Aug 18, 2012, 08:01 AM
United States, NJ
Joined Feb 2010
NIP Hacker E3-49 Brushless Inrunner Motor, 4900kV CHEAP
$25 shipped
Product Description
Key Features
Ideal for 6.6:1 gearbox (EFLM221)
Precision engineered in Germany by proven World Champions
Excellent Motor for small airplanes between 10 oz – 18 oz (280 g – 510 g) and 3D models between 12 oz – 15 oz (340 g – 425 g)
Combines ultra-high power and super-efficient design
State-of-the-art 2-pole slotted stator design for high power output
Robust all-metal construction featuring high-grade alloys throughout
Machined heat sink fins and ventilation holes on each end bell provide excellent heat dissipation at high levels of power for maximum reliability
Multiple mounting hole spacing to fit into most GWS and E-flite™ gearboxes – 14 mm and 17 mm spacing
Specifications: Diameter: 24mm (.95 in) Length: 36mm (1.4 in) Weight: 48 g (1.7 oz) Continuous Amps: 7A Peak Amps: 12A Kv: 4900 rpm/v Io: 1.4A Ri: .15 ohms
Ideal for park flyers, miniature helis and the Mini-T™
Two mounting hole spacing options
Heat sink ventilation for enhanced dissipation at high levels of power
Large -diameter rotor for better mechanical leverage
Machine-wound precision stator for more consistent performance
Specifically designed to operate with 2- to 3-series 1200–1320mAh Li-Po batteries
Needed To Complete
6.6:1 Gearbox
12 - 25A Brushless ESC
9x4.7 to 11x4.7 Prop
(10x4.7 ideal Prop)
11.1V 3-Cell 1200-1320mAh LiPo
Overview
These motors combine 3-time FAI F5D World Champion Hacker’s precision engineering with E-flite’s recognized reliability. New Hacker E-Series Brushless Motors are a unique blend of high performance and competitive price, braced by Hacker’s state-of-the-art 2-pole slotted stator design, which produces high levels of torque and rpm at lower current draws.
Ideal for 6.6:1 (EFLM221) gearbox with either a 10x4.7 or 12x6 prop using 3-Cell 1200-1320mAh Li-Po batteries on all park flyers and aerobatic planes under 16 ounces. You will get high power with great vertical and long flight times.
