Old Aug 26, 2014, 11:19 AM
Joined Aug 2014
Do you lose range if you use a lipo pack in your Transmitter
I was told today at my local hobby shop that if I put a lipo pack in my transmitter I would lose range. Is he just blowing smoke to get me to buy an over priced $50.00 nimh tx pack or is this true?
Neoburn1035 is offline Find More Posts by Neoburn1035
Old Aug 26, 2014, 11:23 AM
DonA's Avatar
United States, CA, Placerville
Joined Feb 2006
Your transmitter doesn't know what type battery is supplying power. As long as the max voltage of the battery is within limits for the transmitter, the battery type should not effect range in any way.
Having said that, some transmitters have built in low voltage detection that may not match the discharge profile of the alternate battery. You need to check what the voltage limits and at what voltage the transmitter will give a low voltage warning.
Don
DonA is online now Find More Posts by DonA
Old Aug 26, 2014, 11:26 AM
Joined Aug 2014
Thanks Don, that is what I thought. I will check I have a Spectrum DX7 that is a few years old I will check the specs and see.
Old Aug 26, 2014, 12:41 PM
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
As a general rule, if your tx did not come with a LiPO battery (which is a relatively recent event) the manufacturer will not warranty anything that's had a LiPO installed.
Your DX7 fits in that category.
Some folks don't care about manufacturer's recommendations and do it anyway. Be aware that if you do convert, you MUST make sure you have a way to limit the voltage from the LiPO as it will be higher than the NiMH. Also, you will not be able to charge the battery inside the tx, it must be removed.
My suggestion would be an Eneloop pack which will be in the price range you mentioned but those batteries are an extremely low self discharge NiMH cells and work great for tx's. You can also use your factory walwart to charge them.
Finally, it's always confused me when guys spend a lot of money on RC stuff which all depends on the batteries used and how they are cared for and charged or cycled, then they buy the cheapest batteries they can find.... JMHO.
Zeeb is offline Find More Posts by Zeeb
Old Aug 26, 2014, 01:05 PM
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
I also hold the opinion that Eneloops are easier to deal with when it comes to TX batteries.
However, the TX electronics work on 5V and the RF circuit on 2.4Ghz radios works on 3.3V, so anything above that level will do. Should your radio work with linear regulators, more voltage will mean more heat, but I have yet to hear about a TX where this caused problems. Old MHz gear was sometimes directly powered from the battery voltage, and here it had a considerable influence.
Julez is offline Find More Posts by Julez
Old Aug 26, 2014, 01:29 PM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
If the battery voltage is not within the operating voltage range of the Tx then the Tx may not work at all, or may be damaged due to over voltage.
But one thing is for sure it wont operate at reduced range.. So yes, the guy in the shop was blowing smoke.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Aug 26, 2014, 01:31 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
I agree that for most it's best to stick with LSD Nimh for "legacy" 8 cell transmitters.
Having a more modern Tx designed for 6 cells (Futaba 8FG) and having user adjustable low voltage makes a 2S lipo designed for transmitter use a good alternative to the stock 6 cell Nimh pack for me. When using a Lipo in a Tx the most important consideration is making sure the battery is designed for low drain use and has low C rating of around 5C, since low C rated cells are more stable than high C rated cells, and they're not as finicky about being left fully charged for long periods of time.
I have 3 seasons now on a 2S Lipo from Value Hobby and it's still going strong.
I prefer charging up the lipo with a Cellpro Multi4 at the field during a lunch or coffee break to remembering to put it on the overnite slow charge for an Nimh battery.
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Aug 26, 2014, 01:46 PM
United States, VA, Blacksburg
Joined Aug 2013
What about those LiPo packs from Hobby King that they say is for the DX8? I have one in mine and it is definitely higher voltage. The Tx seems fine but I don't want to do any damage to it long term. Is this pack OK?
maranello993 is online now Find More Posts by maranello993
Old Aug 26, 2014, 01:57 PM
pilotpete2's Avatar
Joined Jun 2004
The HK DX8 battery is a 2S Lipo, so exactly the same voltage as the optional Spektrum Lipo, just a LOT cheaper. The important fact is that the DX8 is designed for 2S Lipo operation as well as 4 cell Nimh, so no problem.
Pete
Old Aug 26, 2014, 03:00 PM
Aberdeen
Joined Mar 2006
Yes, as noted above, the DX8 is designed for a 2s LiPo. i used my DX8 with the Turnigy LiPo all the time I had it and it worked great. You just need to go into the setup and select LiPo.
Old Aug 26, 2014, 06:34 PM
Livin' the Dream
Promo's Avatar
United States, UT, Vineyard
Joined Dec 2011
I used HK's TX lipo packs in my old DX7s and DX8.....they work OK but there are some quality issues. In my DX9 I run a Pulse TX 4000mAH Lipo (about twice the cost of HK junk). When it comes to Lipo batteries Pulse is one of the best IMO!
Promo is offline Find More Posts by Promo
Old Aug 26, 2014, 09:12 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
As long as you get a battery with the voltage in the proper range the low battery alarm can be re-set on the DX7 for LiPo use. There is a You-Tube video that shows you how.
davidmc36 is offline Find More Posts by davidmc36
Old Yesterday, 08:05 AM
Barbados
Joined Jan 2011
Yes endloop batts are a much better solution than OEM nimh batts,the newer Tx's are lipo compatible as my A9 radio,i use lipo's because I use lots of 2s batts and the Tx batt goes on in parallel with flt packs,ever so much more convienent for my uses.My Tx lipo came from RC Accessory and it's been great 2yrs.
The Tug is offline Find More Posts by The Tug
Old Yesterday, 09:26 AM
Georgia
Joined Jun 2007
All the Pulse Lipos I bought ballooned while at 3.85 volt per cell storage.
(Two green, two red)
Two had never been flown. (5S,6S, 5000mah
chuck75 is offline Find More Posts by chuck75
Old Yesterday, 10:04 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
That makes them the best? Easy to please, are ya?
mw
Mark Wood is offline Find More Posts by Mark Wood
Discussion lipo can't be fired if you use a great ballance charger,what ballance charger do you andylaw500 Batteries and Chargers 0 Apr 21, 2014 12:52 AM
Discussion What expo settings do you use in your aileron,elevator and rudder? Pakingzzz Electric Heli Talk 32 Nov 18, 2013 12:24 PM
Poll Presidential Poll: What Will YOU Do If Your Candidate Loses the Nomination? Highflight Life, The Universe, and Politics 77 Jan 10, 2012 10:19 AM
Poll Do you use red (permanent) threadlock in your builds? (If so, where?) Harrow Large Electric Helis 6 Jan 05, 2012 12:49 PM
Discussion how do you tell if you have a dead cell in your pack AzJason Batteries and Chargers 4 May 12, 2006 06:27 PM
