Old Aug 27, 2015, 01:33 PM
Springbok14 is offline
Find More Posts by Springbok14
Joined Aug 2015
Question
Scratchbuilt Parkflyer - Power Setup Suggestions
Hi all,
I'm looking at building a few dollar tree foam models and wanted to know what everyone's experience has been with different power setups for these models.
I have spare RX's kicking around but would be buying the brushless motor, esc and batteries new. My biggest question is what do you all consider your go-to powertrain for your park-flyer sized foamies? (battery mAH capacity, cell# and motor size and brand/model)
I'm leaning towards a 3c setup, would like flight times around 10 mins if possible, wouldn't be doing FPV but would like to mount a stripped down Mobius video camera at some point.
Sorry if this is a repeat of someone else's question, I tried searching the forum but didn't come up with anything specific.
Thanks!
Springbok14 is offline Find More Posts by Springbok14
Old Aug 27, 2015, 02:01 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
If you click on my username and browse my blog, you can get a feel for the type and size of DTF planes I build and fly (30-40" span, 7-16oz ) - most of the onesheeters are DTF. For virtually all of them the gear is as follows: 1700kv 24 gram motor (blue wonder), 7x6 APC style prop, 8-10 amp HobbyKing ss ESC, 2s 800-950mah lipo. 5 or 9 gm hextronix servos (hxt500 or hxt900). If you are interested in 3s, then a 1300 or 1500kv BW is better, but I find 2s is plenty fast for me. Flight times vary from 6 to 18 minutes depending on plane and how much I use the left stick. I have flown several with the key fob cams, Möbius should do OK as well . if you are looking for a real AP plane or fpv, then you want larger planes and gear.
springer is online now Find More Posts by springer
Old Aug 27, 2015, 03:36 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
United States, WA, Vancouver
Joined Aug 2010
+1 for Springer's electronics for " just cruisin' around " planes . For speedier planes ( F15 , etc ) the 3000 kv Blue Wonder motor works well .
balsa or carbon is online now Find More Posts by balsa or carbon
Old Aug 28, 2015, 01:08 PM
Joined Aug 2015
Thanks to you both! really appreciate the direction on this, there seems to be near countless configurations
Discussion Best HobbyKing setup for a 3D foamie Parkflyer? icy_wind500 Australia 5 Jul 09, 2015 03:29 AM
For Sale Parkflyer/3d power setup CMA Grant Aircraft - Electric - Power Systems (FS/W) 3 Jan 08, 2015 11:20 PM
Discussion Caudron G4 parkflyer – please, suggest hw Jennik Parkflyers 6 Dec 08, 2014 05:20 PM
Discussion Hotliner power setup suggestions (Smart and X-Ray) swill High Performance 1 Jun 30, 2014 02:19 AM
Discussion Thinking about a parkflyer; what are your suggestions? UserName Here Electric Plane Talk 21 Jun 04, 2014 10:13 AM
