USA, ME, Ellsworth
Joined May 2008
Greg,
Thanks for reminding me of something I have totally forgotten. When you say: "..By winding 3 slot pitch coils, 1.0 winding factor is achieved. It's very common..." I simply cannot visualize what that would look like. But then, I have very poor math and geometry skills. Any skill I have there is to simply do the work by rote without a true understand of the concepts. Is this document an explanation of what we are talking about on the winding factor? http://davidsonsales.com/docs_pdf/CoilPitch.pdf I'm going to print it and read it over and over if it is. Jack |
For those that got involved after the outrunner revolution the common inrunner designs seem foreign. Most inrunner are wound like this. This was the thread. The links to documents are in there.
The document you link gets into fractional pitch coils. This is important to reduce harmonics in large, high power motors, but not important for model size motors. VTdiy, the thing to keep in mind is that 2 phases are energized in the case of Wye, and all three, though at different currents, with Delta termination. If you look around the stator tooth heads some will be directly over a magnet and some between. If you look at a winding scheme with a low winding factor like 0.5 and pay attention to the states of the armature magnetization you'll see that some coils simply aren't contributing to the torque. The goal is to make all to the work in the same direction. This is winding factor. Greg |
Latest blog entry: A tiny diesel engine AE 0.1CC
| Thread Tools | |
| Help! i'm looking for a tiny video cam for an r/c jet | iflyrc1012 | Aerial Photography | 1 | Jun 24, 2012 05:00 PM |
| Wanted Mills 1.3 non r/c carb.... Trade for r/c carb | stegla | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Jun 04, 2011 03:30 AM |
| Wanted Wanted: Radio/motor/battery setup from an el-cheap-O "RTF" R/C plane. | Cheesehead | Aircraft - General - Miscellaneous (FS/W) | 1 | Aug 01, 2006 11:05 PM |
| Can I use an r/c car battery for an r/c plane?? | jacksonjrs | Parkflyers | 7 | Jan 28, 2004 10:25 PM |
