Old Jun 21, 2014, 12:23 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
AoA hardware and indicator
So I am going to be getting into fpv here soon and have been brainstorming about having an angle of attack indicator. I think this would be really valuable info to have as well as being a fun project.
I have been thinking about a setup for my EDF F-16 to control leading edge flaps using a potentiometer attached to small weather vane and an Arduino to control the servos. I also wanted airspeed information to control a variable exhaust cone at the rear.
For the FPV setup I was thinking about something much simpler. A small weather vane would rotate against a conductive strip connected to a small strip of LED's that are placed in camera view. Power would be a small button battery. There would be something like three green three yellow and two red ones that would light up in progression based on the AOA. Flying fast would be three green as you slow the yellows light up in progression, then red.
There would be some setup required of course. I was thinking about some strings on the wing in front of a box fan to get an idea for the angles. This could be further refined after some flight testing.
From all the videos I have watched it looks like people do fine without it but I think it would be a great tool to make much better approaches and landings.
I have come across many different potentiometers online and the one thing I cannot figure out is how much resistance the knob has to torque. It would need to be fairly loose so that it could rotate freely in the airstream. Obviously this is not important for the simple version but I still have plans for the Arduino version.
Anyway there are my thoughts. Any ideas?
Sherlock is offline Find More Posts by Sherlock
Old Jun 21, 2014, 04:29 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
OK, those are some great ideas! LOL
Old Jun 22, 2014, 09:33 AM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Really? No one has thought about AoA?
Old Jun 22, 2014, 09:40 AM
resU deretsigeR
Western Pa
Joined Oct 2006
My osd has AOA on it, or atleast the artificial horizon.....and that gives you the same info.
LDGILLS is offline Find More Posts by LDGILLS
Old Jun 22, 2014, 10:09 AM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Yes, I have seen ODS's with an attitude indicator. That's not the same as AoA but it is certainly very useful.
Old Jun 23, 2014, 08:22 AM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Really? No interest in AoA?
Old Jun 23, 2014, 12:27 PM
Crashing in style.
Bazed's Avatar
Joined Jun 2012
Would need to be something pretty simple to build tho... Something like the below, on the fuse? Not sure if the smaller reynold numbers would play a role in how accurate it would be... Maybe someone smarter than me could chime in on that..
http://www.aircraftmech.com/pics/aoa.jpg
I'm current building a airspeed sensor with a pitot tube and I'd love to have a AoA indicator as well, got plenty of free ADC pins left on the atmel328.
So yeah, I'm interested!
Bazed is online now Find More Posts by Bazed
Old Jun 23, 2014, 01:27 PM
Joined Nov 2007
Of course the idea is very interesting
I can see a bit of trouble converting the aoa vane position to electrical signalling?
Perhaps a piece of very light wire suspended small amount away from fuselage but in fpv camera wiew can provide the same information?
Something like this?
Hero with a wing (6 min 55 sec)
oops! video credits to ommadawn
sweflyer is offline Find More Posts by sweflyer
Old Jun 23, 2014, 01:39 PM
KD0EMB
United States, KS, Wichita
Joined Jan 2013
I've thought about it too. would be cool if you could do it in a compact way.
eraujk is offline Find More Posts by eraujk
Old Jun 23, 2014, 02:21 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Nice! I think you could get some crude AoA info off of a string like that. I was actually thinking of something similar with some sort of backing, like a flat piece of plastic, to get a closer idea of the angle. Mark the plastic with a line perpendicular to the zero AoA chord of the wing. Index some other marks and then fly it to see where the stall angle is. The string would follow the wind and be attached to the leading edge of the plastic and move up and down against the indexed marks.
Another way is to attach the AoA vane to a rotary potentiometer. Potentiometer output is voltage that varies based on the position. A simple program could read the voltage and drive servos or light up lights or possibly generate a display on an OSD
Old Jun 23, 2014, 02:51 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Yes exactly! Make a similar weather vane and attach that to a potentiometer. Send that output to the pin and write a program to do what you want with it. That is way over my skill level at this point though. I know what I want to do but writing the code and finding a proper potentiometer are the biggest challenges right now.
Old Jun 23, 2014, 02:57 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
I don't think the small r number would be a problem. As long as it is sticking out the side if the fuselage a bit it should be fine.
Old Jun 23, 2014, 03:03 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
I was thinking of a small flat piece of balsa triangularly shaped and attached to the potentiometer about 25% from the leading edge like all flying elevators. A small weight at the back will help bias it to "fly" without flipping the other way.
Old Jun 23, 2014, 03:35 PM
KD0EMB
Joined Jan 2013
I like the rotary potentiometer with measured voltage output. Could do a red, green, yellow LED indexer that's visible to the camera if you didn't want to work it into existing OSDs.
Old Jun 23, 2014, 04:59 PM
Sherlock's Avatar
Milwaukee, WI
Joined Sep 2006
Yeah, I like this idea too. Any idea how to set up a circuit like that?
Discussion Aftermarket AOA meter...for certificated aircraft dll932 Life, The Universe, and Politics 13 May 27, 2014 10:31 AM
Question Tail aoa devashri Modeling Science 24 Dec 15, 2013 10:13 PM
Discussion Feds Say Possession of “Large Amounts” of Weapons May Indicate Terrorist Activity rcjetpilot Life, The Universe, and Politics 75 Oct 20, 2013 12:30 PM
Sold LED Power indicator light kylejclaflin Aircraft - General - Miscellaneous (FS/W) 6 Oct 11, 2013 09:14 AM
Sold LED Power Indicator Lights kylejclaflin Aircraft - Fuel - Airplanes (FS/W) 1 Oct 02, 2013 07:00 PM
