Old Mar 20, 2016, 05:22 PM
Birds is offline
Find More Posts by Birds
Birds's Avatar
Joined Mar 2016
mAh Question
I'm flying a plane with a 6s, 4000mAh battery. After a flight time of 8 minutes I am putting 2050mAh back into the battery. Does this mean I can add 25% more of flight time.??
Birds is offline Find More Posts by Birds
Old Mar 20, 2016, 05:41 PM
Shlomo FPV is offline
Find More Posts by Shlomo FPV
Shlomo FPV's Avatar
Australia, NSW, Sydney
Joined Sep 2015
if your going by the 'use max of 80%' rule xD
Shlomo FPV is offline Find More Posts by Shlomo FPV
Old Mar 20, 2016, 05:49 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Your only using about 50% of the batteries mah capacity. You can safely use 80%. That means you can use 3200 mah.
Keep adding to your flight times till you are replacing 3200mah.
Tom
tacx is offline Find More Posts by tacx
Old Mar 20, 2016, 06:06 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Remember, one hitch to using the "back-in mah" to calculate % used, is that it assumes the battery never loses mah due to aging.
IMO, it's much better to use 3.7V/cell (resting - after flying) as the min low voltage limit. That is about the 80% of actual capacity.
Avg Resting V % Remaining Capacity
By cell
4.00V--84%
3.96---77%
3.93---70%
3.90---63%
3.86---56%
3.83---48%
3.80---43%
3.76---35%
3.73---27%
3.70---21%
3.67---14%
hoppy is offline Find More Posts by hoppy
Old Mar 21, 2016, 04:42 PM
Birds is offline
Birds's Avatar
Joined Mar 2016
Great reply hoppy.!!!
Thanks to all. I'll go down to 3.70 per cell.
Old Mar 21, 2016, 05:16 PM
CraigHB is online now
Find More Posts by CraigHB
it wasn't me
CraigHB's Avatar
United States, NV, Reno
Joined Dec 2014
There's also some loss that occurs within the battery when charging. You can see that if you do a charge from a particular voltage then use the charger's discharge function to the same voltage. You'll get a slightly bigger number going in than going out. In any case 3.7V resting voltage is the best thing to go by. A higher voltage means you've got some amount of charge left you can utilize as indicated by the chart above.
CraigHB is online now Find More Posts by CraigHB
Discussion measuring MAH capacity question? Would these variables differ? Eddie500 Batteries and Chargers 7 Feb 19, 2016 12:15 PM
Discussion Alpha 250 racecopter mAh battery question soundfield Graupner OPENHOBBY 2 Nov 17, 2015 01:12 PM
Discussion Lipo mah question FloridaFlyBob Batteries and Chargers 2 Nov 06, 2015 07:04 AM
Discussion Max amps mah questions Irokwrx Batteries and Chargers 12 Jul 27, 2015 12:23 AM
Question A question regarding mah, voltage, and flight time. Greasydugan Batteries and Chargers 11 Apr 13, 2014 07:48 AM
