Old Apr 05, 2014, 03:28 PM
Thatsright I drankthe rum
K9000wner's Avatar
USA, MN, Robbinsdale
Joined May 2006
one waiting in the closet for to be completed wish I had the time / money
K9000wner is offline Find More Posts by K9000wner
Latest blog entry: nice map
Old Apr 06, 2014, 09:53 AM
Joined Apr 2013
Hi everybody :-)
My first post!
Just ordered my HK Spitfire 1234mm balsa yesterday with SK3-3548 1050kv.
I plan on running a 9x9 apc-e on 4S (theoretical max speed @ 154kmh) , or a 10x10 on 3S (theoretical max speed @ 131kmh),
Didn't order battery yet, i don't know how much room i got.
I was hoping to fit a 3300mah 65c nanotech in it.
Anybody was able to fit a 3300mah 4S in th Spit?
Anyway, thanks for this thread, lots of very useful info here!
marcuspocus is offline Find More Posts by marcuspocus
Last edited by marcuspocus; Apr 06, 2014 at 09:54 AM. Reason: add greetings...a minimum...
Old Apr 06, 2014, 11:32 AM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
I have run both 3s and 4s 4000 in mine. I have run from 10x5 to 12x8 props on different motors. Currently I have 3s 4400, 1400kv motor and 11*8.5 2 blade prop. I have run 3 blades, but the speed was way down and amp draw up and 2 inch three blade spinners are hard to find.
JimNM is offline Find More Posts by JimNM
Old Apr 06, 2014, 01:06 PM
Joined Apr 2013
Thanks alot Jim!
Think I'll get Turnigy 4000mah 4S 30C then...
I'll start with an APC-E 10x7 (have a couples of them) and see from there :-)
Old Apr 06, 2014, 03:03 PM
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
Jim is right 2" 3 blade spinner can be hard to come by, I used a dubro one, but I did find it heavy, master airscrew 11x7 maybe 8 and a 140g 3639 1100kv, 4s 2200. Flew mine as light as possible but it would take some more weight, good luck and lots of pictures please, missing this plane
mustflynow2 is online now Find More Posts by mustflynow2
Old Apr 11, 2014, 08:07 PM
Joined Apr 2013
Got my spitfire today!
I've started the build, everything looking good so far.
But seriously, those mecanicals retracts are really bad.
Won't be using them for sure!
I've ordered hk full metal retract 80deg (instead of the 90deg that came with the spit), hope they'll fit without to much troubles...
Marc
Old Apr 17, 2014, 07:54 AM
Joined Apr 2013
Almost done with building, was fast&easy.
I fitted the full metal retracts from hobbyking, they look very sturdy, but i should have bought the 90deg ones.
I also changed the wheel for real rubber ones, a tiny bit bigger and wider.
=> They still fit perfectly in wheel wells.
Everything a ready for maiden, hopefully this sunday.
Old Apr 17, 2014, 12:34 PM
capteasy's Avatar
USA, Texas Hill Country
Joined May 2008
What rubber wheels did you use....? I'd like to change mine out if they fit.
Good luck with your maiden....you'll have a great experience I think. Let us know
ce
capteasy is offline Find More Posts by capteasy
Latest blog entry: E-flite hawker Hurricane 25E
Old Apr 17, 2014, 03:04 PM
Joined Apr 2013
Got "airtrap 44mm" from a lhs:
http://www.flashrc.com/a2pro/3590-ro...ique_44mm.html
Thanks for the maiden :-)
Discussion what do ya think about this video? furyflyer2 Foamies (Kits) 2 May 05, 2006 05:19 PM
Discussion What do ya think, JR 10x heli or JR 9303? Bunyan Radios 2 Apr 24, 2006 04:20 PM
Discussion brushless pcw, going lipo 1stimer, what do ya think? snowcrash75 Flying Wings 1 Dec 31, 2005 02:36 AM
What do ya think about that? dad57c Engines 2 Dec 15, 2005 09:15 AM
Mini-Falcon,..What do ya think?,. wackyd Slope 19 Jan 29, 2005 09:41 PM
