Old Nov 21, 2012, 12:40 PM
United Kingdom, England, Cambridge
Joined Aug 2012
Turnigy 9x - Frsky does not fit!
H all, my order finally arrived in the UK from hobby king.
I got the combo deal Turnigy 9x and Frsky module.. And it does not fit flush and will not clip in. I read on another forum to trim down the pins on the TX. Does that really need to be done, it sticks out not flush by about 3mm but I'm sure the pins are together. Can I just tape it down to secure it or hot glue gun?
Jmm_jammy is offline Find More Posts by Jmm_jammy
Old Nov 21, 2012, 01:18 PM
kitesurfer
Australia, WA, Perth
Joined Dec 2005
ahh, i had this problem with the turnigy but not the flysky tx.
to be able to plug the module into the tx, i had to unscrew the module, plug the bottom plastic plate into the tx, then plug the board onto the pins, then screw the top of the module back on.
this was with the flysky module though and not the frsky.. not sure if its the same.
AliB is online now Find More Posts by AliB
Old Nov 21, 2012, 03:02 PM
Joined May 2012
You don't have to trim the pins. Just cut the plastic around them. It was what I did and it's perfect.
crocus is offline Find More Posts by crocus
Old Nov 21, 2012, 05:09 PM
Joined Aug 2012
Do you mean the plastic moun on which the male pins sit on? I noticed the raised mount they are on has slightly rounded edges which stick out a bit, do you mean some how file this bit down?
Old Nov 21, 2012, 05:10 PM
Joined Aug 2012
Also, while fitting the Frsky and the USB mod, I've seen some people fit a LED and bind button, is that necessary??
Old Nov 22, 2012, 05:16 AM
Joined May 2012
Yes you can trim that plastic around the male pins until the module fits perfectly!
Old Nov 22, 2012, 07:43 AM
Joined Aug 2012
Got the dremel out last night and removed all the plastic mouldin around pins, fits perfectly now! Thanks guys
Old Mar 31, 2014, 06:43 AM
Freezes when panicking
daniirwan's Avatar
Kuala Lumpur, Malaysia
Joined Mar 2007
Just curious...after doing the mod & removing the plastic bit around the pins, sure the DJT module fits perfectly...but how about if you want to use another module..say Orange's DSM2/DSMX module? Will it fit perfectly even though the plastic bit is gone from around the pins?
daniirwan is offline Find More Posts by daniirwan
Build Log Turnigy 9X and FrSky with Telemetry for Dummies Art Newland Radios 26 Dec 22, 2011 11:54 AM
For Sale Turnigy 9x, Frsky and goodies!! bizzeus Aircraft - General - Radio Equipment (FS/W) 10 Nov 29, 2011 10:06 PM
For Sale Turnigy 9x, FrSky, 900mhz tx/rx, cam fpv_copter FPV Equipment (FS/W) 4 Jun 15, 2011 08:39 AM
For Sale Turnigy 9x w/ Headtracking and Frsky Module - 2x 8ch rx galexis FPV Equipment (FS/W) 2 Dec 11, 2010 12:05 PM
Discussion JR8103 w/Frsky 2.4 and Turnigy 9X kuya- Radios 3 Dec 05, 2010 08:31 PM
