Old May 18, 2015, 09:31 AM
MIGPILOT44 is online now
Find More Posts by MIGPILOT44
United States, PA
Joined Dec 2013
Help!
Changesun 10 Blade EDF Unit
Hello all, recently purchased a Changesun 10 blade EDF unit. The seller stated it was new and never used but when i received it the hardware package only included a 4mm adapter. This was ok as my motor has a 4mm shaft. My major concern is that when the motor is mounted in the fan housing and the adapter is put on the shaft and the fan is tightened down against the compression ring, the shaft adapter rubs on the housing and the fan will not spin. Has anyone run into this problem before? I'm sure I could carefully dremel out where its rubbing but its very close to where the motor mount bolts go through the fan housing. It does not sound ideal to weaken the motor mount area by removing material in this area.
Any thoughts?
MIGPILOT44 is online now Find More Posts by MIGPILOT44
Old May 18, 2015, 10:14 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
As you tighten it moves back. Pull it forward a bit then tighten...
Chris True is offline Find More Posts by Chris True
Old May 18, 2015, 12:09 PM
United States, PA
Joined Dec 2013
I've tried that a couple times, to get it to lock down on the shaft just forward of the housing but it still seems to want to drag on the inside of the motor mount area.
I'll keep trying your method if you are saying this is what works..........
Thanks for the reply!
Old May 18, 2015, 12:22 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I don't use the supplied adapters, with the CS fans. They are usually too loose and sometimes even bored off center. Tams, Efflux and Extreme, all carry adapters that are correct, in either 3.17mm or 4mm. Well worth the price. Save the CS adapters for a prop job.
Question, does the shroud have 4 stators or more? The V-1 has 4 stators, and these all had bad adapters. Some of the newer V2 and V3 adapters were improved, but it was still a hit and miss on quality. There is a huge thread on the CS-10. There are certain requirements for operating these high load fans. One is minimum 100%FSA intake area and 60-61mm dia exhaust(100%).
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old May 18, 2015, 12:35 PM
Joined Dec 1996
It does work. If you are still having difficulty, insert 2 or 3 shims of 1/64" ply between the back of the rotor and the motor mount. Set the rotor against the shims, tighten, then pull the shims out.
One other tip that may help, put just a tiny amount of grease on the tapered cone part of the adapter, then when you drop the driver section that engages the back of the rotor on it will tend to tighten a little easier.
Old May 18, 2015, 01:03 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Any thoughts?
Hold the rotor up through the stators from the bottom of the shroud with your fingers so the top of the rotor blade are 2 - 3 cm away from the top rim of the shroud.
Start tightening the shaft adapter nut with fingers...
Never will get a rubbing shaft adapter again
erh7771 is offline Find More Posts by erh7771
Old May 19, 2015, 12:29 AM
United States, PA
Joined Dec 2013
Thanks for all the replies, I'm hoping to have some time tomorrow to look into this fan just a little but more.
I'll report back with as to how things work out.
Old May 20, 2015, 07:32 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
My tip is to dry fit all the parts. I like to ream the center hole of the motor mount just so I can install the adapter on the motor before inserting into the housing with out interference, then test the clearance of the impeller by adjusting the adapter height. Once I have the adapter elevation set on the motor shaft, then its time to ad the motor screws for final assembly, clock the impeller and go for one billion rpm!
ApexAero is offline Find More Posts by ApexAero
Latest blog entry: no comment
Old May 21, 2015, 02:15 PM
United States, PA
Joined Dec 2013
Thank you for all the advice, tips, and tricks to get this working right. I'm glad to hear others have run into the same problems.
I did eventually get this fan to run smooth and got it mounted in my ARC Mig 15. What a great flying EDF, I've really enjoyed this kit and can't say enough good things about it. I wish they were not out of production and easier to find here in kit format within the USA. If anyone knows where you can buy this kit either here in the USA or even overseas please let me know.
Thanks again for all the help
Sold Leopard 3400kv / ChangeSun 70mm 10-Blade EDF Unit HardAbz Aircraft - Electric - Jets (FS/W) 11 Mar 07, 2015 10:16 PM
Sold 10 blade ChangeSun edf unit nib dumbthumbbum Aircraft - Electric - Jets (FS/W) 1 Feb 24, 2015 07:56 PM
Sold New Changesun 10 blade 70 mm fan unit with spare rotor. The Don Aircraft - Electric - Jets (FS/W) 2 Jan 18, 2015 10:52 AM
Sold ChangeSun 70mm 10 Bladed EDF fans never flown PJPJ Aircraft - Electric - Jets (FS/W) 0 Dec 31, 2014 11:57 PM
Sold Changesun 64mm 12 blade EDF units The Don Aircraft - Electric - Jets (FS/W) 3 Jun 10, 2014 11:43 AM
