Old Jan 20, 2015, 10:13 PM
Joined Dec 2014
Classic Runabout needs TLC
I am hoping someone can help me repair my boat.
I have a ProBoat Classic Runabout 29".
The sides have wood planks that are glued to a fiberglass hull.
My problem is, some of these planks have contracted and opened up gaps.
If I keep running the boat I will probably ruin it.
I would really rather not strip the entire boat to fiberglass it. None of the trim pieces are being produced any more.
Is there a way to seal the sides and still make it look decent?
Thanks!
Ron
Rsmith0399 is offline Find More Posts by Rsmith0399
Old Jan 20, 2015, 10:39 PM
Vince Hoffmann's Avatar
Hayward, CA
Joined Jan 2009
Is the wood sealed with epoxy or urethane? Remove the metal fittings and give it a good sanding. Don't remove the finish down to the wood, but give it a good tooth. Put on a fresh coat of epoxy (or whatever it is finished with) and work it into the gaps between the planks. It may take more than a few coats, but you can restore it back to good working condition. If you sand it between coats, you will get a beautiful glossy finish, but you will need patience and don't stop until you have at least 6 coats.
Vince Hoffmann is online now Find More Posts by Vince Hoffmann
Old Jan 20, 2015, 10:48 PM
Joined Dec 2014
Pretty sure it's urethane. That won't keep it from cracking again will it?
Old Jan 21, 2015, 09:09 AM
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
I have had a couple of seams open up on that runabout. I flowed thin C/A into the seam. This sealed the seams up very well with no further problem. Future floor wax is an actylic and will bring the finish back up also.
VINCE, The crome plated trim pieces on this boat are plastic not metal.
Hobbico had a set of replacement trim parts for the boat at one time.
charlie eaton is offline Find More Posts by charlie eaton
Old Jan 21, 2015, 04:34 PM
Hayward, CA
Joined Jan 2009
CA is a good option, then a good re-seal with brush applied urethane should seal it up nicely.
Sold ProBoat Classic Runabout 29" Rsmith0399 Boats (FS/W) 7 Jan 20, 2015 09:39 PM
Discussion Hull repairs on Classic Runabout Rsmith0399 Dock Talk 11 Jan 09, 2015 04:02 PM
Sold Blade SR needs TLC some spare parts Dallas101 Aircraft - Electric - Helis (FS/W) 1 Oct 21, 2014 10:35 PM
Sold Blade SR needs TLC some spare parts Dallas101 Aircraft - Electric - Helis (FS/W) 0 Oct 10, 2014 07:44 PM
Discussion Motor upgrade for ProBoat Classic Runabout? 98 SNAKE EATER Scale Boats 24 Feb 24, 2014 10:06 PM
