Old Sep 28, 2008, 04:10 AM
Joined Aug 2008
Never doubted it. I know a thorough guy when I see one.
Ghimmy51 is offline Find More Posts by Ghimmy51
Old Oct 02, 2008, 04:19 PM
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
cam follower
If i was going to slot the follower, I would cut it in a sprial. Then you would not wear a groove into the case.
Cherokee Flyer is offline Find More Posts by Cherokee Flyer
Old Oct 08, 2008, 07:10 PM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I had a chance to run the engine today. It started up nicely and runs fine. The needles are sensitive on 0% nitro fuel. Idle transition is not great. I can't richen it enough to slam the throttle open without it stumbling or quiting. If I do richen it, the idle is sloppy. It will idle very slowly, but not at a mixture setting that allows any sort of transition. It seems the carb gets very rich at extremely low throttle settings. I think the carb is beyond it's normal idle range, there is such a small opening that it's surprising it runs. I pulled the rocker cover after about ten minutes of tuning and it was nice and wet, much more oil than it ever has in stock form. The fuel had only 8% oil, balance methanol.
I have added a page on my site now. I'll add a photo tonight of the installation in the test airframe. I managed to get the ignition and fuel tank into the nose of an Avistar 40. I hope to fly it and get some performance figures tomorrow.
Greg
gkamysz is offline Find More Posts by gkamysz
Latest blog entry: A tiny diesel engine AE 0.1CC
Old Oct 09, 2008, 09:36 AM
I TOBOR's Avatar
Joined Feb 2007
Greg, I've been following this with great interest and actually made a velocity stack from the stainless tube on a (dead) Hobbico SuperShot. I expanded the tube a little with the shaft end of an appropriately sized drill bit. It is a fairly hard press fit with red LockTite, it's the second one I've done this way, they never offer to come off.
I TOBOR is offline Find More Posts by I TOBOR
Old Oct 09, 2008, 10:00 PM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I'll probably end up making a stack from aluminum bar.
The carb tuned well even tough it was sensitive. One click rich on the main needle would give it a mid range burble in the air. It never quit and I love it. The guys that were out today liked it too.
I just updated my webpage with a video.
Greg
Old Dec 19, 2008, 03:30 PM
Joined Nov 2006
Hi, I'm planning to get the FSa 56 for a Kyosho Spitfire 40. Due to the new lubrication mechanism I have some doubts if the lubrication is working if the engine is mounted upside down. Has anybody operating experience running this engine upside down ?
boetzi is offline Find More Posts by boetzi
Old Dec 19, 2008, 04:03 PM
jdr43
jdr43's Avatar
USA, AR, Bella Vista
Joined Oct 2005
FSa 56
I'm running mine upside down in a Topflight Elder no problems to report.
jdr43 is offline Find More Posts by jdr43
Old Dec 20, 2008, 01:14 AM
We shall serve the Lord
kingsflyer's Avatar
TEXAS
Joined Sep 2005
Inverted mounting should make the lubrication system work even better. You get a gravity assist to get the lube up the lifter covers and into the valve cover.
McD
kingsflyer is offline Find More Posts by kingsflyer
Old Jan 07, 2009, 11:32 AM
Joined Dec 2007
Kingsflyer,
Have you tried the 56a on a 14x5 prop? It should be the same loading as the 13x6. I'm currently flying the OS .48 on a Goldberg Tiger2 with a 12x5 and it has the torque to do outside loops. I had a magnum 52 on the tiger and it barely flew. I have a new 56 that I was going to put on a Sig Kadet aerial photography plane.
dMac
macmoke1 is offline Find More Posts by macmoke1
Old Jan 08, 2009, 03:39 AM
kingsflyer's Avatar
TEXAS
Joined Sep 2005
I'm still flying the 13x6 Master Airscrew S2 prop on my Akro. I'm sure a 14x4 would work as well, but I like the extra speed of the 6 pitch for Knife edge.
Mike McD
Old Aug 04, 2009, 02:45 AM
Too windy to fly? Lets surf
w1nd6urfa's Avatar
Athens, Greece
Joined Oct 2008
No compression, poor top RPM
I have the OS 56 FS-a, bought new and run in with about a gallon of fuel last December. Used it on a Kyosho warbird, wasn't impressed with the performance and switched to the 55 AX.
After 6 months of storage in a sealed bag with after run oil, I want to use the 56a again. I checked the valve clearance, installed a new F plug and tested it last weekend: it fired up OK with electric starter and it produced 8,500 RPM on APC 12x6 at WOT (200 RPM rich of max). Used 15% Cool Power, rather hot but dry day.
I also noted that when the engine's cold I can turn the prop and there's almost no compression (just the hissing sound as the valves open and close), no comparison to my .91 Surpass II which has a lot of compression when cold.
Is this how the FS-a behaves or there's a problem? The RPMs I get are 15-20% less than the test numbers reported on page 1, what could be the problem?
w1nd6urfa is offline Find More Posts by w1nd6urfa
Old Aug 04, 2009, 06:06 PM
psjdb's Avatar
Pannawonica WA
Joined Aug 2007
We have hot dry days here ,I had my 56a in an 8lb CMPro Zero, had an APC 13x7 prop which seemed to give the best all round performance and it was pulling around 8900 RPM so your engine,s rpm sounds alittle on the low side..what altitude is your flying site ?.
I was running 20% nitro 13 % syn 5% castor mix.
Also I had an OS 52FS pipe fitted on this model , which is why it sounds alittle different from the 56a's ussual note.
Cheers Steffan.
Last flights of the Zero (3 min 30 sec)
psjdb is offline Find More Posts by psjdb
Old Aug 04, 2009, 10:16 PM
kingsflyer's Avatar
TEXAS
Joined Sep 2005
I agree with Steffan. Your numbers sound low and you should have pretty good compression even when cold. You may need to send it back to OS for a checkup.
McD
Latest blog entry: LEDs on my T-28
Old Apr 22, 2010, 10:19 PM
Sunnyvale, California USA
Joined Jan 2003
anyone get the FSa-72?
tora is offline Find More Posts by tora
Old Apr 22, 2010, 10:37 PM
CustomPC's Avatar
Australia, NSW, Cherrybrook
Joined May 2004
Yep,
I have the .72a in my Big Stik 40 and its great.
Turns a 12x7 at 10,700rpm and pulls the plane around with plenty of power to spare.
CustomPC is offline Find More Posts by CustomPC
For Sale OS .91 four stroke Surpass engine, new. Thomas B Aircraft - Fuel - Engines and Accessories (FS/W) 9 Apr 18, 2007 04:04 AM
For Sale Os Fs 91s Ii Four Stroke Engine antoinevan Aircraft - Fuel - Engines and Accessories (FS/W) 3 Dec 22, 2006 08:51 PM
Off Site OS FS 61 Four Stroke Glow Engine wl6 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2006 08:39 AM
For Sale FOR SALE: OS FT-120 GEMINI FOUR STROKE ENGINE - Like New IFLYdoyou Aircraft - Fuel - Airplanes (FS/W) 0 Dec 12, 2005 10:11 PM
Sold OS FS-120 Four Stroke Airplane Engine IFLYdoyou Aircraft - Fuel - Airplanes (FS/W) 3 Dec 01, 2005 02:59 AM
