Old May 18, 2009, 02:18 PM
ALF F14's Avatar
UK
Joined Mar 2009
Convert 5 wire servo to 3 wire??
Have the Parkzone Mustang and want to use my Spektrum DXi6 transmitter w/ AR6100 receiver and brushed ESC. The servo's that come stock on this aircraft have 5 wires coming out of each servo (O, Y, Blk, W, Blu) the AR6100 is three pin, is it possible to convert these 5 wire stock servos to plug into the 3 pin? Thanks!
ALF F14 is offline Find More Posts by ALF F14
Old May 18, 2009, 02:26 PM
Watch out for that TREE!
Houston, Tx
Joined Oct 2006
It's probably possible, though not worth the time, effort, and parts to make it work. I have never seen anyone post the directions to accomplish this. Just throw some $5 servos in it.
John
GD5015 is offline Find More Posts by GD5015
Old May 18, 2009, 02:32 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I haven't tried it, but personally would say, no they can't be converted without rebuilding the electronics, it's not a case of swapping some wires.
Proper 3-wire servos and pretty cheap these days, try Giantcod, BRC Hobbies, Steve Webb Servoshop or any of the model shops.
eflightray is offline Find More Posts by eflightray
Old May 18, 2009, 03:48 PM
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
No.
flydiver is online now Find More Posts by flydiver
Old May 18, 2009, 04:20 PM
WARNING: May contain spam
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
As far as I know, not worth the time.
Xpress.. is offline Find More Posts by Xpress..
Old May 18, 2009, 09:29 PM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
Part of the controlling electronics are located in the receiver. Conversion would entail rebuilding the servo . Not worth the cost or effort.
BM
BillM is online now Find More Posts by BillM
Old May 19, 2009, 07:57 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Certainly.
Start with a new, good servo. Rip out the control electronics and install into the one you're looking to convert. The 5 wires are two for motor, three for the pot - the same as you'll find in the new, perfectly good servo.
.. or you could just use the new, perfectly good servo as-is..
..a
Old Mar 02, 2014, 12:01 AM
Joined Mar 2014
I have done it.
Through trial and error. if you open 3 wire servo. there is a small board with 5 wires. 2 wires to one moter and 3 to another. cut off board and 3 wire plug. make sure you have as much wire as you can get. then splice to the 5 wire servo. colors go: red to blue, grey to brown, orange to white, green to red, yellow to black. here is a pic of old and new.
Shidiz is offline Find More Posts by Shidiz
Old Mar 02, 2014, 11:33 AM
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
With the current price of servos, it is really not worth upgrading or replacing 5 wire servos.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Dec 19, 2014, 11:00 AM
Joined Jun 2007
I would say it is worthy bcz u will learn how servo elctronics work.
I hv a mini z overland truck wth 5 wires built in servo. If I can convert th built in 5 wires to 3 wires, I can use regular car ESC & radio & not to be ripped off by over expensive radio & ESC of mini z overland.
So th car would run by regular ESC wth 3 wire servo converter , & any hobby king 2.4 ghz radio.
I will try this mod soon.
congcon97 is offline Find More Posts by congcon97
Old Dec 19, 2014, 12:25 PM
yank and bank!!
Joined May 2013
Exactly.... you can buy HXT900 servos for about $ 3.33 apiece.
failboat is offline Find More Posts by failboat
Old Dec 19, 2014, 05:05 PM
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
When you can buy a ton of different servos for less than 5 bucks, in many sizes, it is simply not worth the effort. You are going to get a cheap HK radio anyway, so spring for a servo or two.
I think there are more and better ways to learn about servo electronics and electronics in general than trying to convert old 5 wire servos to 3 wire servos.
Per the post above where someone did it, you need, at a minimum, a servo amplifier board to put in the 5 wire servo to take the place of the servo amp that was in the original 5 wire RX.
And then the chance of the feedback pot working with that amp is an unknown. It might work and it might not work. I do not think you can buy the servo amps by themselves anywhere alone.
You would have to source the amps from new cheap servos and remove them or source them from someone's old damaged servos.
Old Dec 19, 2014, 05:49 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
So you destroyed a 3 wire servo to convert a 5 wire servo to a 3 wire servo when you could have just thrown the 5 wire servo away and used the original 3 wire servo directly?
Larry
Lnagel is online now Find More Posts by Lnagel
Old Dec 19, 2014, 05:56 PM
yank and bank!!
Joined May 2013
Larry
You are just the biggest people person, you big softie
Old Dec 20, 2014, 05:22 AM
Joined May 2012
This kind of reminds me of many, many years ago before servo reversing on the radios, had to take apart servos and rewire them if you needed it to work the other direction.
I agree with just about everybodies opinion that it just isn't worth it and you really aren't learning anything about electronics per say, just some soldering practice....
If I understand Shivis you have to sacrifice a 3 wire servo to convert the 5 wire so why not just use the 3 wire as already asked a couple posts above.
Sibe is offline Find More Posts by Sibe
Discussion which servo is better the hitec hs 55 or the losi 3 wire servo losb0815 ? mortonj69 Micro Cars 1 May 18, 2009 12:29 PM
Help! How do I reverse a Parkzone 5 wire servo? tofuti Radios 4 Nov 13, 2007 05:38 PM
Discussion 5 Wire Servo Mod SCOTTA1 Radios 1 Mar 28, 2006 01:33 AM
Wanted WTB PARKZONE 5-Wire Servo old_dude Aircraft - General - Radio Equipment (FS/W) 3 Feb 11, 2006 12:12 PM
Park Zone 5 Wire Servos old_dude Parkflyers 3 Dec 21, 2005 10:50 AM
