Old Mar 22, 2014, 01:14 PM
Always comPLANEing
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
I expected to be able to determine a base map by runups and monitoring that would be better than fixed mixture. These small engines may be tricky.
Chophop is offline Find More Posts by Chophop
Old Mar 25, 2014, 08:27 AM
Canada, ON, Hanover
Joined Jul 2011
I wouldn't have the patience for that, I would just buy a picospray, bolt on efi unit as soon as they are available, or there is another company called ecotron that has them also but they are hugely expensive I think around 399.99 for the kit
http://www.ecotrons.com/products/sma...injection_kit/
an interesting article for picospray:
http://www.popularmechanics.com/cars...etors-15682450
larz001 is offline Find More Posts by larz001
Old Mar 25, 2014, 08:33 PM
Always comPLANEing
Chophop's Avatar
Joined Sep 2006
All you really need to do for a reasonable start is set points on a throttle curve memory array. Run the engine at the throttle points, adjust the mixture for optimum burn, then enter the temperature and needle position into memory. Then the trick is to know which side of the error you are on, and correct if needed. The creep and peep method may not be fast enough, and the temperature probe may not respond fast enough either.
I have mentioned, larger snowmobile and ultralight engines have a needle that follows the throttle, and it is shaped to optimize the mixture at most throttle positions.
This could possible fix those awful rough places along the throttle curve that make you worry the motor could quit.
I need to dig into it and then I'll get it if it is able to improve how these motors run, terrible sounding to me.
Looks like back surgery is on review after the MRI I had. It's getting so bad I'm doing well to stand and walk. So now I go the a consult for surgery. I may be able to get some work done after that, but I have heard lots of not so good stories about spinal surgery.
Old Mar 25, 2014, 10:08 PM
Complete RC Idiot Savant
The Netherlands
Joined Nov 2009
I really wish U good luck on that part, that fuel mixture thingy is of lesser importance....
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Mar 26, 2014, 01:56 AM
Always comPLANEing
Chophop's Avatar
Joined Sep 2006
Oh, it's only a surgery. Not as if he were going to pull out a chest hair and everything else that follows.
Old Mar 26, 2014, 02:48 AM
Australia, SA, Adelaide
Joined Sep 2007
I feel your pain chopchop. If it wasn't for the pain pills I couldn't get of bed . Your lucky in that surgery is a option . There not the butchers that everyone makes out and generally won't do anything unless their sure its gonna help but one things for sure your back is never going to be the same . I have 3 dodgy discs in the back and 1 in the neck and if surgury was an option I would run over a nun to get to the hospital . Make sure your happy with your doctor and specialist and if not pi$$ em off until you find one your happy with . Good luck with everything I think your gonna be out of action for awhile but there is light at the end of the tunnel. Cheers the pope .
the pope is online now Find More Posts by the pope
Old Mar 26, 2014, 07:07 AM
Always comPLANEing
Chophop's Avatar
Joined Sep 2006
Thanks. Some readers have been hearing of my back problems over a few years, so I thought I'd announce it is being evaluated again, MRI shows worsening problems.
Old Mar 26, 2014, 07:13 AM
Canada, ON, Hanover
Joined Jul 2011
good luck to you chophop here is hoping everything goes well in the future
Old Mar 26, 2014, 03:16 PM
Always comPLANEing
Chophop's Avatar
Joined Sep 2006
Give me a pair of pliers. I'll squeeze your thumb with them awhile then let go , to show how that works for improving the sense of well being.
Old Mar 26, 2014, 05:04 PM
ncflyer79's Avatar
United States, NC, Marion
Joined Jun 2011
guys im trying to find some info on the NGH 25 but not having much luck. Any opinions?
ncflyer79 is offline Find More Posts by ncflyer79
Old Mar 28, 2014, 11:17 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I don't know anyone that used one. But it uses a Walbro carb clone, so the carb is easy to rebuild if needed. But the engine works pretty good. The connecting rod does not have needled bearings so you still need to use a 20:1 fuel to oil ratio when new during run in and maybe can go to 25:1 after it has a few hours on it. I also suggest using a really good synthetic oil such as Stihl HP Ultra for example. Do not use the inexpensive oils or the rod may fail.
Here is a review of it here http://christiantraders.com.au/conte...l%20Engine.pdf
earlwb is offline Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Apr 09, 2014, 08:36 PM
United States, NC, Coats
Joined Jul 2013
earlwb, how did the 9cc ngh engines work out?
koolhand55 is offline Find More Posts by koolhand55
Old Apr 09, 2014, 09:49 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well, the ones I am using work for me. Two engines are stock and the third one has a Walbro carb on it. Unfortunately a lot of other people were having trouble with the pump/regulator unit though. Actually I had trouble with them until I more or less figured out ways to make them work OK. So I guess it depends on the person and their luck and or skill. The carburetors are sort of screwed up, but they work if you use the 1/2 open as idle speed from there to WOT. Trying to make the carb work more normally just doesn't work. It might if the needles are reworked, but I never bothered to try though.
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Dec 10, 2011 11:31 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 14, 2011 11:44 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Oct 07, 2011 10:46 AM
For Sale Prop Chart and Thread finder for any Glow or Gas Engine unclegeorge Aircraft - General - Miscellaneous (FS/W) 3 Sep 23, 2011 11:25 PM
Sold NGH GT17cc gas engine NIB ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jun 30, 2011 10:35 AM
