Old Dec 22, 2014, 07:22 AM
RC4ME2 is offline
Find More Posts by RC4ME2
Joined Dec 2013
FMS Olympus CG and Battery Tray Issue
I know this sounds crazy, but the FMS Olympus I just purchased seems to have the track for the battery tray mounted too far forward. When I watched the video by RC Informer (the 15 plus minute video on Youtube), I noticed the way he was able to put the battery tray in. On my Olympus I have to push the front end of the battery tray all the way up into the motor compartment and then get it started in the track. I could never install my battery tray the way the guy on the video did since the track is mounted so far forward.
When you look on the inside of the fuse where the track mounts, you can see where the fuse has cut outs that would accommodate the track being mounted further back in the fuse. It looks like if the tracks had been glued in as far back as the cut outs allow, then if would match up with what I saw on the video mentioned above.
The result of all of this is, when the battery tray is locked in place, to get the CG even close I have to mount the 6S 3300 35C battery several inches from the front edge of the battery tray which means that it ends up hanging off the back of the tray.
A buddy of mine purchased his Olympus some time ago and he said his plane balances with his battery mounted with 1/4" of battery hanging off the front edge of the tray (with tray locked in place). I tried that on my first flight and almost crashed.
So, it seems to me that the left and right tracks were simply mounted too far forward.
Has anyone else who purchased a Olympus recently noticed this issue?
RC4ME2 is offline Find More Posts by RC4ME2
Old Dec 30, 2014, 03:23 PM
Anthonyr is offline
Find More Posts by Anthonyr
United States, NY, Ossining
Joined Aug 2003
My tray is almost all the way over the wing. With a 5 cell 4500 it works fine and the others in my club had no trouble. Maybe a picture?
Anthonyr is offline Find More Posts by Anthonyr
Old Feb 28, 2015, 10:07 PM
Chompy is offline
Find More Posts by Chompy
Joined Jan 2014
RC4ME2: I just received my Olympus and have the exact same issue. Basically I cant/wont take the battery tray out (which defeats the purpose) and moved the straps all the way back. I also put a large strip of velcro on the bottom of the tray and have the corresponding velcro on my batteries (I also have this on my other planes). What CG did you find works for you?
Chompy is offline Find More Posts by Chompy
Old Sep 03, 2015, 04:04 AM
richie.p is offline
Find More Posts by richie.p
Joined Dec 2013
My battery tray has to be pushed all the way to the motor with a a 6cell on it and it balances perfect the only thing i had to do was cut some fome away to allow the tray to drop into the runners.
richie.p is offline Find More Posts by richie.p
Old Dec 15, 2015, 02:44 PM
Pattern_is_fun is offline
Find More Posts by Pattern_is_fun
Pattern_is_fun's Avatar
United States, CO, Westminster
Joined Sep 2004
Here is a link (below) that shows my battery location - the last post is a picture. I'm running my CG at 7.25" from the front of the wing (185mm). I run a 5 Cell 5000mah pack. While my battery hangs way over the back of the tray, I have some Styrofoam blocks to keep the battery from moving back and forth - see picture. Also, I do not remove my battery tray (actually I have a screw in place to make sure the tray does not slide forward (picture)) - the battery slides in and out thru the Velcro straps and works great. Clearly a late post but thought I'd respond for others that may read this.
http://www.rcuniverse.com/forum/elec...olympus-4.html
scott
Pattern_is_fun is offline Find More Posts by Pattern_is_fun
Old Dec 19, 2015, 07:46 PM
Joined Sep 2004
Battery tray modification to push battery back farther
After thinking about this a bit I made a small modification which allows the battery tray to get pushed back about 2-3" and the battery now sits fine in the tray and very secure. I took a Dermal tool and cut out the back notch in the side slides - then did a bit of filing and the tray then slid back 2-3" in the track. I then mounted a small hardwood block (picture) in the Styrofoam which aligned with the screw hole I have in the battery tray. A 6x32 screw now holds the battery tray in place and is very secure. I like the solution and it's easy to do. I will be removing the Styrofoam rear battery supports you see in the picture.
Note the picture with the battery tray in position - you can see the mounting screw just to the right of the front Velcro strap. The red line is the original battery tray mounting position.
Discussion FMS 1300mm Extra 300 cg inverted flier Vendor Talk 6 May 08, 2015 02:06 PM
Discussion FMS 85A ESC and CC Bec Issues richgraf Castle Creations 3 Nov 21, 2014 09:11 AM
Discussion FMS BBD 1450mm ARF - FMS Motor Issues Undermoose Foamies (Kits) 8 Sep 01, 2014 01:46 PM
Sold SOLD 600 Pro KDE Battery Tray(2 trays) SOLD jgpncll Aircraft - Electric - Helis (FS/W) 0 Jun 22, 2012 11:06 PM
Wanted Starmax HL F-18 rx tray, battery tray and nose gear Joe 1320 Aircraft - Electric - Jets (FS/W) 7 Sep 16, 2008 09:56 PM
