension, x2
-12" HD extension, x4
-SWB 1.5" Futaba spline arm, x4
-SWB 1" Futaba spline arm, x1
-SWB 4" offset Futaba spline arm, x1
-Secraft easy couplers, x1
-Secraft wing bolts, x1
I think that's about it. I'll give the factory fuel dot a try and if I don't like it I can always change it out later. Having other nice hardware already in the box really saves on cash, it's a very comprehensive kit.
Old Jan 13, 2016, 04:27 PM
I fly. I'm pilot.
Joined Oct 2012
Nice detail in the pics. Do you know if the DA-70 will fit without cutting holes in the cowl for the plugs?
Old Jan 13, 2016, 05:12 PM
John
jk6672's Avatar
Joined Sep 2012
Is it light enough to electrify? Those are some interesting looking control horns. I don't think I've ever seen them like that.
Whoops! Aerobeez 38" Slick 540 ToeBall 3D Foamies 2 Oct 20, 2015 12:39 PM
Video The Aerobeez Epp Electric Slick 540. Testimonials, Flying, and More Aerobeez Aerobeez 0 Jul 22, 2015 03:36 PM
Sold Aerobeez 30cc Slick 540 Airframe and more... Rich215 Aircraft - Fuel - Airplanes (FS/W) 3 May 13, 2015 09:23 AM
Build Log Aerobeez 30% Slick 540 Build Thread funflyr Giant Scale Airplanes 59 Aug 17, 2013 08:16 AM
