Old Jun 26, 2015, 01:00 AM
Sideslip is online now
Find More Posts by Sideslip
Sideslip's Avatar
United States, MI, Parchment
Joined May 2004
[QUOTE=Marza Taxx;31994123]
Originally Posted by Sideslip View Post
OK, and how long will shipping take at that price? We here in MI can't usually fly much in December.
Get a pair od Dubro skis! You'll love winter flying.
B-r-r-r-r-r-r-r-r-r-r-
Me I'll watch your videos and fly in the gym.
Sideslip is online now Find More Posts by Sideslip
Old Jun 26, 2015, 07:21 AM
FlyingHobo is offline
Find More Posts by FlyingHobo
Deadalus' other child
FlyingHobo's Avatar
United States, TN, Gallatin
Joined Feb 2014
Yeah, Michigan winters get so cold it can hurt to breathe. Got in one battery in the UMX Yak in ND and had to stop so I could warm up enough to feel my face again.
FlyingHobo is offline Find More Posts by FlyingHobo
Old Jun 26, 2015, 10:05 PM
Marza Taxx is offline
Find More Posts by Marza Taxx
Marza Taxx's Avatar
Joined Mar 2014
yeah, it requires wearing a few layers, but it's so much more fun than the simulator.
I fly from a semi-smooth/rough field in the warm months. After a good 5 inches of snow the airfield is so smooth. It's awesome taking off and landing on a smooth runway.
Marza Taxx is offline Find More Posts by Marza Taxx
Old Yesterday, 06:37 AM
superduke1 is offline
Find More Posts by superduke1
Joined Mar 2012
Hi, I seem to be able to hover a PA Addition X reasonable well but I seem to struggle a bit with the 60" edge the throttle seems to aggresive and I find it hard to found the sweet spot with the throttle. I've changed the throttle curve to 14 36 50 64 100 as listed earlier in this thread. I'm running the Torque/ airboss combo, Revo blend 427 6S 3600 packs and a 16x7 Vox prop. Would a 16x6 help in hovering? Or maybe I just need more practice. I'm just looking for the best setup for hovering/ low and slow.
superduke1 is offline Find More Posts by superduke1
Old Yesterday, 07:26 AM
Luv3d is online now
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
duke-
I suspect it's a practice thing. You have a great setup to be able to hover for the entire battery pack. You might find it beneficial to reduce the expo on the rudder (it will help you make gentle corrections) and possibly the elevator as well.
Also, the throttle curve is nice, but not necessary. I started using a Throttle curve on my Edge as well, but only adjusted the points at mid-point and one spot above/below the mid-point to flatten it slightly. I didn't make any other modifications to mine- just sharing for your consideration.
Keep up the practice and you'll be torque rolling in no time!
Luv3d is online now Find More Posts by Luv3d
Old Yesterday, 07:38 AM
AeroKen is online now
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
Originally Posted by superduke1 View Post
Hi, I seem to be able to hover a PA Addition X reasonable well but I seem to struggle a bit with the 60" edge the throttle seems to adhesive and I find it hard to found the sweet spot with the throttle. I've changed the throttle curve to 14 36 50 64 100 as listed earlier in this thread. I'm running the Torque/ airboss combo, Revo blend 427 6S 3600 packs and a 16x7 Vox prop. Would a 16x6 help in hovering? Or maybe I just need more practice. I'm just looking for the best setup for hovering/ low and slow.
Try some debonder
I'm assuming you meant "too aggressive" there.
If by that you mean it's hard to keep the plane from rising or sinking, then you probably have the wrong throttle curve. Start with no curve at all and see if that's better. If not, try to determine about where on the throttle the hover point is - if you can recruit someone to watch the throttle stick while you attempt hovering they can tell you about what the average position was. Then make a throttle curve that moves the value for that stick position to the center of the throttle travel, and flattens the throttle out a little (not a lot) around it. Too much flattening is just as bad as too little. Flattening around the wrong center point is worse than no curve at all (this may be your current problem).
And of course practice.
AeroKen is online now Find More Posts by AeroKen
Old Yesterday, 01:52 PM
FlyingHobo's Avatar
Joined Feb 2014
Got my BEC bumped up to 7.4 volts, did an engine test, and played with my expo a little bit. Now I just have to wait for calmer winds and less chance of precip tomorrow and I'll finally get to maiden her. I can't wait
Old Yesterday, 05:48 PM
Shirty is online now
Find More Posts by Shirty
Aussies fly Down Under!
Shirty's Avatar
Australia, WA, Perth
Joined Oct 2012
Good luck! She's a real sweetheart. Easily one of my favourites.
Shirty is online now Find More Posts by Shirty
Old Yesterday, 09:56 PM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
No throttle curve, very little rudder expo (20 percent give or take)and a big investment in hover practice. This is what I used to get better at hovers with the edge.
Gravitycheat is offline Find More Posts by Gravitycheat
Old Yesterday, 11:40 PM
Sabin is offline
Find More Posts by Sabin
The cycle is complete.
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
Even if I could maiden my edge, I wouldn't.
http://www.coastreporter.net/news/lo...lert-1.1988902
Sabin is offline Find More Posts by Sabin
Old Yesterday, 11:50 PM
Joined Mar 2012
Thanks for all the feed back I've been out today and my hovering is starting to get better with the Edge. I see a few mixed reports about using a throttle curve. I'll reduce my rudder expo.
Old Today, 06:44 AM
Liberty10 is online now
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
Superduke. If you using the 12x6 prop and keep struggling. Try the 13x6 or13x6.5. THe larger prop will def. help. Just watch you temps if you get into the throttle a lot. Bigger prop means more air over the control surfaces
Liberty10 is online now Find More Posts by Liberty10
Old Today, 06:59 AM
Luv3d is online now
Luv3d's Avatar
Joined May 2010
Sabin- stay safe; the maiden can wait. You'll enjoy the plane when the opportunity presents itself for you to fly. We all know the wait stinks, too.
Wish you and your family well.
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 11525 Today 07:52 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
