Old Dec 20, 2014, 09:32 PM
Joined Dec 2014
Kyosho Hor rx placement...
Well, I bit the bullet and bought a re-issued HOR along with a HobbyWing 25a esc/7800 motor combo and A FlySky FS GT3B transmitter/receiver and my question is where is a good location to mount the receiver? It measures 35.6 x 22.3 x 13 mm (manual lists maximum size for the rx as36x26x14 and the esc as34x24x14- the HW esc measures 43x27.5x16.2). The instruction sheet is a bit confusing as it shows the esc being mounted using double stick tape under the servo housing with the receiver, again using double stick tape, being stuck to the esc case which isn't possible with the HW esc configuration. However, after some test fitting and eyeballing I think the best thing to do is find another location for the rx. There seems to be enough space under the tail section. I'm sure many of you here have more experience with this than I do so I'd like to hear your opinions/suggestions. Thanks.
OOPS! Never mind. I just looked at the box and discovered I ordered the wrong item.
oldyaler is offline Find More Posts by oldyaler
Build Log The Ultimate Kyosho Hor Build kjohns0n Motorcycles 38 Oct 20, 2014 02:22 AM
For Sale Kyosho hor hang on racer assembled Ooze Cars - Motorcycles (FS/W) 3 Oct 09, 2014 03:46 PM
Question 1/8 Kyosho HOR Tire Insert beforey2k Motorcycles 8 May 12, 2014 08:06 AM
Discussion Kyosho Hor vs GPV-1 capatability? katana2665 Motorcycles 4 Dec 21, 2013 01:59 AM
Question What rx for Kyosho HOR? GuyP Motorcycles 0 Jul 13, 2006 05:30 AM
