Old Feb 09, 2013, 07:07 PM
Joined Jan 2009
tamjets TJ80 pnp with 1509 2y with cc 100 lite
I'm putting this in a new Habu 32. Is the bec in the cc 100 lite in the tail cone OK for this jet. With 8 servos (although 4-5 servos most of the time while flying) this seems to be asking a lot. I've got a stock setup with an onboard 1100 life battery. Also has anyone tried 9s with this? I realize the esc should stay quite cool being where Tam has located it, but I believe the bec in it is only good for 5 amps. Any info from users with this setup will be greatly appreciated. thanks Stephan. ps. I've got 260 flights now on the stock one and still going strong. new 65c batteries and it's flying level at 128 mph. !!!
stmbike is online now Find More Posts by stmbike
Old Feb 09, 2013, 07:20 PM
The jet age began...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
260 flights and you are still counting?...
ysolomon is offline Find More Posts by ysolomon
Old Feb 09, 2013, 07:25 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
use the 1100 LiFe pack straight into the rec
jcdfrd is online now Find More Posts by jcdfrd
Old Feb 09, 2013, 07:29 PM
Joined Jun 2012
set up for 10-20% more thrust???
Hi,
I'm preparing to order the Habu32 and looking for a fan/motor that I would use for the build. I'd like to run 6S (to keep it light) and have just a little more power than the stock setup. The stock setup runs 60-65Amps...I'd be ok going to 70-80Amps with improved thrust.
Is there a commonly used option like this? I've searched this thread and it seems folks use a Mega on 8S or run the stock on 7S. I don't know how I'd charge a 7S pack...might need a new charger. At any rate, 6S is more convenient and cheaper. Along those lines, I'm looking for an inexpensive upgrade (if it exists), no $300 alloy fans.
Andy
sothpaw is offline Find More Posts by sothpaw
Old Feb 09, 2013, 07:35 PM
Jetnfast's Avatar
United States, MO, Warrensburg
Joined Feb 2008
Andy- stock on 7s is possible with the right cooling. As for a hotter 6s setup, the options you mentioned would work, you could also go with a TJ80 from tamjets or a jetfan 80 for a nice improvement in sound and performance.
I know what you mean about charging a 7s pack since most balancing taps for this batteries need creative and careful adaptation to balance charge. The ones from HK typically have two balancing leads a 3s and 4s coming out of it where as the gens ace 7s has a 7s lead and I have yet to find a balancing board you can buy for 7s, some make their own though....
Jetnfast is offline Find More Posts by Jetnfast
Old Feb 09, 2013, 10:01 PM
737DRIVER
tvessie's Avatar
Stockton, CA
Joined Mar 2008
Andy
I fly with a 5100 mAh 6S setup with a 85 Amp ESC and it's powering the 80MM Stu Max fan. The fan sounds awesome, it's quiet and sexy looking and it's a snap to install. That's the beauty of this hobby, so many choices.
Tom
tvessie is offline Find More Posts by tvessie
Old Feb 09, 2013, 10:20 PM
Mile High EDF
United States, CO, Denver
Joined Jul 2011
I have one of these for sale , this is stock fan and eflite bl2150kv motor , with Tamjets carbon shroud and heatsink.
It can run 7s
It's lightly used on 6s
$90 shipped CONUSA
420flyboy is offline Find More Posts by 420flyboy
Old Feb 09, 2013, 11:43 PM
Joined Jun 2012
Thanks! What motor would I use w/the TJ80 or jetfan80 or Stufan? Would I get more thrust or just sound? Any idea on the power made vs the eflite setup?
Old Feb 10, 2013, 08:33 AM
Dublin Ireland
Joined Aug 2005
Originally Posted by tvessie View Post
Andy
Tom
Hi Tom
When You installed Stus Fan did you have to move stuff around or add weight to get the COG right?
Steve.
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Feb 10, 2013, 05:45 PM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Joined Mar 2006
I dunno about $300.00 alloy fans but you will be spending more than 300 bucks on some of the other fans suggested without motor! Only the Jetfan is in the value price range at 150 odd.
Here is a 6s combo with CNC alloy housing, custom wemo PRO rotor and HET 700 series motor, well under $300.00 for the complete fan unit with motor, just add brackets for the Habu install.
http://www.extremerc.com.au/estore/i...oducts_id=1140
Also have a Jetfan combo for not much more $$, still under 300 complete with motor.
http://www.extremerc.com.au/estore/i...oducts_id=1189
Extreme_RC is offline Find More Posts by Extreme_RC
Old Feb 10, 2013, 06:05 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Compared to other high quality EDFs, (EI: Scheubeler, Stumax, jetfan) the Mach 80mm setups bring you great sound, speed, and probably the smoothest, coolest running EDFs available. We've yet to explore the upper limits of these fans yet.
With a $115-130 ARC or HET motor, the 6, 8, and 10s setups are not unreasonable.
Consider that some high end users are running motors that cost twice as much.
There's no fussing with the Mach EDF's. They run smooth as silk right out of the box.
HABU32 at "The Basin" 2/2/2013 (3 min 35 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Feb 10, 2013, 10:12 PM
737DRIVER
tvessie's Avatar
Stockton, CA
Joined Mar 2008
Originally Posted by STEVEAIR2 View Post
Hi Tom
Steve.
The stumax was a plug-and-play just dropped right in! I did not have to add any weight at all, I just moved my battery forward To bring the aircraft back in CG. That size of battery moved forward worked just fine
Old Feb 11, 2013, 02:37 AM
Dublin Ireland
Joined Aug 2005
Thanks Tom
The reason I asked was, my last one of these had a Stumax and even with the
battery moved off the tray as far as the steering servo it was still a bit tail heavy. Mind you it was a 4000 mah battery.Thanks again for the clarification.
Cheers
Steve.
Old Feb 11, 2013, 02:45 AM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Steve,
Why not put a 5000mAh battery in it? (that's the stock size battery anyway)
Site Sponsor
Old Feb 11, 2013, 05:46 AM
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
With my 80mm Stumax i run either a 6 cell 5000mah. Or a 7 cell 5800 Compact (same weight)
C of G is fine.
Chris
icicles is offline Find More Posts by icicles
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
