Old Oct 28, 2015, 08:32 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
Old Dog, Old Ways. New Tricks, BLAHHHHH!
I have several design programs, none that I care for. While trying to get
some plans together for a forum member, two days in a row, the power
went off while I was working. I save every fifteen to thirty minutes, but
I still lost a lot of work both times.
No More Computer Aided Design! I am unloading the programs.
Went to Hobby Lobby, bought a couple T-squares, some erasers, got
plenty of pencils triangles, french curves, rulers. Bought a pad of cheap
paper. Just has to last long enough to get to the print shop and have them
scanned. ON A Damned computer, but what else can I do??? Make stone
plates and print them on palm leaves?
And a desk top drafting table. I love it. Got the plans done in a couple hours.
Take them to the print shop tomorrow. Get them on the site mid day.
This is how I learned to do it, over fifty years ago. And I did it this way
for over forty years.
BHOFM is offline Find More Posts by BHOFM
Old Oct 28, 2015, 08:44 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Got a drawer full of them funny triangular plastic thinggies, and still use them, but I like Sketchup for anything I want real precision for. I finally broke down and got coreldraw6 when I found a pack for under $200, and now I can design in sketchup, export as .dxf and read into Corel for final tweaks before handing over to my favorite laser gal for cutting (it's so easy to get spoiled - even do prototypes this way)
I feel your pain, though all the above only works when power is on! And, I wouldn't have a clue how to use Sketchup if I hadn't been in drafting/engineering for 36yrs. (Fisher Body Engineering drafting school! - triangles and compasses, 4H, french curves, etc, etc.
springer is offline Find More Posts by springer
Old Oct 28, 2015, 09:01 PM
blvdbuzzard is offline
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
People laugh at me. I have a drafting setup too. I can draw a set of simple plans in a hour or so. Simple line drawings mind you. I have a couple CAD programs and for simple things, I find the paper, pencil, 3 sided thingies work great. My friends son was looking at a set of my compasses in a nice fitted case. He asked why the end had this funny looking jaw. They were my inking set. When I told him how the old blue prints were made, he asked why they did not print them? I explained this was long before there was a computer or a ink printer. He had the funnest look on his face, like I was describing life in the stone age. Sort of fun to be old enough to remember when.
Buzz.
blvdbuzzard is offline Find More Posts by blvdbuzzard
Old Oct 28, 2015, 09:05 PM
basicguy is offline
Find More Posts by basicguy
Dream it...Build it...Fly it!
basicguy's Avatar
United States, MO, Macon County
Joined Dec 2014
I like the simplicity of non computer design. Finally got one of my old windows computers going and put sketchup on it. Drew a box section fuselage on it, like a OSG but can't figure out how to lay the 3D construction panels out flat.
I tend to draw a sketch on piece of paper then lay it out on foam. When I make a fuselage I draw the sides and then figure out what should fit in the middle for top and bottom. I use carpenter and machinist tools to make it work.
basicguy is offline Find More Posts by basicguy
Old Oct 28, 2015, 09:10 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
A lot of times I just draw the plans on the foam board and start cutting. The P-38 is just a
3 view I found online and printed the size I wanted. Not rocket science.
Old Oct 28, 2015, 09:22 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
I like the desk top table, folds up and goes behind the door. Space is a premium in my shop room.
Old Oct 28, 2015, 09:30 PM
basicguy is offline
basicguy's Avatar
Joined Dec 2014
What is the model in post 1, is a balsa conversion?
Have found that I like adding some balsa into the foam, seems to make it more rigid without much weight.
Old Oct 28, 2015, 09:44 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
It is a 20" O-Fungle. You can use the plans for any size so I just did the 20" because it was easy.
And it is all balsa.
40" version.
Old Oct 29, 2015, 12:00 AM
georgy is offline
Find More Posts by georgy
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
C-A-D... Tried it, but clearly my patience is sorely lacking!
So i use an old-school projector. Simply move it back & forward till you have the size you want and trace!
Templates are simple A4 3-views printed and cut out by scissor...
You just gotto watch the distortion. So i mostly just do one-half template and just use it mirror image to get a perfectly symmetrical shape..
Real easy, real old-tech.... real happy with it!
georgy is offline Find More Posts by georgy
Old Oct 29, 2015, 07:10 AM
compressor man is offline
Find More Posts by compressor man
Professional tree finder
compressor man's Avatar
GA,USA
Joined Jul 2010
Hundreds of years from now scientists will create a medium for recording information. It will be a revolutionary invention capable of working in the worst conditions and across all platforms. It will have astonishing archival properties and no special software is required to read nor will there be required updates. Whats more, it will never become obsolete and be unable to be read by newer machines/computers.
They will call it paper.
compressor man is offline Find More Posts by compressor man
Old Oct 29, 2015, 07:57 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I kind of enjoy making drawings for plans. Drafting was one of the few things I was any good at in school.
Still use all the hardware as well as a hand held calculator to blow up 3 view drawings to the size I want. I draw them out on butcher paper, cut them out and trace onto poster board for templates.
Part of the enjoyment of scratchbuilding unusual planes you never see kitted.
P.S. Compressor Man:: Most people don't know what flypaper is.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Oct 29, 2015, 09:25 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Old way is still the best way ... JMHO2
gpw is offline Find More Posts by gpw
Old Oct 29, 2015, 10:51 AM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
Plans? Who's heard of such nonsense?
goldguy is offline Find More Posts by goldguy
Old Oct 29, 2015, 11:10 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
I agree, but others want them.
Old Oct 29, 2015, 11:59 AM
georgy is offline
georgy's Avatar
Joined Jan 2012
I recently ventured into the obscure world of correx/corroflue.. built a couple of slot jest with the stuff.
Posted my bunglings on my local forum and was hounded for plans.
So i made some simple templates and posted them. Took me 2 whole nights to make them.. just simple templates! Not even proper plans..
Took me only one eve the cut and build the entire airframe! So i got a lotta new found respect for the gents that regularly post plans!
Discussion New tricks for the Old Dog?! Jim Hatch Foamies (Scratchbuilt) 9 Nov 30, 2009 07:39 PM
Discussion Old Dog....new tricks. Warning OT tim slocum Dock Talk 16 Jun 06, 2009 02:00 PM
we have taught and old dog a few new tricks 3D NUT 3D / Fun Fly Fuel Planes 6 Nov 23, 2005 07:08 PM
