Old Apr 10, 2014, 01:29 PM
Pysy ilmassa, perkele!
Finland, Köyliö
Joined Jun 2013
Originally Posted by SeByDocKy View Post
Maybe some E6000 or CA glue ?
I used CA after I inserted a few rounds of the thin white packing foam that BG uses in all their packaging. Works quite well and increases traction as well as makes the tyres wear more evenly.
ScorpioFIN is offline Find More Posts by ScorpioFIN
Old Apr 10, 2014, 01:41 PM
Finland, Köyliö
Joined Jun 2013
Today I fitted these and had time to run one battery through with them:
https://www.hobbyking.com/hobbyking/...dProduct=34583
All I can say is WOW! The handling is unbelieveably better and there is also a good ground clearance, no fear of the bottom hitting the ground. When you drop the car from about 50 cm to the ground it does not bounce, it just sits there.
All the jumps and bumps that would earlier make the car spin are now smoothed and now I can actually steer this thing all the time, not only when I hit the brakes.
No modifications needed other than longer screws to the upper mounting points.
Old Apr 10, 2014, 02:04 PM
Finland, Köyliö
Joined Jun 2013
Tried a bit on the tarmac... I'd say 40+ km/h easily.
WLToys L959 speedtest (0 min 19 sec)
Old Apr 10, 2014, 02:07 PM
Finland, Köyliö
Joined Jun 2013
...and some jumping. In this video I only had the old Tamiya (1983 or so) rear shocks installed, but still the rear does not hit the ground like with stock springs.
L959 jump test, rear oil shocks. (0 min 9 sec)
Old Apr 10, 2014, 02:11 PM
Finland, Köyliö
Joined Jun 2013
Funny. I'm on iPad and if I try to watch those videos either small or fullscreen, the quality is awful. But when I open them in new tab, they show just ok.
Old Apr 11, 2014, 06:12 AM
WLmadness's Avatar
Russia, MO, Balashikha
Joined Apr 2014
Wltoys l959 durability test with tire mod (compound)
Wltoys l959/l202 Durability test/Испытания на прочность #1 (2 min 3 sec)
WLmadness is offline Find More Posts by WLmadness
Mini-Review WLtoys V912 4-Channel Fixed Pitch Helicopter Mini-Review FyreSG Micro Helis 5886 Today 06:47 AM
Mini-Review WLtoys V959 Quad (with Video Recording Function) Mini-Review FyreSG Mini Multirotors 1248 Apr 06, 2014 09:16 PM
Data HiSKY FBL100 / Turnigy FBL100 / WLToys V922 vs. mCP X Parts Compatibility sparkyjohn Micro Helis 100 Mar 30, 2014 01:19 PM
Mini-Review MJX F45 VS F46 ,WLtoys V912 VS V913 Aaron qin Micro Helis 119 Feb 06, 2014 08:34 AM
Discussion WLtoys V949 UFO Quad fierce Hot Online Deals 5 Jan 09, 2013 09:07 AM
