Old Aug 30, 2015, 08:12 PM
AkumaZeto is online now
Find More Posts by AkumaZeto
United States, WI, Eau Claire
Joined Dec 2014
Originally Posted by GFergy View Post
Because the plastic retract well is squared and so is the retract. It's like a box within a box.
I got it figured out thanks. I LOVE THIS BIRD. However it sucks it is so light. I mean its like paper compaired to other 1400mm birds. Its doomed for nose overs. I started just belly landing it. It has less physical impact that way than nosing over.
AkumaZeto is online now Find More Posts by AkumaZeto
Old Aug 30, 2015, 08:43 PM
Joined Dec 2014
also is their a diffrent motor mount that could be used?
Old Aug 31, 2015, 10:30 AM
TwistedGrin is offline
Find More Posts by TwistedGrin
Yes it was Abby Normal
Joined May 2012
Just to make sure....are you flipping to high rates and using full elevator UP while on the ground. This is nearly mandatory procedure on nearly "All" warbirds (there are some exceptions).
I was able to prevent nose overs before I modified my airframes landing gear to rake forward, but it was a delicate balance......much better results and very few if any nose over after the landing gear modification.
Flipping to highest rate elevator up anytime on the ground including landings as soon as the mains touch down and absolutely any taxi durations
TwistedGrin
TwistedGrin is offline Find More Posts by TwistedGrin
Old Aug 31, 2015, 10:46 AM
GFergy is offline
Find More Posts by GFergy
New York Highlander
GFergy's Avatar
United States, NY, Vermontville
Joined Apr 2012
+1 for the high rate elevator! I find it a must for the PZ SE5a as well.
GFergy is offline Find More Posts by GFergy
Old Aug 31, 2015, 10:47 AM
Joined Dec 2014
Yes full elevator on ground. It mostly happens after the plane starts to slow a tad after touching down. I am on pavement that is smooth as silk too.
Old Aug 31, 2015, 10:55 AM
GFergy is offline
New York Highlander
GFergy's Avatar
Joined Apr 2012
Yeah she can be a bit nosey on the ground, especially on grass. I've done the forward rake mod and that did help, but I have found that you still need to feather the throttle along with full up elevator as she slows down after landing, just to keep the tail planted.
Old Aug 31, 2015, 09:14 PM
Joined Dec 2014
any quality rubber tires out there
Old Aug 31, 2015, 11:18 PM
cherubs 9 is offline
Find More Posts by cherubs 9
cherubs 9's Avatar
Joined Jan 2013
I use 2.75" Du-Bro low bounce. Very quiet and makes my landings look good.
cherubs 9 is offline Find More Posts by cherubs 9
Old Aug 31, 2015, 11:19 PM
Tartago is offline
Find More Posts by Tartago
Back to EDF
Tartago's Avatar
Joined Apr 2006
That's strange. On pavement I've never had nose over issues.
I let her touch on mains and input a little up elevator, after the speed is flared I input full elevator to sit her tail.
My CG is neutral.
Tartago is offline Find More Posts by Tartago
Old Sep 01, 2015, 12:39 PM
CarToon is offline
Find More Posts by CarToon
CarToon's Avatar
Los Angeles
Joined Feb 2011
I have Robarts on mine.
CarToon is offline Find More Posts by CarToon
Discussion wanted taiyo zero a6m zeke a6m5c mitsubishi thingy alsaplenty Parkflyers 2 Apr 15, 2009 01:26 PM
Looking for Mitsubishi A6M Zero 3-Views KSU Flyer Scale Kit/Scratch Built 5 Jul 18, 2008 09:50 PM
Discussion My 8" Mitsubishi A6M Zero gguy Scratchbuilt Indoor and Micro Models 19 Nov 14, 2007 01:08 PM
Mitsubishi A6M Zero JetTech Parkflyers 6 Nov 01, 2004 09:53 AM
