Old Aug 11, 2015, 01:40 AM
TheMadCADer is online now
Find More Posts by TheMadCADer
Always Building
TheMadCADer's Avatar
United States
Joined Sep 2012
New Product
~$10 Extemely Tiny FlySky Receiver
http://www.banggood.com/FLYSKY-Ultra...733432201408CW
Description:
Brand Name: Flysky
Frequency: 2.4G
Channel: 8CH
Net Weight: 0.6g
Opreating Voltage: 1S~3S
Applicability:
FS T6,TH9X
Gun-type remote control: FS GT2B,GT3,GT3B,GT3C etc.
Tuner: FS ER9X,OPENTX etc.
Walkera D7E,D10 etc.
Optional "8 channel servo signal" (A)or "7 channel servo signal+PPM"(B)
Package Included:
1x FLYSKY 2.4G Ultra Miniature 8CH Receiver
TheMadCADer is online now Find More Posts by TheMadCADer
Old Aug 11, 2015, 10:23 AM
Cereal_Killer is offline
Find More Posts by Cereal_Killer
No phones to control drones
United States, OH, Columbus
Joined Dec 2014
Why the heck is there one freaking component on the back of it so it doesn't sit flat?
Cereal_Killer is offline Find More Posts by Cereal_Killer
Old Aug 26, 2015, 06:32 AM
zdenekt is offline
Find More Posts by zdenekt
Joined Jun 2009
How to bind?
Does anyone know where to get the manual?
Or at least how to bind it with transmitter?
zdenekt is offline Find More Posts by zdenekt
Old Sep 08, 2015, 06:37 AM
montis is offline
Find More Posts by montis
Lithuania, Vilnius County, Vilnius
Joined Dec 2006
I'm reposting some anonymous review:
"... receiver is very tiny. There is no bind pin, because it is an "autobind" procedure just like with small quadcopters. When switch on, receiver tries to bind with transmitter for about 3s (led is blinking). If receiver find a transmitter (must be also in bind mode) then it records transmitter identifier and works with it. If it can't bind with a transmitter then is retrieves previously bind transmitter identifier and works with it. This way, you save an extra pin and just need to bind only once. After bind procedure, If reception is ok then led if on, if no reception at all led if off, if reception if bad led is blinking ramdomly. I have tested this receiver with a small quadcopter transmitter (H36, compatible with flysky protocol) and it works really well. PPM and channel signals are "clean" on oscilloscope and range seems really good. More over, i think that we could increase range with a dipole antenna instead of original monopole antenna (easy to do because there is a ground pad just close to antenna pad)."
So it looks very promising.
montis is offline Find More Posts by montis
Old Sep 11, 2015, 12:36 PM
LumpyLouis is offline
Find More Posts by LumpyLouis
United States, VA, Alexandria
Joined Nov 2012
I'm looking to pair my FS-i6 with a programmable FC for a brushed micro quad. The AlienWii is really expensive and unavailable all the time. Any other suggestions on brushed FCs?
LumpyLouis is offline Find More Posts by LumpyLouis
Old Sep 11, 2015, 07:02 PM
AnthonysQuad is offline
Find More Posts by AnthonysQuad
Happy Holidays
AnthonysQuad's Avatar
Joined Jan 2013
Its not 10 dollars its 10.96 cents
AnthonysQuad is offline Find More Posts by AnthonysQuad
Old Sep 12, 2015, 08:45 AM
Always Building
United States
Joined Sep 2012
Good point (I fixed the title).
Old Sep 12, 2015, 01:45 PM
montis is offline
Joined Dec 2006
I have bought this receiver for less than 10$ You just have to wait for sale or use discount code.
Old Sep 12, 2015, 01:48 PM
Always Building
United States
Joined Sep 2012
Gosh guys, you make this so complicated.
Title changed again (for the last time).
Old Sep 12, 2015, 03:08 PM
montis is offline
Joined Dec 2006
Forget the title I am waiting to try this little receiver. Will post my opinion - is it worth 11$
Old Nov 13, 2015, 01:39 AM
Mr.Runster is online now
Find More Posts by Mr.Runster
It's Cody Reed!
Mr.Runster's Avatar
United States, AZ, Flagstaff
Joined Jan 2015
Any updates on this little guy? I'm confused as to how it hooks up. Are you able to solder the servo signal wires to the ch1-8 tabs and the power and ground wires to the vin and gnd pads? Or is this only compatible with a flight controller and you can not attach servos directly to it?
Mr.Runster is online now Find More Posts by Mr.Runster
Old Nov 14, 2015, 04:07 AM
Ian444 is offline
Find More Posts by Ian444
Brisbane, Australia
Joined Apr 2013
I think it should drive servos directly. I have one but have not connected it to anything yet, waiting for some other parts.
Ian444 is offline Find More Posts by Ian444
Old Nov 19, 2015, 01:47 AM
It's Cody Reed!
Mr.Runster's Avatar
Joined Jan 2015
Ian444 have you hooked it up to try it out yet?
Old Nov 19, 2015, 07:29 AM
montis is offline
Joined Dec 2006
I have received it. It is soo tiny! The smallest of all my receivers
Look at the comparison with servo plug:
Description: Compare it to the regular servo plug
Obviosly you need a thinner wires to wire it up. Receiver has 1.25mm pin spacing.
Have not tried to hook it up yet, still have to do some soldering wok
Old Nov 19, 2015, 08:56 AM
Joined Dec 2014
How do you specify you want the B version that does PPM? I'd be willing to give this a shot on my CJMCU micro quad board (but I still can't believe how dumb it is to have a single component on the back of this thing!!)
What are you guys using as a tx? I'd be using my devo.
Sold flysky FS - I 10 10 CH 2.4 GHZ TRANSMITTER 225.00 SHIPPED greatplanes Aircraft - General - Radio Equipment (FS/W) 4 Jul 07, 2015 09:40 AM
Discussion Spektrum 7ch or FlySky fsi-10 CanadianEhh Electric Plane Talk 7 Apr 29, 2015 11:03 PM
Sold Turnigy 9XR Transmitter, FlySky Module, and FlySky Receivers DirtyDovi Aircraft - General - Radio Equipment (FS/W) 2 Mar 28, 2015 05:57 PM
Sold 6 New Flysky FS-GT2 3CH 2.4GHz 3-ch Receiver for 1/8 1/10 Rc Car Boat Transmitter wc_wickedclown Cars - Accessories (FS/W) 1 Dec 20, 2014 11:30 PM
For Sale FlySky 2.4 8ch receiver $10 John Kim Aircraft - General - Radio Equipment (FS/W) 0 Mar 08, 2011 02:32 PM
