Old Dec 06, 2015, 02:13 PM
AJWoods is offline
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Build Log
T-70 X-Wing, Y-Wing, A-Wing and other Star Wars Builds (all with plans!)
The past year, I've been doing a variety of Star Wars related builds, mostly based around multi rotor setups. I've wanted to do an X-Wing, but I wanted it to work as a proper plane. Airhogs came out with a 2 channel version earlier this fall, but performance was rather poor, and it relied on a clear plastic canard to trim.
I started out making a chuck glider "scaled" to match the line of 3.75" figure toys Hasbro makes. This gives it a ~20 inch wingspan. I used the same electronics I usually put in my little twin builds (delteng RX34D, HK1.7g servos, MMM motors on Hubsan props)
Surprisingly it flies much better than I expected. Going to do a painted version today, and try to get plans up shortly.
T-70 X-Wing Preview (4 min 45 sec)
Flying starts at around 3:50
-Adam
AJWoods is offline Find More Posts by AJWoods
Old Dec 06, 2015, 11:06 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Got the new set of parts cut, painted, and weathered. Did a wash on it to dirty up the white, and fill in the panel lines.
-A
Old Dec 07, 2015, 09:07 AM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Cool!!!!
ruzam is offline Find More Posts by ruzam
Old Dec 07, 2015, 05:33 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Very cool!
Petefoss is offline Find More Posts by Petefoss
Old Dec 07, 2015, 10:55 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
AJWoods:
Outstanding job on the T-70 X-Wing. It was a treat to see it fly.
Regards, Dave-
foamdave is offline Find More Posts by foamdave
Old Dec 08, 2015, 12:53 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Thanks guys!
I got it assembled this evening. I really like the look of the black wash. I think I'll do it to some of my existing planes, like the flapjacks.
Just need to swap the gear over from the boilerplate version.
For once, all of the cuts worked as drawn. I was worried about getting the cutout for the wings appropriately sized to get the wings at the proper di/anhedral, but it came out just right. I'll get the plans up soon
-A
Old Dec 08, 2015, 08:31 AM
ruzam is offline
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Wow! She looks fantastic!
I'm curious just how much flyability you'd loose if you sheeted the fuselage over and turned it into a full body.
Old Dec 08, 2015, 10:15 AM
HanksGB is offline
Find More Posts by HanksGB
confused poet
HanksGB's Avatar
USA, CA, Orange
Joined Feb 2004
Adam,
Very cool. I can't wait to see how the painted one turns out.
Hank
HanksGB is offline Find More Posts by HanksGB
Old Dec 09, 2015, 12:53 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Right now the CG is right at the leading edge of the wing, indicating that the forward fuse is working as a big strake, or crappy canard. I fear that boxing it out, would reduce the effectiveness of that surface area, and make the plane untrimable. Although, never know until you try I guess.
Old Dec 09, 2015, 01:12 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
All done and flyable again. Put a 0.5mm rod between the laser's to keep them from flopping, you could get away without them, but it definitely stiffens things up.
Old Dec 09, 2015, 06:09 AM
deadbird is offline
Find More Posts by deadbird
Crashing with style
deadbird's Avatar
UK. Dorset
Joined Jun 2009
One of the most exciting builds I've seen for a long time Mr Woods. I cant believe it flies so well - but that's entirely down to your expertise. I cant imagine what other airborne vehicles from sci-fi films you could produce!
Have you spoken to Mr Lucas about putting it into production?
Jon
deadbird is offline Find More Posts by deadbird
Old Dec 09, 2015, 06:58 AM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Very cool Adam. Can't wait for the plans.
Is it differential thrust plus elevons?
Pete
PS. Do you have a thread on the Tie fighter quad or just the youtube video?
Old Dec 09, 2015, 10:56 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Jon
Thanks! It's one of my favorite creations so far. Usually these weird thing "fly" OK, but this one came out as a decent slow flyer
I know a couple of folks with connections to ILM, so maybe the footage will make it's way to the Great Bearded One.
-A
Old Dec 09, 2015, 10:59 AM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Pete
Yup, same controls setup as pretty much all the other twins. I had to swap the fets on the RX34D to get them to support running two 8.5mm motors.
No build thread on the TE, but here are some photos http://imgur.com/a/FQzo0
Old Dec 09, 2015, 03:13 PM
AJWoods is offline
AJWoods's Avatar
Joined Jul 2005
Remote Control T70 X-Wing -- The Force Awakens (1 min 50 sec)
For Sale REDUCED - Hacker X-70 and X-12 ROLLING CIRCLE Aircraft - Electric - Power Systems (FS/W) 0 Jun 27, 2015 11:52 PM
Discussion Naza can't handle gains over 70/70 atbtomaha Multirotor Talk 4 May 03, 2015 12:16 PM
Discussion T-MOTOR 15 X 5.5 vs T-MOTOR 15 X 5 Props J.Marques Multirotor Talk 2 Oct 06, 2014 03:02 PM
Discussion Hacker X-70 Pro esc soft-start isn't so soft Al P Power Systems 15 Dec 22, 2006 04:41 AM
Why aren't there more 70+inch span flying wings? fly1milehi Slope 99 Apr 12, 2005 07:13 AM
