Old Dec 08, 2013, 09:05 AM
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
ESM F4U Corsair Color F 74" Wingspan Model ARF
I've read a few members are about to assemble this ARF. This thread is a place we can share info as we go. I am in the waiting for delivery stage
my plans include :
EVO35GT or PTE36 gas motor and sierra gear in hand.
What size tires fit this model?
What have you got in mind for your model?
Post questions and answers
scootrb4 is online now Find More Posts by scootrb4
Old Dec 09, 2013, 03:59 PM
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
I have a saito 170 radial for mine. Sierra retracts.
kahloq is offline Find More Posts by kahloq
Old Dec 09, 2013, 05:18 PM
scootrb4's Avatar
Joined Nov 2011
I'm jealous - watched about every radial corsair video on utube before I settled upon what I had
But I have the Sierras (by accident) and the kit has arrived today!
The stock tank is 550cc or 18.7 oz
Old Dec 09, 2013, 08:39 PM
scootrb4's Avatar
Joined Nov 2011
I see the 170 Saito weights 46oz (engine only)
My EVO35 weights 53
I have batteries, ignition, & muffler to add.
Does anybody know how much weight is required total to balance this plane out + or -?
I bought the mechanical tailwheel retract from eBay (2.2 oz)
The cowl is 8 inches across and 5.75 deep
This is about 1 inch wider than the CMP 75" model
Old Dec 09, 2013, 10:19 PM
kahloq's Avatar
Joined Dec 2005
I also have an onboard glow unit and 6v battery to go upfront
Old Dec 09, 2013, 10:36 PM
scootrb4's Avatar
Joined Nov 2011
I hope its a lawnmower battery
I have 2 6v 2000 mah for this plane they weigh 3.8 each. One ignition and one receiver.
But I don't know if all this weight will be needed up front. Once I get the motor on I can get an idea. I just wondered if anybody reading could say what it took to balance theirs.
And speaking of balance - where is the real CG?
At 8 inches wide this cowl would host a twin ......
Old Dec 09, 2013, 10:45 PM
scootrb4's Avatar
Joined Nov 2011
I saw on utube a gentleman had the DLE55 in it and said it balanced without added weight.
Old Dec 10, 2013, 11:47 AM
kahloq's Avatar
Joined Dec 2005
Friend has one with a saito 200 radial and he had to cantilever the rx and onboard glow 6v 2000's out over the engine for balance.
Old Dec 10, 2013, 03:14 PM
scootrb4's Avatar
Joined Nov 2011
Saito 200 = 50.8 oz
Good to know.
6v 2000 mh & ignition about 4 oz
I don't know what the OBG system weighs
Old Dec 10, 2013, 07:10 PM
kahloq's Avatar
Joined Dec 2005
Onboard glow unit would weigh about the same as a CDI for a gas motor...almost the same size box. Lots of wires too...especially for a 3 cyl radial......so same basic weight as the wire plug/cap for a gas engine
Old Dec 10, 2013, 08:27 PM
scootrb4's Avatar
Joined Nov 2011
Sounds like I'm going to end up a little heavy and I probably won't need 'everything' ahead of the FW - good news for the retractable tail wheel idea. My wife is gone for 3 days, the F4U sits on the kitchen table - LOL
Old Dec 11, 2013, 10:59 PM
Australia, QLD
Joined Sep 2010
G'day all,
I have had my ESM Corsair for a month or two so far, the Engine is a DLA35 RA, will be using the ESM Air retracts, other than that JR radio gear.
So far I have the Rudder and Elevators fitted and working, I used Pull, Pull for the Rudder, but I use 2 servos and C/F push rods for the Elevators, all connections are internal.
The Engine is fitted, Cowl is on, I fit the Cowl first, then get the Engine lined up with the Cowl, then fit the engine, beef up the inside of the firewall with F/Glass.
I changed the fuel tank position, lifted it higher in the fuselage and moved it rearward, closer to the CofG
Flaps, I didnt like the look of the Kit system, I found info on RCU by P-51 Tom, and used something like that, a bit complicated but more scale, they are on and working, I used a web between each of the Flaps.
Not sure about a retract tail wheel as yet, I am looking at fitting main Wheel doors, something simple, spring open then when the wheels retract they pull them closed.
I like the ESM 72 inch range of models, have the P-47, DLE 30, the P-51B with an RCG 30, the Typhoon with an RCG 30, had the Spitfire, but it died, waiting for them to come in stock again.
I hope to fly the Corsair before Xmas, will post some photos of it before then,
Oldtimer.
oldtimer47 is offline Find More Posts by oldtimer47
Old Dec 12, 2013, 12:42 AM
scootrb4's Avatar
Joined Nov 2011
Originally Posted by oldtimer47 View Post
G'day all,
Oldtimer.
Good to have your input. What CG are u using? Do you have a link to the flap mod at RCU? The tail retract I got is the same as sold on TBM.
Old Dec 12, 2013, 05:26 AM
Australia, QLD
Joined Sep 2010
G'day, here is the link, almost the bottom of the page.
http://www.rcuniverse.com/forum/rc-w...orsair-48.html
as to CofG I will be going 100mm, maybe 105mm, same as I run on all the other ESM Kits, that way I know it will fly, I can move it after I have flown it. attached is a photo of the hinge setup I used.
Oldtimer
Old Dec 20, 2013, 02:30 AM
BDK74's Avatar
United States, CA, Redondo Beach
Joined Sep 2012
I just picked one of these up today. Not sure if I'm ready to dive into it. Where will I stop???
BDK74 is offline Find More Posts by BDK74
Sold F-4U Corsair ARF by Hanger 9, 60 size NIB rcrube Aircraft - Fuel - Airplanes (FS/W) 3 Dec 04, 2013 12:50 AM
Sold 5-CH AirField1430mm F4U Corsair ARF w/ Motor/ESC/Retracts $100 Winterdd Aircraft - Electric - Airplanes (FS/W) 2 Oct 09, 2013 01:55 PM
Build Log ESM 74" F4U Corsair strictlyscale Glow to Electric Conversions 325 Sep 11, 2013 12:53 AM
Wanted NIB ESM 85 in Corsair ARF or TF Giant ARF Corsair NIB Fastandlow Aircraft - Fuel - Airplanes (FS/W) 3 Dec 20, 2012 01:08 PM
Sold ESM DHC-2 Beaver Color A Green and Yellow 95" Wingspan Model ARF Airplane Go4it Aircraft - Fuel - Airplanes (FS/W) 1 May 31, 2012 03:58 AM
