Old Mar 30, 2015, 01:50 PM
Simon Castle is offline
Find More Posts by Simon Castle
Germany, HE, Griesheim
Joined May 2008
Originally Posted by Neil Stainton View Post
How does the ESP-8266 connect to the vario
Long answer see my other posts in this thread for a more complete description of my setup.
Or go through the other videos on my YouTube channel its a bit shorter.
Basically I have an Arduino base station receiving the Vario/Voltage over a 433 RF link, the base station is doing the Biping and Voice Altitude/Voltage announcements locally, I'm just hooking up the 8266 to the serial port and feeding it the data every second.
... Simon
Simon Castle is offline Find More Posts by Simon Castle
Old Mar 30, 2015, 02:03 PM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Thanks for the explanation.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Mar 31, 2015, 11:41 AM
Rfriedman is offline
Find More Posts by Rfriedman
United States, CO, Boulder
Joined Jul 2012
Do all these components look like good ones for the vario (just the vario part, I will output audio to my video tx)
arduino:
http://www.mouser.com/new/gravitech/...h-arduinoNano/
pressure sensor:
http://www.mouser.com/ds/2/261/MS5611-01BA03-527786.pdf
Does this work or should I find one with pins broken out. Not sure if that exists on mouser...
3.3 uF cap:
http://www.mouser.com/ProductDetail/...ejiwCB6tE4%3d\
33 uF cap:
http://www.mouser.com/ProductDetail/...XcgSoJojvPw%3d
Only issue is that the arduino is $30, I was hoping to spend around $30 total.
Dx.com also has the stuff, much cheaper. The bmp sensor is $7, while the ms5611 with pins broken out if $15. Arduino is $7
I will be buying my own radio to communicate with paragliders, maybe I could get it to transmit the vario tones so they can listen in on my lift
Rfriedman is offline Find More Posts by Rfriedman
Old Apr 01, 2015, 12:06 PM
ThermalSeeker is offline
Find More Posts by ThermalSeeker
United States, CO, Denver
Joined Sep 2005
Sparkfun has the Arduino Pro Minis for $10 while existing stock exists. That's what I used and it works fine.
ThermalSeeker is offline Find More Posts by ThermalSeeker
Old Apr 01, 2015, 10:40 PM
Joined Jul 2012
Ah. The pro mini are cheaper than arduino nano V3 that my DIY headtracker uses.
Is there any disadvantage other than no usb port (have to use FTDI)?
Old Apr 02, 2015, 04:27 AM
Schalonsus is offline
Find More Posts by Schalonsus
Joined Nov 2013
No disadvantages
Schalonsus is offline Find More Posts by Schalonsus
Old Apr 03, 2015, 05:56 AM
PapaHotel is offline
Find More Posts by PapaHotel
The Netherlands, ZH, The Hague
Joined Dec 2012
I am buying my Pro Mini boards at EBay. Last two years, I bought more than 10 for less than 3 dollars each. Not experienced any problem yet. Only problem can be that it takes ~10 days to ship it to Netherlands.
This was my last source a couple of months ago for $2,60 (a 3.3v, 8MHz version):
http://www.ebay.com/itm/Redesign-Pro...item2ec77675a9
PapaHotel is offline Find More Posts by PapaHotel
Old Apr 07, 2015, 04:24 AM
jurepu is offline
Find More Posts by jurepu
Joined Sep 2012
When vario tone is in constant beep I receive some crunch inbetween, when going up I receive beep beep crunch beep etc.. at first I realized I don't have 33 uF cap on the plane side, then I added it and the crunching is also there. I have found out that EarthMagnet had similar issues. Does anyone have some advice on what to look for?
Anyone tried this module? HC-12 SI4463. You can find it on aliexpress.
jurepu is offline Find More Posts by jurepu
Old Apr 08, 2015, 08:31 AM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Yes.
Compared to the Si4432 (as in RFM22B etc) I found it less sensitive and required more complex code to drive it.
srnet is online now Find More Posts by srnet
Old Apr 10, 2015, 09:12 PM
wingid is offline
Find More Posts by wingid
Joined Jul 2006
Newbie question
Hi all, was wondering if it is possible to use the freetronics baro module in this project, and if so what changes need to be done to the sketch, as I am completely new to writing sketches.
wingid is offline Find More Posts by wingid
Old Apr 11, 2015, 02:42 AM
Thermalist is offline
Find More Posts by Thermalist
Joined Apr 2015
Another newbie question,
I have Frsky variometers for my Taranis. I need two extra variometers for my new projects. What is the wisdom, should I buy the frskys again or go for this one?
- How do these variometers perform comparing to Frsky variometers (they are ok but I like to find better ones)?
- Can I attach a TEK tube?
- Can I buy these somewhere?
Thermalist is offline Find More Posts by Thermalist
Old Apr 14, 2015, 02:23 PM
Joined May 2008
Working System
OK Flew the Android bit for the first time today, very happy with it.
Due to camera issues, Sun, Focus, reflection etc I don't have the best video for you, but hopefully you get the idea. Lots of ideas for tuning the Android App now.
First thing will be to record the flight to file.
What was interesting was just how much the battery voltage collapses when its under load. Main thing for me is to know when I'm down near 3.8V without load on a long flight. There has been occasions when I've been in the air for more than 2 Hrs with no idea of the state of my battery.
MOV00721 (2 min 38 sec)
Enjoy.
.... Simon
Discussion Arduino based IR tag module for combat sh4nce Combat 38 Feb 18, 2015 04:02 PM
New Product DIY OpenPilot based FlightControl (F4) lilvinz Multirotor Electronics 271 Jan 04, 2015 05:58 AM
Mini-HowTo DIY arduino twin video receiver diversity controller. Updates allways in post #1 Richard_s FPV Equipment 144 Jul 13, 2014 11:27 AM
Idea DIY Video Diversity with Arduino - Please Review! MayMayDay FPV Talk 2 Sep 23, 2012 12:36 PM
Help! Engineering student and first arduino based build? cad2blender UAV - Unmanned Aerial Vehicles 3 May 17, 2012 07:59 AM
