Old Jul 23, 2015, 11:00 PM
DYORD is offline
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Prop wash and prop diameter and battery pack
What are your thoughts with bigger prop on 4s v.s. smaller prop on 6s.
Which one is better for 3D?
I'm assembling a HK Sbach 342 1323mm.
DYORD is offline Find More Posts by DYORD
Old Jul 23, 2015, 11:13 PM
Motojunk is offline
Find More Posts by Motojunk
Fly it 'till it breaks.
Motojunk's Avatar
Joined May 2011
Larger prop will give you more prop wash over the control surfaces, giving you more control authority post-stall as well as more torque for quicker response. Smaller prop will be better for speed. I'd generally recommend the larger prop if you're going for 3D performance.
Motojunk is offline Find More Posts by Motojunk
Old Jul 23, 2015, 11:55 PM
Doc Austin is offline
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Yeah, big props rule for vectored thrust.
Doc Austin is offline Find More Posts by Doc Austin
Question Prop wash hitting frame - jitter cause? raw89 Scratchbuilt Multirotors 19 Jun 24, 2015 08:28 AM
Discussion Prop wash off the rug SlowJeff Mini Multirotors 3 Apr 27, 2015 10:03 PM
Question APC type prop diameter vs Folding prop diameter hog2soar Electric Sailplanes 19 Nov 01, 2013 05:29 PM
Question APC type prop diameter VS Folding prop diameter hog2soar Sailplane Talk 5 Oct 29, 2013 04:19 PM
Discussion Realflight 6.5 helical wash and prop wash set up Jnel9324 Simulators 1 Sep 01, 2013 05:08 AM
