Old Aug 07, 2015, 06:13 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Important reading about the Vbar governor:
http://www.helifreak.com/showthread.php?t=601719
The electric defaults are too high for big helis, it needs to be more like 15-20 rather than 25-30 as the software defaults suggest. The lower gain is also easier on your ESC.
On my Xtreme 600 lowering the gov gain to 15 and raising the collective and cyclic add to 40 finally eliminated the twitch in hover and tail kick that has plagued it since I replaced the Robird with a GV8000. I don't even need to increase the tail precomp above the default of 22 anymore.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Aug 15, 2015, 04:11 AM
Black_Angel is online now
Find More Posts by Black_Angel
Black_Angel's Avatar
Joined Jan 2015
Im doing final setup up on my trex 500 with kbar / vstabi and got a surprice when im on Cyclic setup: Cyclic trow in vstabi. After pressing Start position, then Measure, then to my surprise i see my rotor move to minus 8 not pluss 8 as it normally do...
I really have no idea how this happend...everything else working as it show with right directions etc
Edit: solved.. I just find out i messured in front not over tailboom.
BA
Black_Angel is online now Find More Posts by Black_Angel
Old Aug 31, 2015, 04:45 PM
microrcfiend is online now
Find More Posts by microrcfiend
microrcfiend's Avatar
United Kingdom, England, Sheffield
Joined Jun 2012
I was having trouble with a 450 bogging badly when trying aileron tic tocs but could just about manage elevator ones. I was going to ask here for advice but on suggestion for a friend, lowered the agility from max 120 down to 95. It made them actually possible with ok collective management of my Fubar 3S and then lowering the style slider to minimum transformed the cyclic fluidity too.
So if anyone is maxing out that agility slider thinking above 100 is working for them, might be worth lowering a touch. It was flying well before but this really helped. Is there anything else I can do to increase agility on the cyclic without being inefficient and inducing more bogging?
Trex 450 - fbl style slider from 90 down to 60 (4 min 39 sec)
microrcfiend is online now Find More Posts by microrcfiend
Old Sep 01, 2015, 08:21 AM
ForceFedDSM is offline
Find More Posts by ForceFedDSM
ForceFedDSM's Avatar
Massachusetts
Joined Jun 2008
Do any units support the use of the vcontrol radio? Basically can any of the units(kbar, sbar, fubar) be updated to 6.0?
ForceFedDSM is offline Find More Posts by ForceFedDSM
Old Sep 01, 2015, 07:50 PM
ridge_racer is online now
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
No unfortunately you can not update the FW since they are not real vbars.
ridge_racer is online now Find More Posts by ridge_racer
Old Sep 02, 2015, 04:03 AM
MikeHRC is online now
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
There was also a rumour (not sure if it was ever confirmed) that if you try to update the firmware in your K-bar, that Mikado's software would brick it...
MikeHRC is online now Find More Posts by MikeHRC
Old Sep 03, 2015, 06:54 AM
Crasy666 is online now
Find More Posts by Crasy666
Crasy666's Avatar
Germany, BY, Nord
Joined Oct 2012
I am quite sure it is not just a rumour, the not real vbars could have an adapted FW e.g. to work with different Gyros, so if you flash here the newest one (if you anyway are able to get the V6 which is not in public available) than you will brick your FBL...
I think it was always clear, that you will be never able to update a kbar fubar or any other not real vbar....
Crasy666 is online now Find More Posts by Crasy666
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 15, 2013 07:40 PM
For Sale Vintage Techi Models Mini Bar Fli pattern kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 28, 2013 02:27 PM
Sold Mikado Mini V-Bar Pro with 2 DSMX satts. e-heliflyer Aircraft - Electric - Helis (FS/W) 0 Jan 16, 2013 04:11 PM
Sold Mini V-Bar "Blueline" 5.3 Pro xxrando Aircraft - Electric - Helis (FS/W) 0 Jan 02, 2013 09:36 AM
Sold Vintage Free Flight Midwest FU-BAR '36' 1/2A Kit NIB $45.00 FREE SHIPPING!! stevster Aircraft - Fuel - Airplanes (FS/W) 2 Jan 14, 2012 08:07 PM
