Old May 01, 2015, 04:32 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Profili Pro templates for cutting foam wing cores
Anybody using Profili Pro to make templates for drop-arm foam cutting? I have looked at it and I don't understand how the lead-in ramp works. It doesn't look quite right to me...
BillO is offline Find More Posts by BillO
Old May 01, 2015, 04:48 PM
dpot is online now
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
it depends on what leading edge and trailing edge you are going to use
dpot is online now Find More Posts by dpot
Old May 01, 2015, 09:24 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Bill,
I don't have Profili Pro, but do have Profili2 which also has an irregularity around the leading edge.
However this does not concern me as I make a curved entry ramp at the leading edge anyway. This is, in effect, a modification of the flat ramp, with the sudden change in direction at the leading edge and makes starting of the wires progress more reliable.
I also modify the exit ramps to refect a continuation of the slope of the last part of the airfoil. Then there is no sudden change in the direction of progress of the ends of the bow carrying the hot wire. Otherwise, the wire lag will create thickening in the middle of the panel at the trailing edge.
This (modifying the ramp) totally eliminates trailing edge scalloping and eliminates sanding.
If the above is not clear, I might have some .dxf drawings somewhere.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Sold Super Gee II foam cutting templates & CLM Pro E Pod Wing&aPrayer Aircraft - Sailplanes (FS/W) 3 Jul 22, 2014 09:10 PM
Question Need some advice on cutting foam core wings Artful Owl Foamies (Scratchbuilt) 2 May 04, 2014 06:54 PM
Question Choosing foam thickness for cutting wing cores iceburg47 Foamies (Scratchbuilt) 3 Sep 25, 2013 04:34 PM
Question Making templates for cutting foam cores fooesboy Slope 7 Mar 22, 2008 03:35 PM
Help with templates for cutting wing cores. willin Foamies (Kits) 2 Jun 12, 2004 04:50 PM
