Old Jun 03, 2014, 12:58 AM
Catherine Luo
China, Guangdong, Shenzhen
Joined Apr 2014
New Product
Skyzone SKY-700D 5.8GHz 32CH Diversity 7"FPV Monitor DVR
Specification:
1. Screen: 7 inch TFT LCD Screen/long life, LED backlight
2. Resolution: PAL(720576)、NTSC(720480)
3. Dynamic image:MP4, mono audio channel
4. Storage:RAM(around 128MB)、Mini SD(TF) Card(support 32GB in max)
5. AV output: mono audio channel、video output
6. AV input: mono audio channel、video input
7. Working Voltage: DV 6-36V(center positive) or 2s to 6S Li-battery
8. Size: 180mm x 125mm x 35mm
9. Antenna Connection: SMA Jack (center hole)
10. Built-in 5.8Ghz Dual diversity receiver automatically for best reception
11. TF card slot support TF card unto 32GB
12. AV output and 1CH AV input
13. Language : English、Chinese、German、French
14. Menu List: Loop Record/Date Stamp/Memory Info/Format/Language/Date/Time/Default/Beep/TV Standard/Battery Type/LCD Brightness/LCD Full Screen/Version
Features:
1. Built-in Dual Receiver Automatically for best reception Automatic Antenna Switching
2. Not affect by 2.4GHz R/C Radios
3. Small, light weight, durable
4. No Blue Screen, Black Screen, Flash Screen
5. Folding sunshade
6. 2 DC port
7. Support 2S to 6S Battery
8. USB port for connecting to PC or upgrade
9. 4 Bands and total 32 Channels
sitelfpv is offline Find More Posts by sitelfpv
Old Jun 03, 2014, 03:03 AM
Joined Oct 2009
it's great but it's difficult to find battery with 140*37*16.5mm size
Mister_a is offline Find More Posts by Mister_a
Old Jun 03, 2014, 03:50 AM
Polska, Mazowieckie, Warszawa
Joined Jan 2011
All below should be fine:
http://hobbyking.com/hobbyking/store...idProduct=6539
http://hobbyking.com/hobbyking/store...idProduct=9167
Modification required:
http://hobbyking.com/hobbyking/store...dProduct=17286
http://hobbyking.com/hobbyking/store...dProduct=37843
marimach77 is online now Find More Posts by marimach77
Old Jun 03, 2014, 06:15 AM
Joined Oct 2009
airsoft batteries maybe but not the other. They are in 17 mm not 16.5
Old Jun 03, 2014, 06:39 AM
Joined Jan 2011
I hope to get my Skyzone SKY-700D in a few days. Then I should be able to confirm that.
Old Jun 04, 2014, 03:34 AM
Joined Oct 2009
Thank you, I'm very interisting about this monitor.
Old Jun 19, 2014, 12:30 AM
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Does anyone have a online user manual for this? I mislaid mine and therefore can't set the dip switches...
Coming form an RC800, it's got way better features, although it's frozen once (luckily I was using the goggles at the time). Dip switches is a pain. Battery bay is great. It seems to be not *quite* as bright as the RC800, despite the sunshade. Inserting the tiny micro SD card is a bother - get it wrong and the card lands up inside the case and you have to open it up. DVR is ok, although it seems to have a lot of compression artifacts. Screen blacks out for 1/2 second when it opens a new file to write, placing undue stress on the flyer's vascular system.
heinduplessis is offline Find More Posts by heinduplessis
Old Jun 23, 2014, 08:15 AM
Joined Jan 2013
I'm not sure, but check this:
http://www.hobby-service.ru/shop.htm...roduct_id=7371
Has it frozen while recording?
How quick (if at all) it was recovered by power button?
out0f0rder is offline Find More Posts by out0f0rder
Old Jun 27, 2014, 10:09 AM
Foam Snow
Joined Aug 2011
Originally Posted by out0f0rder View Post
Thanks but link took me to a error "Ошибка: Извините, но запрашиваемый файл не был найден!".
It made an audible tone at the time as well. There isn't a power button. My spotter had to disconnect from power. Haven't happen since, but you only need it to happen once on a non RTH aircraft and it's all over.
Old Jun 28, 2014, 10:16 AM
Joined Jan 2013
Saved for you here:
https://drive.google.com/file/d/0B5Q...it?usp=sharing
Yep, that's sad news
Old Jun 28, 2014, 10:56 AM
Foam Snow
Joined Aug 2011
Thanks OutOfOrder I found it on that site after browsing around a bit. Thanks for the download. Here it is in images, for in case someone else needs it:
Old Jun 29, 2014, 06:00 PM
1 man standing in a field
the_bunker's Avatar
United Kingdom, Royal Leamington Spa
Joined Sep 2012
It's disappointing there's no power switch - I'll have to fit something but have struggled to find a small enough switch. Any suggestions ?
the_bunker is offline Find More Posts by the_bunker
Old Jun 30, 2014, 12:52 AM
Joined Jan 2011
I have started to drill the hole for this kind of switch:
Hole size should be 16mm for this switch but maybe I will stop with the current hole 6.5mm and try to use another switch.
Old Jun 30, 2014, 05:39 AM
h20rat's Avatar
Australia, QLD, Brisbane
Joined Sep 2013
I've been cautiously about to pull the trigger on this one for the last few days over anything else on the market, are owners happy with performance and features? Has anyone got any DVR video posted to see how it artifacts as mentioned above? It seems like a pretty good, solid, feature-packed unit.
h20rat is offline Find More Posts by h20rat
Old Jun 30, 2014, 07:24 AM
the_bunker's Avatar
Joined Sep 2012
I found this http://www.ebay.co.uk/itm/251569070841
I prefer a rocker switch to toggle, but this only needs a 5mm hole.
New Product All-in-one 7" Wireless & DVR Monitor 5.8GHz 32CH - Model RC800 Hobby Tech FPV Equipment 4 Jun 16, 2014 12:44 PM
Cool r Skyzone SKY-700D 5.8GHz 32CH Diversity 7"FPV Monitor DVR sitelfpv Hot Online Deals 0 May 04, 2014 11:33 PM
Whoops! $200 Skyzone SKY-700D 5.8GHz 32CH Diversity 7"FPV Monitor DVR sitelfpv Hot Online Deals 0 May 04, 2014 11:27 PM
