Old Feb 04, 2014, 09:36 PM
Clear Skies & Contrails
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
New Product
Banana Hobby / Blitz RC Works 50mm Viper Jet Build Thread
This is a build thread on the New Banana Hobby Blitz RC Works 50mm Viper Jet. The purpose of this thread is to provide helpful assembly tips, overview of parts and quality of this product.
This is the ARF version. This 50mm Viper Jet is available from Banana Hobby and found via this link:
http://www.bananahobby.com/3-ch-blit...f-jet-rtf.html
Features:
•3 Channel Full Function Radio Controlled (Aileron, Elevator &Throttle)
•BS2X 2 Axis Gyro Stabilization
•Detachable Nose
•Detachable Motor Hatch Secured with Rare Earth Magnets
•Pushrod Fairings
•Reinforced Winglets
•Winglets Provides Steady Flight Characteristics
•Factory Applied Decals
•EPO Foam
I have one flight on the Viper Jet using the 3S 25C 850 mAh battery and gyro not used....didn't need it. One ounce of weight was added to achieve CG but a 1000mAh battery would be the better option. Super stable flyer! I used 50% expo in the ailerons and elevator and it flew like a larger jet...even in a 10 mph crosswind. Inverted flight was rock solid with no bad tendencies.
This is a great flyer and a nice addition to the 50mm jet series.
Special thanks to Banana Hobby for providing this sample for review.
All the best,
Tony
xplaneguy is online now Find More Posts by xplaneguy
Old Feb 24, 2014, 09:05 PM
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Very nice build, Tony. This is one sweet looking plane! I will have to pick one up....sweeet
G-LO is offline Find More Posts by G-LO
Old Feb 24, 2014, 10:02 PM
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Cool...thanks G-LO! .
It's definitely one of the best 50mm jets in the Sky Angel / Blitz RC Works series.
Have fun,
Tony
Old Apr 07, 2014, 01:52 PM
Fly more Foam
sam51401's Avatar
United States, IN, Sellersburg
Joined Jun 2004
I have looked and as of yet, your review is the only one on the Mini Viper. Having just returned from Toledo, I was able to leave with the only plane of this I seen at the show and Andrew Kondor was not wanting to take it back with him. I promised I would review mine and take videos of flying it at the Jet jam coming shortly at Muncie but this before I found your postings. I would like to ask if you would not mind me being able to add to your review so as to kind of keep the info centralized for others.
I will use Glacier 3s 1300/30c packs for this and look forward to some quick and easy, throw in the car type flying from this.
FYI from Andrew, he did say he has requested for the MiniV to also come in the same scheme as the 90mm version, he favors the red one and he does like the Vipers!
The one he had at Toledo came as the ARF and he assembled the main airframe but no further. I will finish it out with the servo horns and rest of the hardware.
Here is a pic taken by someone else of it on the display rack.
sam51401 is online now Find More Posts by sam51401
Old Apr 08, 2014, 10:54 AM
naozcongmin
A moderator felt this post violated the following rule: Highly Offensive Content (Immediate suspension). It is temporarily hidden while naozcongmin edits it.
Old Apr 09, 2014, 09:47 PM
xplaneguy's Avatar
Edwards AFB, CA
Joined May 2009
Have fun Sam!
Old Apr 09, 2014, 09:58 PM
Fly more Foam
sam51401's Avatar
Joined Jun 2004
So just a few questions.......
1 Did you have issues with the decals coming loose and off? Clear coat with anything?
2 Is the posted CG in the manual correct in that it is at the LE of the wing root?????
Be a little bit before I finish it out since my main project is the A10 finish applied before the Jet Jam in Muncie. Thanks for the opportunity to post in your thread.
Sam
Old Apr 16, 2014, 03:29 PM
RAVI KOTHARI
Joined Nov 2005
The CG on the viper is nowhere close to the Manual,
The Plane flies beautifully at 1.25"- 1.5" from the leading edge where the wing meets the fuselage. Mine is currently stock & balances perfectly with just a 3S 850 mah Nano 45C. Beautiful plane, flies better than anything else i own.
Just got completely put off by that screeching fan, just sounds awful, so just ordered the 10 Bladed Dr MAD thrust 4S version & a 4s 1800 25C compact Lipo. Will file flight report post conversion soon.
ravikoth is offline Find More Posts by ravikoth
Old Apr 18, 2014, 08:28 AM
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
Subscribed. Glad I found this thread. Not much talk about the Viper over on the 50mm Skyangel thread . Mine arrives today. Have experience with the F-16, T-45, T-33, F-18, Katana and Screamer. The only disappoint was the Katana. I converted that one to a pusher prop. Also have a squadron of 64 and 70mm's.
I ordered the kit version from BH as I have components I can recycle. Going with a 4S setup using the CS-11 fan. Love the "swoosh" sound. I also like that it has a rudder too. Did I hear knife edge ? Plus, let's face it. It looks cool !
Appreciate the nice build shots. Always helpful to learn from those who have been there. Seems like every one of these JPower models has its own set of quirks. Anything to be on the lookout for concerning the Viper?
Cheers,
Hawk
dahawk47 is online now Find More Posts by dahawk47
Old Apr 18, 2014, 10:00 AM
Fly more Foam
sam51401's Avatar
Joined Jun 2004
Mine came rudderless! Not to say that one can be added but I believe it comes as a three channel.
Old Apr 18, 2014, 10:07 AM
Augermeister
dahawk47's Avatar
Joined Jul 2011
Dang, I thought I read somewhere it had a rudder. That's fine. I'm good with Bank and Yank. will still be a good addition. I do like the 64mm Stinger for that reason.
Old Apr 18, 2014, 05:56 PM
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
I noticed that it has a hinge on the vertical stabilizer anyways...
Old Apr 25, 2014, 05:03 AM
RAVI KOTHARI
Joined Nov 2005
Just a heads up on the EDF hatch, try to secure it with a Fibre tape,
mine flew off in flight. Is a pain carving out a new one
Beautiful plane.
Old Apr 25, 2014, 07:53 AM
Augermeister
dahawk47's Avatar
Joined Jul 2011
I now have a balanced CS-11 520watt 4S setup going in that I bought from Don's Wicked. Have a 4S Dr. Mad thrust set up in the Screamer. Swoosh ! Looking forward to maiden. Hopefully Saturday if I don't go see the Blue Angels fly.
Also have the T-33, F-16, T-45, Katana( converted to pusher) and the F-18. Love these little birds. Been looking for a red L-39 in this series.
Been on an edf binge lately building the Viper, a GP F-20 and the Unique Models T-50, which is truly unique.
Review Horizon Hobby E-flite's Allusive 2.2m ARF Electric Sailplane Michael Heer Electric Sailplanes 16 Dec 23, 2014 01:33 PM
Build Log Banana Hobby / LX Twin 70mm F-4 Phantom II Build Thread xplaneguy Foamy EDFs 226 Dec 01, 2014 05:52 PM
For Sale blitz rc works mini f-86 sabre jet <<<<LPU>>> ED3 Aircraft - Electric - Jets (FS/W) 3 Jan 24, 2014 01:28 AM
Discussion f-18 90mm blitz rc works edf jet by banana hobby hixallstar18 Foamy EDFs 3 Nov 29, 2009 03:20 PM
