Old Aug 26, 2015, 07:46 AM
rothlisburger is online now
Find More Posts by rothlisburger
the occasional flyer
rothlisburger's Avatar
Rexburg, ID
Joined Jul 2008
Question
Servos that don't center
I just finished a Le Fish build, and it turns out one of the wing servos doesn't center properly. When full aileron is commanded and released, the servo goes past neutral, and a little to the other side. If you jiggle the stick, it makes its way to zero, but not immediately.
Servos are HS-85mg. Is there anything I can do to fix this? Is there anything Hitec can do to fix this? Or do I just chuck it and buy a new servo? The guy at customer service didn't seem too helpful.
Thanks for any help.
-David
rothlisburger is online now Find More Posts by rothlisburger
Old Aug 26, 2015, 08:58 AM
jetmaven is online now
Find More Posts by jetmaven
The first and obvious question . Does the surface move perfectly freely when it's not attached to the servo ?
jetmaven is online now Find More Posts by jetmaven
Old Aug 26, 2015, 11:34 AM
Rexburg, ID
Joined Jul 2008
Yes.
Plus, the one that is bad is also very noisy.
-David
Old Aug 26, 2015, 01:20 PM
kbstingwing is offline
Find More Posts by kbstingwing
Slope Nutz, FLY OR DIE
kbstingwing's Avatar
Vista, Ca
Joined Oct 2002
Originally Posted by rothlisburger View Post
Yes.
-David
might have some metal shavings in the gears or some dirt, if you bought it new, I would return it if it's worth the effort or open it up and see if there is some contaminates in the gears or on the PC board, it's possible that it was a used damaged servo that got sent back and repackaged.
kbstingwing is offline Find More Posts by kbstingwing
Old Aug 26, 2015, 04:46 PM
Absolute , it's a write off . Cut the wire off right at the case so you're not tempted to reuse it . Save the wire , flush the servo .
I use Hitec servos almost exclusively , mainly 225's and a few 85's , all MG's never had a problem . I only run them at 4.8v.
Old Aug 26, 2015, 07:08 PM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Ship it back to Poway (Hitec). These guys are super good and will either replace it or fix it.
rockbus is offline Find More Posts by rockbus
Old Aug 26, 2015, 10:20 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Agreed. I'm usually too lazy to send stuff in, but Hitec has a reputation for replacing bad servos
(even ones abused severely by the pilot) at little to no cost.
Daemon is offline Find More Posts by Daemon
Old Aug 26, 2015, 10:25 PM
Aerogance is online now
Find More Posts by Aerogance
Here comes the wind!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
I have had a few Hitec servos develop bad boards recently. I will send them in soon. The servos sounded slower than normal when new and then eventually the boards smoked. The gears and cases were fine.
Aerogance is online now Find More Posts by Aerogance
Old Aug 31, 2015, 10:14 PM
Vista, Ca
Joined Oct 2002
I've had servos get dirt and small pebbles in them on the circuit board end through the wire opening, the dirt and pebbles contained iron and caused short circuits, cleaned the servos and sealed with silicone, they worked fine after that.
Old Yesterday, 09:43 AM
Rexburg, ID
Joined Jul 2008
I'll cut them out and send them in. They are brand new, but they're HS-82MGs, not 85s as I originally reported. Haven't THE 82 s had centering problems in the past? Guess it's better to spend the little extra.
-David
Old Yesterday, 10:08 AM
Vista, Ca
Joined Oct 2002
-David
I've had that happen on HS-82's before, plus there was an issue of the wires pinching and breaking at the case opening, no rubber grommet, send them back to Hitec and they should fix the problem, I made a switch to MKS servos, DS6100's are very strong and always center, they cost about $33.00 ea but well worth the added cost.
Old Yesterday, 02:22 PM
taurineman is offline
Find More Posts by taurineman
taurineman's Avatar
Wellington, New Zealand
Joined Sep 2009
81/82s are rubbish.
taurineman is offline Find More Posts by taurineman
Discussion Found some cool FPV T-shirts that don't suck blueoval16 FPV Racing 1 Jun 27, 2015 12:14 PM
Discussion Dems don't like Hillary all that much after all. madsci_guy Life, The Universe, and Politics 28 May 06, 2015 07:45 AM
Discussion Carmanufacturor LIPO cars that don't that don't explode mike314 Batteries and Chargers 5 Jul 24, 2011 09:43 AM
Discussion Servos in my HDE TREX don't go back to center Sky_Dancer Mini Helis 4 Mar 30, 2007 02:34 PM
CS-3 Micro Joule SX Servos HUNT and don't re-center. Menacer Scratchbuilt Indoor and Micro Models 1 May 30, 2005 03:51 PM
